TM1637 LED Display Module hack
asuz
#1 Post by asuz » 02 Sep 2022, 22:46
Hello to all, I need to use TM1637 LED Display Module with big 7 segment display. The common TM1637 LED Display Module's displays are small. Here is sample:https://www.aliexpress.com/item/1005002 ... TLUBEHpcUF. May I change the TM1637's 0.56 inch LED Display Module with the 0.8 inch one as the link https://www.aliexpress.com/item/4000284 ... i96xq6q9Pl. I need advice from experts.
Re: TM1637 LED Display Module hack
#2 Post by Ath » 02 Sep 2022, 23:13
You can use any size of display, as long as it is supported by the plugin & hardware, and TM1637 is supported, so I see no issues here. The plugin is only concerned about the chip used, not the display connected to the chip ;)
asuz
#3 Post by asuz » 02 Sep 2022, 23:16
Ath wrote: 02 Sep 2022, 23:13 You can use any size of display, as long as it is supported by the plugin & hardware, and TM1637 is supported, so I see no issues here. The plugin is only concerned about the chip used, not the display connected to the chip ;)
Should i change the display with common anode or common cathode one?
#4 Post by Ath » 02 Sep 2022, 23:41
That depends on what's currently being used, I'm not an expert on that, sorry, just been using 'regular' units, bought from my friends at Ali ;)
Depending on price, you can buy both types and don't use the ones that won't work, but that's not efficient, better investigate what's being used.
asuz
#5 Post by asuz » 03 Sep 2022, 18:33
Ath wrote: 02 Sep 2022, 23:41 That depends on what's currently being used, I'm not an expert on that, sorry, just been using 'regular' units, bought from my friends at Ali ;)
Right, i will buy both types and try :idea:
#6 Post by Ath » 03 Sep 2022, 21:35
Did a bit of a google search and found this note: "The TM1637 supports only common anode displays"
That should get you the correct ones 8-)
asuz
#7 Post by asuz » 04 Sep 2022, 11:21
Ath wrote: 03 Sep 2022, 21:35 Did a bit of a google search and found this note: "The TM1637 supports only common anode displays"
important information, It's good that you told me before ordering. :D
asuz
#8 Post by asuz » 19 Sep 2022, 14:32
After two weeks of waiting, 0.8 Inch 7 Segment displays arrived. I want to share with all. Might be later somebody use. I soldered the new display as a prototype, don't mind the workmanship, I haven't done the final assembly yet. Please see the differences with orjinal TM1637 display modul.
asuz
#9 Post by asuz » 19 Sep 2022, 14:45
Those displays are 4 bit Anode type. Actually I bought 2 types of display. One is 4 bit Common Anode another is 4 bit Anode Clock. But 4 bit Anode Clock has 7 pins but 4 bit Common Anode has 6 pins. The original TM1637 has 6 pins with clock. What do you think about how can I connect 4 bit Anode Clock (7 pin) to the TM1637)
#10 Post by Ath » 19 Sep 2022, 20:10
Looks like a nice experiment, working out as intended :D
The 2 middle dots are usually (for what I could find on Google) connected in parallel on the extra pins, 1 on each side. Using a multimeter in diode test mode should assist in finding what pins are used for that. Not sure how they should connect to the TM1637 though but there are a lot of schematics available on google too.
