Compilation failed - release ESPEasy-mega-20221105
skwaruch
#1 Post by skwaruch » 14 Nov 2022, 21:24
I do everything according to this tutorial (at least I think so): https://espeasy.readthedocs.io/en/lates ... noIDE.html
Below are the error messages:
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\CustomBuild\CompiletimeDefines.cpp: In function 'uint16_t get_build_nr()':
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\CustomBuild\CompiletimeDefines.cpp:31:58: note: '#pragma message: Build is not based on current date'
   31 |   #pragma message ( "Build is not based on current date" )
In file included from C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginTaskData_base.h:7,
                 from C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginTaskData_base.cpp:1:
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:158:27: error: 'taskVarIndex_t' has not been declared
  158 |   void    initPluginStats(taskVarIndex_t taskVarIndex);
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:159:28: error: 'taskVarIndex_t' has not been declared
  159 |   void    clearPluginStats(taskVarIndex_t taskVarIndex);
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:182:16: error: expected ';' at end of member declaration
  182 |   PluginStats* getPluginStats(taskVarIndex_t taskVarIndex) const;
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:182:45: error: expected ')' before 'taskVarIndex'
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:184:16: error: expected ';' at end of member declaration
  184 |   PluginStats* getPluginStats(taskVarIndex_t taskVarIndex);
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:184:31: error: redeclaration of 'PluginStats* PluginStats_array::getPluginStats'
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:182:16: note: previous declaration 'PluginStats* PluginStats_array::getPluginStats'
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:184:45: error: expected ')' before 'taskVarIndex'
In file included from C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.cpp:1:
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginTaskData_base.cpp: In member function 'PluginStats* PluginTaskData_base::getPluginStats(taskVarIndex_t) const':
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginTaskData_base.cpp:141:60: error: expression cannot be used as a function
  141 |     return _plugin_stats_array->getPluginStats(taskVarIndex);
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginTaskData_base.cpp: In member function 'PluginStats* PluginTaskData_base::getPluginStats(taskVarIndex_t)':
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginTaskData_base.cpp:149:60: error: expression cannot be used as a function
  149 |     return _plugin_stats_array->getPluginStats(taskVarIndex);
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.cpp:274:6: error: no declaration matches 'void PluginStats_array::initPluginStats(taskVarIndex_t)'
  274 | void PluginStats_array::initPluginStats(taskVarIndex_t taskVarIndex)
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:158:11: note: candidate is: 'void PluginStats_array::initPluginStats(int)'
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:152:7: note: 'class PluginStats_array' defined here
  152 | class PluginStats_array {
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.cpp:296:6: error: no declaration matches 'void PluginStats_array::clearPluginStats(taskVarIndex_t)'
  296 | void PluginStats_array::clearPluginStats(taskVarIndex_t taskVarIndex)
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:159:11: note: candidate is: 'void PluginStats_array::clearPluginStats(int)'
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.cpp:439:15: error: no declaration matches 'PluginStats* PluginStats_array::getPluginStats(taskVarIndex_t) const'
  439 | PluginStats * PluginStats_array::getPluginStats(taskVarIndex_t taskVarIndex) const
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.h:182:16: note: candidate is: 'PluginStats* PluginStats_array::getPluginStats'
C:\arduino-1.8.19\portable\sketchbook\ESPEasy\src\DataStructs\PluginStats.cpp:447:15: error: no declaration matches 'PluginStats* PluginStats_array::getPluginStats(taskVarIndex_t)'
  447 | PluginStats * PluginStats_array::getPluginStats(taskVarIndex_t taskVarIndex)
exit status 1
Re: Compilation failed - release ESPEasy-mega-20221105
#2 Post by Ath » 14 Nov 2022, 21:51
Any chance you could try to compile using VSCode and PlatformIO, as described in this documentation?
That's what is being used as the main development environment for ESPEasy. We currently don't use Arduino IDE, and the effort of getting it all to fit in the limited size of some of the builds requires the use of PlatformIO. And PlatformIO is also the toolchain used to compile ESPEasy using Github Actions.
#3 Post by TD-er » 14 Nov 2022, 23:28
skwaruch wrote: 14 Nov 2022, 21:24 I do everything according to this tutorial (at least I think so): https://espeasy.readthedocs.io/en/lates ... noIDE.html
exit status 1
I looked into the code and it is for sure possible I may have forgotten some #include.
But the one you mention here is not a correct build error.
What you can do is adding #include <sdkconfig.h> in the file
src/include/ESPEasy_config.h:
#if defined(ESP32)
  #include <esp8266-compat.h>
  #if ESP_IDF_VERSION_MAJOR < 3
    #ifndef ICACHE_RAM_ATTR
      #define ICACHE_RAM_ATTR IRAM_ATTR
    #endif
  #endif
#endif
And this include directory needs to be in the include path.
No idea where this should be set in Arduino IDE.
skwaruch
#4 Post by skwaruch » 19 Nov 2022, 19:02
Thanks for the replies.
I solved the problem using VS Code and PlatformIO.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 39 guests
