Espeasy relay after reboot is on.
nobody@all
#1 Post by nobody@all » 11 Dec 2023, 00:58
Hello.
Using espeasy mega-20231130, I have added devices : Switch and relay and servo.
1) Device config is:
Switch input - Switch
Name -switch
Internal pullup - marked
Gpio 12
switch type: switch
Switch button type: Push button active low
debounce 50ms.
2)Device config is:
Switch input - switch
Name -Relay
Gpio 13
switch type: switch
Switch button type: normal switch
Rules looks like:
On System#Boot do
  Servo,1,2,0
  GPIO,13,0
On Switch#State Do
 if [Switch#State]=1
  Servo,1,2,180
  gpio,13,1
  Servo,1,2,0
  GPIO,13,0
EndOn
When I power on espeasy state of switch and relay is 1.
What do I don't understand? When system boot i want to have relay and switch 0
Re: Espeasy relay after reboot is on.
#2 Post by TD-er » 11 Dec 2023, 08:55
I don't think you need to have a second task for the relay.
If you only act on it via the gpio commands then having a task for it is no longer needed.
N.B. You can also set the boot state of the pin on the hardware tab.
#3 Post by Ath » 11 Dec 2023, 10:08
Using the Internal Pull-up option is supposed to pull the pin to high level, so that's probably not the best use in your situation.
#4 Post by TD-er » 11 Dec 2023, 11:54
Yeah, but that should only be affecting this when used as an input.
I can have a look at the code to see if setting the pull-up active actually changes the GPIO mode to input.
Then it would explain the current behavior.
Users browsing this forum: Bing [Bot] and 1 guest
