New here, thank you for this board
So, I bought the Nodo 868.3 MHz RFLink Gateway :
https://www.nodo-shop.nl/en/rflink-/168 ... kabel.html
With soldering service, so that everything is made properly.
It runs firmware 1.1 R50.
I also bought TFA Temperature/humidity Transmitter 30.3180 (especially for its precision Sensirion SHT30 sensor) :
https://www.tfa-dostmann.de/en/product/ ... r-30-3180/
Transmission frequency is 868 MHz as per its technical data, also as per its instruction manual (every 10 seconds).
Perfect.
When I use RFLink Loader in Serial Port Logging mode, Debug on, I see DEBUG Pulses lines from time to time.
Seems then my RFLink Gateway receives "things". I even captured a door bell
But no line seems to correspond to my TFA transmitter
Its transmission icons blinks every 10 seconds, but the Arduino LED does not blink at the same time / does not blink at all.
And of course no corresponding debug line showing at the same time in RFLink Loader.
I tried many things such as :
- flashing the RFLink firmware again
- playing with the TFA transmitter batteries
- replacing Nodo antenna with a 86mm wire
- tested both R48 and R50 firmwares
But I can't manage to have a RFLink debug line every 10 seconds...
Did I miss something ?
Thank you very much for your help !
