The Thermosensors plugin does not work
- Andrew Mamohin
The Thermosensors plugin does not work with the MAX6675 module in version ESP_Easy_mega_20230930 for S2.
The temperature is always equal NAN.
When I flash version 20230822 the plugin works fine.
Andy.
Re: The Thermosensors plugin does not work
How is SPI configured?
I assume you've checked the wiring 3 times? (like I usually do if something won't work as expected)
- Andrew Mamohin
Hi!
Yes, I checked. This device has been working for some time on the firmware 20230822. I tried several times to flash firmware 20230930, but I always get nan.
And now the device works well on 20230822.
Andy.
Which exact build are you using? (filename)
I did remove quite a lot of "excessive logs" etc. from that plugin and wrapped it in "#ifndef BUILD_NO_DEBUG" or "#ifndef LIMIT_BUILD_SIZE"
So it might be possible there was something done in such log-only code blocks. But that would probably have been a bug anyway as those would then not be executed if log level was not set.
Have to check the code changes to be sure.
Can you check this PR when it is ready building?
https://github.com/letscontrolit/ESPEasy/pull/4836
GH Actions build: https://github.com/letscontrolit/ESPEas ... 6389659984
- Andrew Mamohin
Yes! This build works. Thank you! You fix bugs amazingly quickly!
Andy.
Sadly not as quick as I write them... ![Knipoog ;)](./images/smilies/icon_e_wink.gif)
