AM312 mini PIR?
TommySharp
AM312 mini PIR?
#1 Post by TommySharp » 23 Oct 2017, 12:32
Anyone able to help me out getting one of these working with ESP Easy?
https://www.aliexpress.com/item/Mini-IR ... 688bb8ffcf
Re: AM312 mini PIR?
#2 Post by grovkillen » 23 Oct 2017, 12:40
I have used one of those, lots of false alarm. But you might get someone else to help since it should be possible to fix some of those false triggers.
Re: AM312 mini PIR?
#3 Post by Shardan » 23 Oct 2017, 14:45
Same here. I've tested those sensors.
They work, simply as a switch. So just connect the output to a free GPIO and configure it to a pushbutton switch.
See https://www.letscontrolit.com/wiki/index.php/Switch
As Grovkillen said these modules a lot of false positives. Sensivity is not changeable so just some filtering of powersupply might help.
See https://www.letscontrolit.com/wiki/inde ... _positives.
Domosapiens
Re: AM312 mini PIR?
#4 Post by Domosapiens » 23 Oct 2017, 19:45
This PIR seems a simplified module of the HC-SR505 PIR sensor.
I use this one:
https://nl.aliexpress.com/item/HC-SR505 ... 22745.html
The HC-SR505 PIR sensor is sensitive to the 2.4Ghz WiFi.
To solve the false positives problem, I have added a 47pF cap over the input voltage.
With a shielding of isolation plus ALU tape connected to earth
In this box, 230V conversion is on the left, ESP on the right.
So WiFi antenna and HC-SR505 PIR are very close to each other.
Thanks to the shielding, no false positives.
TommySharp
Re: AM312 mini PIR?
#5 Post by TommySharp » 25 Oct 2017, 07:23
So any advice on how to set it up in ESP Easy?
I've connected it to GPIO 15 and set it up as a switch on the Devices tab.
I must have done something wrong because it's not working.....
Can I see the state getting updated in the web interface or do I need to check the MQTT traffic?
Re: AM312 mini PIR?
#6 Post by Shardan » 25 Oct 2017, 12:24
For first testing i'd prefer to use GPIO-12/13/14.
GPIO-0/2/9/10/15/16 have additional functions. The connected sensor might lead to unpredicted results like not booting or crashing.
You can see the actual state in the "Devices" page.
Please remember this site is static and needs reloading (F5) to show changes.
TommySharp
Re: AM312 mini PIR?
#7 Post by TommySharp » 26 Oct 2017, 07:22
Okay so taking this back to complete basics.... I've used a jumper cable and am just connecting D7 (GPIO13) to GND and I'd assume the following setup should allow me make the state change from 0 to 1?
toffel969
Re: AM312 mini PIR?
#8 Post by toffel969 » 26 Oct 2017, 08:12
Yes correct
TommySharp
Re: AM312 mini PIR?
#9 Post by TommySharp » 26 Oct 2017, 10:20
Okay, cool well I'm not seeing any sort of change when I complete the GPIO13 and GND connection so I must have something else not quite right....
Re: AM312 mini PIR?
#10 Post by grovkillen » 26 Oct 2017, 13:30
Yes I got the same experience. Some tinkering gave me a trigger signal but gave me tons of false triggers = I simply tossed that device into my trash bin (to be sorted as electronic waste, just to be clear!). :)
papperone
Re: AM312 mini PIR?
#11 Post by papperone » 26 Oct 2017, 14:18
Maybe I misunderstood but:
  • If you short GPIO to GND the PIN state I can guess will always be LOW (zero).
  • To have a real pull-down you should have a resistor (I normally use 10k) between GND and the GPIO.
bubastic
Re: AM312 mini PIR?
#12 Post by bubastic » 22 Jan 2023, 20:15
Domosapiens wrote: 23 Oct 2017, 19:45 This PIR seems a simplified module of the HC-SR505 PIR sensor.
I use this one:
this module has DC4.5-20V supply voltage ?
If so, then it's inconvenient.
bubastic
Re: AM312 mini PIR?
#13 Post by bubastic » 07 Mar 2023, 00:39
I spent a lot of time, I tried 3 AM312 modules, but they didn't work.
But as soon as I connected the SR602 and lo and behold, everything works.
bidrohini
Re: AM312 mini PIR?
#14 Post by bidrohini » 09 Mar 2023, 16:43
bubastic wrote: 07 Mar 2023, 00:39 I spent a lot of time, I tried 3 AM312 modules, but they didn't work.
I think espeasy supports the SR series only. https://espeasy.readthedocs.io/en/lates ... ensor.html
Re: AM312 mini PIR?
#15 Post by Ath » 09 Mar 2023, 17:10
bidrohini wrote: 09 Mar 2023, 16:43
ESPEasy supports any PIR sensor that provides a high or low output signal when movement is detected, as it is picked up by the Switch plugin that can detect both low- or high-active state.
For PIR sensors outputting an analog signal (probably related to the detection-distance) the Analog input plugin, probably using a voltage divider on the input pin, can be used. That might need some rules to trigger at the desired level.
