How to control Wave Design extractor hood from Home Assistant?
bbccdd
#1 Post by bbccdd » 18 Sep 2023, 13:17
Hi all. I'm new here.
As a user of home assistant using an RFlink device at firmware R48
I'd like to control my [supposedly supported] Wave Design extractor hood
a) to see when it is in a turned on state
b) to turn it off
So that I can see when it is turned on in home assistant as a basis for further automations.
I have created home assistant entities for each of the relevant button presses but they do not control the extractor hood. Nor does a button press change the state of an entity in home assistant.
Please support with troubleshooting!
Home assistant configuration.yaml
# https://www.rogerfrost.com/how-to-use-many-more-of-your-433mhz-devices-using-rflink-and-integrate-them-with-home-assistant/
rflink:
  # find by monitoring supervisor log while plugging usnmb in. need passthrough
  port: /dev/serial/by-id/usb-Arduino__www.arduino.cc__Arduino_Mega_2560_852353330353515052F0-if00
  wait_for_ack: false
light:
  - platform: rflink
    automatic_add: false
    devices:
      bosch_788d_0:
sensor:
  - platform: rflink
switch: # does not support auto add.
  #Use the log viewer to see what happens and add manually OR set light and sensor auto add to true and cleanup later in entities.
  - platform: rflink
    devices:
      bosch_788d_1:
        aliases:
          - aster_bosch_788d_1
      bosch_788d_2:
        aliases:
          - aster_bosch_788d_2
It seems to be supported for a while now already.
Changelog:
R44:
- New Device: Siemens SF-01 and compatible ventilation units
- New Device: Wave Design SF-01 and compatible ventilation units
bidrohini
Re: How to control supported Wave Design extractor hood from Home Assistant?
#2 Post by bidrohini » 19 Sep 2023, 10:54
The only resource I found regarding extractor hood is this one: https://community.home-assistant.io/t/i ... d/422219/7
I hope the admins will come forward to troubleshoot your code.
bbccdd
#3 Post by bbccdd » 19 Sep 2023, 11:17
Thanks for that link. Indeed, I could use various means to detect cooking. However 1) I'd like to use RFlink because I think it is cool (and this is its first application) and 2) I'd like the ability to turn off the extractor hood from home assistant.
