How many timers is availabl in each of the 3 rules
And is the timer numbering global across all 3 rules?
Br
Ar
Rule timer
Re: Rule timer
Timers are global.
You can see the rules files as being one concatenated big rules file (except a block of "on ... endon" should be in the same file)
If my memory serves me well, there are 8 timers. At least there used to be, not 100% if I removed that limit.
Re: Rule timer
Good afternoon. how many timers can be put in the rules now? at the moment I am using 8 timers, how many more timers can I set up for the module esp32 to work properly?
Re: Rule timer
The max number of timer at the moment is 256. Not sure what that will do with performance and memory use though, especially on ESP8266
Re: Rule timer
thank you
Users browsing this forum: Google [Bot] and 1 guest
