I need help with a formula
chromo23
#1 Post by chromo23 » 10 May 2022, 21:12
For more than a decade i use arduinos to control my led lights (kitchenlight, wakeuplight in bedroom)
I use a formula for this to have a nice fade in/out effect that also takes care of the non linearity of the brightness of a led while fading in a linear way.
by slowing the process down i have also a wakeuplight for the winter.
I would like to move this to an esp8266 or esp32.
How would this work in rules? I can not do the syntax right....
value = (exp(sin((x - 1000) / 2000.0 * PI)) - 0.36787944) * 108.0;
value2 = (int) value;
analogWrite(pulsepin, value2);
Re: I need help with a formula
#2 Post by TD-er » 10 May 2022, 21:24
How often do you need to update the value per second?
For a wake-up light, it doesn't have to be quick, but for other purposes I can imagine you may need to do it several times a second.
This may be a bit too much for rules.
Just plotted the formula to get an idea of the curve: https://www.desmos.com/calculator/yu1a1y27a1
chromo23
#3 Post by chromo23 » 10 May 2022, 21:37
right now it is limited to 255 so the maximum needs to be adjusted to 1024.
i also use this for a pulsing/breathing led....therefore the sinusoidal component.. so milliseconds
I already thought that rules would be to slow. probably putting it into a plugin would do the trick right?
#4 Post by TD-er » 10 May 2022, 21:38
Just pre-compute a constant.
/2000*pi = *(pi/2000) = *0.0015708
on compValue do
  let,1,exp(sin((%eventvalue1% - 1000) * 0.0015708)) - 0.36787944
  let,1,[var#1]*108
  pwm,2,[var#1] // GPIO 2
The event can then be something like
event,compValue=100
chromo23
#5 Post by chromo23 » 10 May 2022, 22:28
i changed the formula to use less steps for one cycle but still it is way to slow...
#6 Post by TD-er » 10 May 2022, 22:34
Then we must add some new flag to the PWM command, to apply some LUT and still allow for a fade from one value to another.
Users browsing this forum: Google [Bot] and 18 guests
