How to sent numeric converted to string
BartSr
#1 Post by BartSr » 22 Jan 2023, 23:01
Hi!,
To sent textdata from easpeasy to domoticz next syntax is valid.
on CO2#PPM do
SendToHTTP ,192.168.2.100,8080,/json.htm?param=udevice&type=command&idx=909&svalue=SomeData
Domoticz will display "SomeData"in a virtual text-device.
Now I'd like to sent numeric value (content of a variable).
Is there a kind of conversuin formula to do so eg num2string(numericvar)
TIA
-Bart
Re: How to sent numeric converted to string
#2 Post by Ath » 22 Jan 2023, 23:23
The documentation on Rules has most/all info and a lot of examples
For the values of a task you can use the [taskname#valuename] syntax (square brackets included!), optional formatting is also documented at that link, for system variables the %sysname% syntax can be used.
Domoticz expects most values via svalue, but for some the nvalue should be set.
