Nice housing or ready made with good WAF
HomeJCL
#1 Post by HomeJCL » 10 Jan 2022, 19:28
Just found this, readymade setup https://www.kincony.com/kc868-uair-esp ... eased.html with ESP32
Or also interesting the housing (naked) https://www.aliexpress.com/item/330406 ... 6c37034tAs most interesting not limited to their specific print size, both shells have 4 studs for screw fixing of prints
Very high WAF factor : :twisted:
Re: Nice housing or ready made with good WAF
#2 Post by TD-er » 10 Jan 2022, 21:23
Looks really nice indeed.
And also the enclosure looks quite good. Too bad it has openings for mini USB, but that's probably why it is so cheap :)
Too bad they don't list it with ESPEasy... https://www.aliexpress.com/item/1005003740881856.html
vincen
#3 Post by vincen » 14 Mar 2022, 09:58
My advice is to stay away of that device ! Have one here and it's chinese bad design :(
  • One of the ring/base LED is wired with bar LED which kills the visual effect of product
  • Temperature sensor inside is not an original Dallas temp sensor (4/5° offset with my other sensors aronud !).
  • support of manufacturer is very bad.
jgrad
#4 Post by jgrad » 13 Nov 2023, 10:35
have anybody sucessfully installed ESP32 version of ESPEASY on this board?
This board is interesting for me as "ready made of-the-shelf HW" with digital I/O and wired Ethernet.
#5 Post by TD-er » 13 Nov 2023, 10:39
I have not, but seems like all onboard except for the RF modules should work just fine.
#6 Post by Ath » 13 Nov 2023, 11:19
jgrad wrote: 13 Nov 2023, 10:35 This board is interesting for me as "ready made of-the-shelf HW" with digital I/O and wired Ethernet.
Not sure where you have found the wired Ethernet connection, I can only see 2 mini-USB connectors installed :?
And AFAICS, the available GPIO pins don't allow for an Ethernet module to be connected, as some of the required/fixed ETH GPIOs are in use by other things.
jgrad
#7 Post by jgrad » 13 Nov 2023, 11:27
sorry, not same board. I was looking for this board
https://www.kincony.com/kc868-a8-hardwa ... tails.html
vincen
#8 Post by vincen » 13 Nov 2023, 11:46
jgrad wrote: 13 Nov 2023, 11:27 sorry, not same board. I was looking for this board
That one works really well with ESPHome so it should be all good with ESPEasy too ;) I have quite a few installed at some customers !
jgrad
#9 Post by jgrad » 13 Nov 2023, 12:45
@vincen
thanks for feedback - I ordered one to try first device with wired ethernet in combination with ESPeasy.
#10 Post by Ath » 13 Nov 2023, 13:04
Ah, ok, indeed, all except the 433 MHz sub-boards seem to be supported. I do have support for such 433 MHz boards on my TODO list though... ;)
