I'm using a ESP12 with R78 to monitor my power and gas meter.
Power is connected to GPIO-13 and the gas to GPIO-16.
Power is working well and today I added the gas counter hardware, strangely enough the gas counter doesn't work.
The signal arrives at the ESP12 (0 or 5 volt) but it is not counted.
Interesting detail is that when I make it a switch input, the signal is detected by the ESP12 but not when using it as a counter.
https://www.dropbox.com/s/8o0meflrxk4pr ... 2.png?dl=0
Any thoughts ?
-ben
pulscount issue on R78
Re: pulscount issue on R78
Are you sure about the 5V ? This will kill the ESP, max 3.3V
Yes correct, but why does it work with switch input ?
But I will make it 3.3V to see if this solves the problem.
-ben
-ben
Changed it to 3.3 volt, no difference.
Works well with switch input but NOT with counter!
Could it be related to GPIO-16 port ?
-ben
-ben
Moved signal to GPIO-4, problem solved.
Cannot explain, anyone else ?
-ben
-ben
There are bugs in the counter plugin. I couldn't get formulas to work
The GPIO16, can not be used for Interrupt driven puls counts.
It is an issues of the ESP8266, see esp data sheet.
Users browsing this forum: Bing [Bot] and 14 guests
