ESP07 and AHT10
ESP07 and AHT10
Hello Everyone!
I have some ESP07 modules with 1Mb memory and AHT10 temperature sensor. Unfortunately, I can't force it to work together with ESPEasy.
I've tried to flash "ESP_Easy_mega_20211224_normal_ESP8266_1M.bin" - ESP07'd started and worked, but in "normal" flash there is no AHT10 support
I've tried to flash "ESP_Easy_mega_20211224_test_A_beta_ESP8266_4M1M" - but ESP07 had not started with this flash.
Have anybody any ideas how else can I try to force to work them together?
Big thnks!
Big thnks!
Re: ESP07 and AHT10
There is no standard build that has the combination of 1MB Flash support and the AHT10 plugin available.
You will have to use a Custom build, either by creating one or if you can't build it yourself, ask nicely, and we might provide one here
Re: ESP07 and AHT10
"So I went down and got it for you..."
This is a 'normal' 1MB build where I added plugin AHT10/20/21 (P105)
The build seems not to work as intended so I removed it.
Re: ESP07 and AHT10
Thank you, that's great news!
If it possible, I would like to try to create Custom build by myself. Where can I found manuals or some starting instructions for it?
Thank you one more time!!
Re: ESP07 and AHT10
And this thread is also a bit helpful, I guess: viewtopic.php?f=4&t=8760&p=54949#p54949
Re: ESP07 and AHT10
Thank you very-very much!
Unfortunately, your build didn't work with my chinese ESP07, but I'd compiled my own custom build using your link and it started to work!
Thanks a lot!
Re: ESP07 and AHT10
No, module didn't start wifi, and when I tried to connect to module with com-port it didn't answer anything except 1 line of unreadable symbols.
Now I flash another module with your firmware and it send to com-port some information, but wifi on it doesn't start too
Re: ESP07 and AHT10
Hmm, my build must have not been baked right. I've removed the attachment to prevent disappointment for other users finding this thread.
You have built a working one yourself, so all is fine
Re: ESP07 and AHT10
Anyway, your help was awesome! So quick and helpful! Thank you very very much!
Re: ESP07 and AHT10
Hi, can you help me build a build for ESP-01s 1MB version that supports AHT10? I can't add plugin to compilation.
Re: ESP07 and AHT10
I can build it later today, 6 to 8 hours from now, what other plugins do you require/use?
Re: ESP07 and AHT10
I care about this one sensor, I want to monitor the temperature and humidity in the hive - the data will be sent to domoticz.
Re: ESP07 and AHT10
MQTT or HTTP Domoticz controller?
Re: ESP07 and AHT10
I've created a NORMAL build where I disabled the NeoPixel plugin, to gain some room in the bin file, and enabled the AHT10 plugin (P105). This should have the regular Contrroller set included, where both the Domoticz HTTP and MQTT are available.
it is built from the latest available mega sources. Please report your findings.
Re: ESP07 and AHT10
Thank you for your help, as soon as I test I will let you know if it works. On Monday I will have the opportunity to test.
Users browsing this forum: Google [Bot] and 11 guests
