As you may know, I have a number of converted S20s in use.
A few days ago I had a technical problem with my power supply and as a result two S20 and a Shelly plug didn't want to use wifi anymore...
The problem is solved, but I noticed that an S20 always runs at 99% load.
As soon as I remove the rules, the problem goes away. So it must have something to do with the rules...
Hence my question:
Am I doing something here that generates an infinite loop or something like that? I do not find it
on System#Boot do
// Prefill all Data after cold start
TaskValueSet,Taste,BTN,0
TaskValueSet,Sollwert,D,23.0 // Daytime- temperature
TaskValueSet,Sollwert,N,19.0 // Nighttime- temperature
TaskValueSet,Zeiten,Dh,05 // Time to start Day/hour
TaskValueSet,Zeiten,Dm,30 // Time to start Day/minute
TaskValueSet,Zeiten,Nh,22 // Time to start Night/hour
TaskValueSet,Zeiten,Nm,00 // Time to start Night/minute
on Time#Initialized do
// Set Level of Regulator after cold start
if %systime% > [Zeiten#Dh#D2]:[Zeiten#Dm#D2] and %systime% < [Zeiten#Nh#D2]:[Zeiten#Nm#D2]
config,task,Regler,SetLevel,[Sollwert#D]
TaskValueSet,Sollwert,IS,[Sollwert#D]
config,task,Regler,SetLevel,[Sollwert#N]
TaskValueSet,Sollwert,IS,[Sollwert#N]
on Regler#SET do
// Regler ACTIVE && KEY ON || Regler ACTIVE && Regler ON
if [Regler#SET] = 1 or [Taste#BTN] = 1
gpio,12,1
TaskValueSet,Sollwert,IS,[Regler#GetLevel]
// Regler ACTIVE && KEY OFF && Regler OFF
elseif [Regler#SET] = 0 and [Taste#BTN] = 0
gpio,12,0
// Time to switch to over day temperature
on Clock#Time=All,[Zeiten#Dh]:[Zeiten#Dm] do
// Time to switch to over night temperature
on Clock#Time=All,[Zeiten#Nh]:[Zeiten#Nm] do
// LongPress: Toggle the regulator (OFF/AUTOMATIC)
// ShortPress: Toggle between AUTO and ON (ON
on Taste#BTN do
// Regler ACTIVE && KEY Longpress? Regler PASSIVE, RLY OFF
if [Regler#settings.enabled] = 1 and %eventvalue1% > 9
gpio,12,0
TaskDisable,Regler
longpulse_ms,13,1,300,100,-1
// Regler ACTIVE and KEY ON Regler ACTIVE, RLY On
elseif [Regler#settings.enabled] = 1 and %eventvalue1% = 1
gpio,12,1
// Regler ACTIVE and KEY OFF Regler ACTIVE, RLY OFF
elseif [Regler#settings.enabled] = 1 and %eventvalue1% = 0
gpio,12,0
// Regler PASSIVE and KEY Longpress? Regler ACTIVE, RLY OFF
elseif [Regler#settings.enabled] = 0 and %eventvalue1% > 9
gpio,12,0
TaskEnable,Regler
longpulse_ms,13,1,0
// Base system: SONOff S20, 4pin 3,5mm Plug, !! Wire from PE to GND !!
// 10k resistor inside Plug, not in device. GND=GND, Ring 1 = TX, Ring 2 = RX, TIP = +Ub
// DEVICES
// 1 - Switch input - Switch - "Taste#BTN" - GPIO0
// 2 - Switch input - Switch - "Relais#RLY" - GPIO12
// 5 - Regulator - Level Control - "Regler#SET" - Task11
// 8 - Generic - Dummy Device - "Sollwert#D - °C Day tt.t
// 8 - "Sollwert#N - °C Night
// 9 - Generic - Dummy Device - "Zeiten#Dh" - Day Hour
// 9 - "Zeiten#Dm" - Day Minutes
// 9 - "Zeiten#Nh" - Night Hour
// 9 - "Zeiten#Nm" - Night Minutes
// 11 - Environment - DS18b20 - "Sensor#TMP" - either ...
// 12 - Environment - DHT11/12... - "Sensor#TMP" - ... or
// 12 - "Sensor#HUM" -
