mqtt cpu load
mqtt cpu load
I'm attempting to use mqtt to send a switch state, and it works fine.
However, if the remote Broker is offline when the esp boots, the load goes to 100% if the mqtt controller is enabled.
Also seen on a regular esp-32.
Any way to stop this happening?
Re: mqtt cpu load
There seems to be an issue with the http-client library, that it keeps polling if the connection is lost, causing high CPU-load. It's not yet clear if we can do something about that.
Re: mqtt cpu load
Thanks for responding, I just wanted to make sure that I wasn't doing something silly...
It shouldn't normally be a problem.
![Knipoog ;)](./images/smilies/icon_e_wink.gif)
Re: mqtt cpu load
Well if it isn't a problem, then please do something sillyseersucker wrote: ↑02 Dec 2023, 21:34 Thanks for responding, I just wanted to make sure that I wasn't doing something silly...![]()
Users browsing this forum: Ahrefs [Bot] and 0 guests
