Constants in Rules
Burberius
Constants in Rules
#1 Post by Burberius » 24 Nov 2023, 22:31
I have a little sensor module that sends its values to some http service as a given time.
I use rules for that but the "code" doesn't look that nice. I would prefere to define the apikey of the http service and also the execution time at the beginning of the rules to make it easier to configure/change them.
Something like:
def apikey=abc123
def sendtime=07:00
On Clock#Time=All,%sendtime% do
  SendToHTTP www.pushsafer.com,80,/api?k=%apikey%&i=81&t=%sysname%%20Status&m={urlencode:"Temperature [Sensor#Temperature]°C Humidity [Sensor#Humidity]% Dew Point %c_dew_th%([Sensor#Temperature],[Sensor#Humidity])°C at time: %lcltime%"}
Is that somehow possible?
Bye, Burb
Re: Constants in Rules
#2 Post by TD-er » 24 Nov 2023, 22:37
You can use the command 'let' to store variables and then access them via [int#N] or [var#N] to access variable nr N.
But those can only be numerical, not a string.
Burberius
#3 Post by Burberius » 28 Nov 2023, 18:40
Is there a possibility to get the name of a value from a dummy controller?
Then I could create a controller apikey and set the key as the value name.
chromo23
#4 Post by chromo23 » 28 Nov 2023, 19:49
Burberius wrote: 28 Nov 2023, 18:40 Then I could create a controller apikey and set the key as the value name.
But why not making then for every API a sperate entry and just set a number? e.g.:
let,1,1
Like
On Clock#Time=All,[var#2]:[var#3] Do // I can´t remember if this worked but i think so...
 If [var#1]=1
  SendToHTTP www.pushsafer.com,80,/api?k=<key1>...
 Elseif [var#1]=2
  SendToHTTP www.pushsafer.com,80,/api?k=<key2>...
 Elseif [var#1]=3
  SendToHTTP www.pushsafer.com,80,/api?k=<key3>...
 Elseif [var#1]=4
  SendToHTTP www.pushsafer.com,80,/api?k=<key4>...
 Elseif [var#1]=5
  SendToHTTP www.pushsafer.com,80,/api?k=<key5>...
 Endif
#5 Post by TD-er » 28 Nov 2023, 22:19
Burberius wrote: 28 Nov 2023, 18:40 Is there a possibility to get the name of a value from a dummy controller?
You mean like this: https://espeasy.readthedocs.io/en/lates ... r-eventpar
