MQTT point in comma
How can I convert a value 0.18234 to 0.18234 so that I can calculate with it?
MQTT
Re: MQTT
I think you meant "0,18234" as input?
Where do you get this value from?
Is it via MQTT import or via commands and using C005?
Re: MQTT
C005 is the OpenHab/HomeAssistant controller in ESPEasy.
As shown in its documentation, you can also subscribe to topics crafted in such a way that they represent commands for ESPEasy. See: https://espeasy.readthedocs.io/en/lates ... d-handling
As you can also craft commands to generate an event, and the comma is the separator of parameters (called eventvalues in ESPEasy), you could combine those separate eventvalues into a single value.
Ton does have a lot of work recently on the MQTT import plugin, which he also documents very well: https://espeasy.readthedocs.io/en/lates ... #p037-page
I did have a quick look, but right now I can't think of a way how to replace those decimal commas.
Maybe he has some idea...
Re: MQTT
It turned out to be quite easy, just enable the 'Generate events for accepted topics' option in the MQTT Import task and add a rule for your MQTT topic to 'convert' and assign the value like this:
on mqtt/topic/cmd do // Handle the MQTT Topic event from MQTT Import
Let,1,%eventvalue1%.%eventvalue2% // The initial comma separates the values into 2 arguments
LogEntry,'Value: %v1%' // Optional logging of the value
TaskvalueSet,Variables,Dummy1,[var#1] // Assign the value to a Dummy task to be used elsewhere, or immediately use it somewhere else like on a display
Users browsing this forum: Ahrefs [Bot] and 36 guests
