my current project is to control my projector UHD370X (manufacturer: Optoma) per remote and to integrate it into my SmartHome automation.
The projector has a serial port (RS232, D-Sub9) which I want to use for that. Unfortunately I didn't found pretty much information about using the "Serial Server" of ESP Easy.
I want to use a "WEMOS D1 Mini", currently flashed with release "ESP_Easy_mega_20230623_normal_ESP8266_4M1M" (Jun 23 2023) and use the hardware serial port "0" (GPIO-3 + GPIO-1).
I connected the WEMOS via a level shifter (Wemos: TTL level, RS232 +/- 15V) to the projector and tried to send a command via MQTT.
I need to send Hex strings like "7E 30 30 31 35 30 20 31 0D" to the projector, it will answer like "4F 6B 30 30 30 30 32 38 30 30 30 43 30 38 30 30 0D".
This works as I tested it before with direct connection from laptop to projector using a serial terminal tool (e.g. "Realterm" or "Hterm").
Now I have serveral problems.
1. Generic - MQTT Import: If data is received it is converted to a float value (MQTT topic 1, value 1). This huge string above can not be converted correctly into an integer value (range overflow). So I tried to send every single byte via an own MQTT message and store it in max. 12 different variables ("Let,3,%eventvalue%" .. "Let,13,%eventvalue%") until all bytes are transmitted. I used twi different MQTT topics for that "Bytewert" - the value to be transmitted (stored in int#1) and "Byteposition" (stored in int#2) to tell the ruIe to which variable the value have to be assigned to. Is there a more comfortable way to handle this?
2. If the last received byte matches "OD" the string is completed and I sent it out via "serialsendmix" command from "Communication - Serial Server", adding each byte from before ("[int#3]" .. "[int#12]"). Since "OD" received via MQTT and convered to integer (0x0D = 13 dec.) before and converting it back to hex for sendig it via the command, the leading "0" of "0D" is lost. Reading back the request above via MQTT for debugging results in "0x7e30303135302031d", as it can be seen, the last "byte" is only "d" instead of "0d". So the string is wrong now and the projector does not understand by request. Is there a possibility to get the leading "0" at the conversation from int to hex? I used "{tohex:[int#3]}".
Rules Set 1:
On MQTT2Serial#Byteposition* do
Let,2,abs(%eventvalue%) // Variable 2 = Byteposition (Variable 1 = Bytewert, siehe RuleSet 2)
If [int#2] = 1
If [int#1] = 0x7E // 1. Byte muss bei valider Anfrage den Wert 0x7E haben
Let,3,[int#1]
Let,15,0
Else
Let,3,0xFF
Let,15,0
Endif
Endif
If [int#2] = 2
Let,4,[int#1]
Endif
If [int#2] = 3
Let,5,[int#1]
Endif
If [int#2] = 4
Let,6,[int#1]
Endif
If [int#2] = 5
Let,7,[int#1]
Endif
If [int#2] = 6
Let,8,[int#1]
Endif
If [int#2] = 7
Let,9,[int#1]
Endif
If [int#2] = 8
Let,10,[int#1]
Endif
If [int#2] = 9
Let,11,[int#1]
If [int#1] = 13
serialsendmix,0x{tohex:[int#3]}{tohex:[int#4]}{tohex:[int#5]}{tohex:[int#6]}{tohex:[int#7]}{tohex:[int#8]}{tohex:[int#9]}{tohex:[int#10]}{tohex:[int#11]}
Publish, %sysname%/debugging,0x{tohex:[int#3]}{tohex:[int#4]}{tohex:[int#5]}{tohex:[int#6]}{tohex:[int#7]}{tohex:[int#8]}{tohex:[int#9]}{tohex:[int#10]}{tohex:[int#11]}
Let,15,1
Endif
Endif
If [int#2] = 10
Let,12,[int#1]
If [int#1] = 13
serialsendmix,0x{tohex:[int#3]}{tohex:[int#4]}{tohex:[int#5]}{tohex:[int#6]}{tohex:[int#7]}{tohex:[int#8]}{tohex:[int#9]}{tohex:[int#10]}{tohex:[int#11]}{tohex:[int#12]}
Let,15,1
Endif
Endif
If [int#2] = 11
Let,13,[int#1]
If [int#1] = 13
serialsendmix,0x{tohex:[int#3]}{tohex:[int#4]}{tohex:[int#5]}{tohex:[int#6]}{tohex:[int#7]}{tohex:[int#8]}{tohex:[int#9]}{tohex:[int#10]}{tohex:[int#11]}{tohex:[int#12]}{tohex:[int#13]}
Let,15,1
Endif
Endif
If [int#2] = 12
Let,14,[int#1]
If [int#1] = 13
serialsendmix,0x{tohex:[int#3]}{tohex:[int#4]}{tohex:[int#5]}{tohex:[int#6]}{tohex:[int#7]}{tohex:[int#8]}{tohex:[int#9]}{tohex:[int#10]}{tohex:[int#11]}{tohex:[int#12]}{tohex:[int#13]}{tohex:[int#14]}
Let,15,1
Endif
Endif
If [int#15] = 1
Let,1,255
Let,2,0
Let,3,255
Let,4,255
Let,5,255
Let,6,255
Let,7,255
Let,8,255
Let,9,255
Let,10,255
Let,11,255
Let,12,255
Let,13,255
Let,14,255
Let,15,0
Endif
On MQTT2Serial#Bytewert* do
Let,1,abs(%eventvalue%)
On !Serial#* do
Publish, %sysname%/serial, {substring:8:25:%eventvalue%}
Devices:
Serial Server Setup:
MQTT Setup:
MQTT debugging message:
Thanks a lot for your help and investigations!
Best regards,
Sebastian
