I run into a problem with one of my projects. In short, my nodo rflink won't talk to NodeMCU. I guess the problem might be in the settings in ESPeasy that's why I've placed it here.
Background and technical stuff:
I've bought at Nodo-shop.nl
- RFLINK 433.92 (v1.1.4f)
- ARDUINO Mega
- ANTENNE
- rflink Wifi bridge v.0.9.2
- NodeMCU
I've flashed the Arduino mega board with the RFlink firmware version 1.48 and the output was amazing in the RFLink Loader. I get clear and fast signals. Now i've flashed NodeMCU with mega-20221224 via the ESP Easy flasher 0.04.007. Before placement on the wifi bridge, I've set it up. And after alter WD=38 setting (watchdog) and a powersource of 9v ESPEasy booted up fast and is stable. But now after the settings in Handleiding NodeMCU V4.pdf I can't get any info from the RFLink to ESPeasy and the values under Devices stays empty. MQTT publish under ESPeasy works. I tried many things but nothing seems to work. Some of the things that i've tried:
- web log level on debug => high logging "WiFi : Set TX power to 14dBm sensitivity: -72dBm RSSI: -66dBm" and toggle "Send With Max TX Power" on
- alter tcp port to different values
- alter baud rate
- alter event processing
- serial Port
- power the arduino with 12v
here some screenprints:
