INEL blinds-shutters not supported
vincentfr1515
#1 Post by vincentfr1515 » 12 Sep 2024, 13:50
Hello and a big thanks to the team for their hard work.
I have two INEL shutters that don’t seem to be recognized by RFLINK. Here are some resources about the product:
https://www.inel.gda.pl/en/
https://www.inel.gda.pl/images/pliki/ma ... 1PM_EN.pdf
The remotes transmit a 433 MHz signal. The code from DEBUG mode is attached below. It appears that the code is not consistent, I recorded it twice for each button.
I hope you can implement support for these in RFLINK!
Remote 1 – UP – Try1
20;04;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,330,300,300,300,3930,720,300,720,300,720,300,300,690,300,690,300,690,720,300,720,300,300,720,720,300,300,690,300,690,300,690,300,720,300,690,300,720,720,300,720,300,300,720,300,690,300,690,720,300,300,720,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,330,300,690,720,300,300,690,720,300,720,300,720,300,300,720,300,690,300,690,300,720,720,300,720,300,720,300,330,690,300,720,720,300,300,690,720,300,300,690,720,300,330,720,300,690,720,300,720,300,720,300,720,300,720,330,720,300,720,300,720,300,300,690,300,720,300,690,300,720,300,690,300,690,300,6990;
20;05;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,300,270,300,300,300,300,270,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,690,300,690,300,720,720,300,720,300,300,690,720,300,300,690,300,690,300,720,300,720,300,690,300,690,720,300,720,300,300,720,300,720,300,690,720,300,300,690,720,300,300,720,300,690,330,690,300,690,720,300,720,300,720,300,720,300,300,720,300,690,300,690,300,720,720,300,720,300,300,690,720,300,690,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,690,690,300,300,720,720,300,300,690,720,300,300,720,300,690,720,300,720,330,720,300,720,300,720,300,720,300,720,300,720,300,300,720,300,720,300,720,300,690,300,690,300,690,300,6990;
20;06;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,270,300,300,270,300,270,300,300,300,300,300,300,300,300,330,300,300,3930,690,300,720,300,720,330,300,690,300,690,300,690,720,300,720,300,300,720,720,300,300,690,300,690,300,690,300,720,300,720,300,690,720,300,720,300,300,690,300,720,300,690,720,300,300,690,720,300,300,690,300,720,300,690,300,690,720,300,720,330,720,300,720,300,300,690,300,690,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,330,690,720,300,300,690,720,300,720,300,720,300,300,690,330,690,300,690,300,720,720,300,720,300,720,300,300,720,300,690,720,300,300,690,720,300,300,690,720,300,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,330,690,300,690,300,6990;
20;07;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,270,300,300,270,300,300,300,300,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,720,300,690,300,690,720,300,720,300,300,720,720,300,300,690,300,690,300,690,330,690,300,720,300,690,720,300,720,300,300,690,300,720,300,720,720,300,300,690,720,300,300,690,300,720,300,720,300,690,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,330,720,300,720,300,300,690,300,690,300,690,300,690,720,330,720,300,720,300,300,690,300,690,720,300,300,720,720,300,300,690,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,330,690,300,720,300,720,300,690,300,690,300,6990;
20;08;DEBUG;Pulses=182;Pulses(uSec)=390,300,270,300,270,270,300,270,300,300,270,300,300,300,300,300,300,300,300,300,330,3930,720,300,720,300,720,300,330,720,300,690,300,690,720,300,690,300,300,690,720,300,330,690,300,690,300,690,300,690,300,720,300,720,720,330,720,300,300,690,300,690,300,720,720,300,300,690,720,300,300,690,300,690,300,720,300,690,720,300,720,300,720,300,720,300,300,690,300,690,300,690,300,690,690,300,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,720,720,300,300,690,720,300,300,690,330,690,720,300,720,300,720,300,720,300,720,300,720,330,720,300,720,300,300,690,300,690,300,690,300,720,300,720,300,690,300,6990;
Remote 1 – UP – Try2
20;09;DEBUG;Pulses=182;Pulses(uSec)=390,300,330,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,720,300,690,720,300,720,330,300,690,300,720,720,300,300,690,300,690,720,300,720,300,300,720,300,690,720,300,300,690,720,300,300,690,330,720,720,300,300,690,720,300,720,300,300,720,720,330,300,690,300,690,300,690,300,690,300,720,720,300,720,330,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,330,720,300,720,720,300,720,300,720,300,300,690,300,720,720,300,300,690,720,300,300,690,720,300,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,300,690,300,720,300,6990;
20;0A;DEBUG;Pulses=182;Pulses(uSec)=510,270,300,300,270,300,300,270,300,270,300,300,300,330,300,300,300,300,300,300,300,3930,720,330,300,720,720,300,720,300,720,300,720,300,720,300,300,720,300,690,720,300,720,300,300,690,300,690,720,300,300,720,300,690,720,300,720,300,300,720,300,690,720,300,330,690,720,300,300,690,300,720,720,300,300,690,720,330,720,300,300,720,720,300,300,690,300,690,300,690,300,720,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,330,720,300,300,690,300,720,720,300,300,690,720,300,300,720,720,300,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,330,690,300,690,300,690,300,690,300,6990;
20;0B;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,270,300,300,270,300,270,270,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,720,300,690,720,300,720,300,330,690,300,690,720,300,300,690,300,690,720,300,720,300,330,720,300,720,720,300,300,690,720,300,300,690,300,720,720,300,300,690,720,300,720,300,300,690,720,300,300,720,300,690,300,690,300,690,300,720,720,300,720,300,330,690,720,300,720,300,720,300,720,300,300,690,720,300,330,690,720,300,720,300,720,300,300,690,300,690,300,720,300,720,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,300,690,720,300,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,300,690,300,720,300,6990;
20;0C;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,270,300,270,300,270,300,300,330,300,300,300,300,300,300,3930,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,690,330,720,720,300,720,300,300,690,300,690,720,300,300,720,300,690,720,300,720,300,300,690,300,720,720,300,300,720,720,300,300,690,300,690,720,300,300,690,720,300,720,300,300,690,720,300,300,720,300,690,300,690,300,690,330,690,720,300,720,300,300,690,720,300,720,300,720,330,720,300,300,690,720,300,300,690,720,300,720,300,720,330,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,720,300,300,690,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,720,300,690,300,690,300,6990;
20;0D;DEBUG;Pulses=182;Pulses(uSec)=330,300,300,270,300,300,300,270,270,300,300,270,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,690,300,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,300,720,300,690,720,300,300,690,300,720,720,300,720,300,300,720,300,690,720,300,300,720,720,300,300,690,300,690,720,300,300,720,720,300,720,300,300,690,720,300,300,690,330,690,300,690,300,690,300,690,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,720,720,300,300,720,720,300,720,300,720,300,300,720,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,690,720,300,330,690,720,300,300,690,720,300,300,690,300,690,720,330,720,300,720,300,720,300,720,300,720,300,720,300,720,330,300,690,300,690,300,690,300,690,300,720,300,690,300,6990;
Remote 1 – DOWN – Try1
20;13;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,330,300,3930,300,690,720,300,300,690,330,690,720,300,300,690,720,300,720,300,300,690,720,330,720,300,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,300,690,720,300,720,300,720,300,300,690,720,300,300,690,720,300,330,690,300,690,300,690,300,690,300,690,300,720,720,330,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,720,300,720,720,300,720,300,720,300,300,690,330,690,720,300,300,690,720,300,720,300,300,690,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,300,720,300,690,300,6990;
20;14;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,300,270,300,300,270,300,270,300,270,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,690,300,690,720,300,300,690,720,330,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,300,690,720,300,720,300,720,300,300,720,720,300,300,690,720,300,300,690,300,690,300,690,300,720,300,690,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,720,720,300,300,690,720,330,720,300,300,690,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,300,690,300,690,300,6990;
20;15;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,270,300,270,270,300,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,720,300,720,720,300,300,690,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,720,720,300,300,690,300,690,720,330,720,300,720,300,300,690,720,300,300,690,720,300,300,720,300,690,300,690,300,690,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,690,720,300,720,300,300,690,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,300,690,330,690,300,6990;
20;16;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,270,300,270,300,270,270,300,300,270,300,300,300,300,300,300,300,300,300,3930,300,720,720,300,300,690,300,720,720,300,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,330,300,690,300,690,720,300,720,300,720,300,300,720,720,300,300,690,720,300,300,690,300,720,300,690,300,690,300,720,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,330,720,300,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,720,300,720,300,300,690,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,720,300,690,300,690,300,6990;
20;17;DEBUG;Pulses=182;Pulses(uSec)=330,270,300,270,300,270,300,300,270,270,300,270,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,690,300,690,720,300,300,690,720,300,720,300,300,690,690,300,720,330,720,300,720,300,300,690,720,300,720,300,720,300,720,330,720,300,300,690,690,300,300,720,300,690,720,300,720,300,720,300,300,690,720,300,300,690,720,300,300,690,330,690,300,720,300,720,300,690,300,690,720,300,720,300,330,720,720,300,720,300,720,300,720,300,300,690,720,330,300,690,720,300,720,300,720,300,300,720,300,720,300,720,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,300,690,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,330,720,300,300,690,300,690,300,690,300,690,300,720,300,720,300,6990;
Remote 1 – DOWN – Try2
20;1D;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,300,300,300,300,300,330,300,300,300,300,300,300,300,3930,720,330,720,300,720,300,300,690,720,300,300,690,720,300,300,720,720,300,300,690,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,330,300,690,720,300,300,720,720,300,300,690,300,690,300,720,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,720,720,300,300,690,720,300,720,330,300,690,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,330,690,300,690,300,690,300,690,300,6990;
20;1E;DEBUG;Pulses=182;Pulses(uSec)=330,300,270,300,270,300,300,270,300,270,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,690,720,300,300,690,720,300,300,720,720,300,300,690,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,330,720,300,720,300,690,720,300,720,300,720,300,720,330,720,300,720,300,720,300,300,690,720,300,300,720,720,300,300,690,300,690,300,690,300,720,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,690,720,300,330,690,720,300,720,300,720,300,300,690,300,690,300,720,300,720,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,300,690,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,300,690,300,720,300,6990;
20;1F;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,270,300,300,270,300,270,300,300,300,300,330,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,690,720,300,300,690,720,300,300,690,720,300,300,690,300,690,720,300,720,300,720,300,720,330,300,690,720,300,300,690,300,690,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,720,720,300,300,720,720,300,300,690,300,690,300,690,330,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,330,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,330,690,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,300,690,300,690,300,6990;
20;20;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,300,300,270,300,300,270,300,300,300,300,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,720,720,300,330,690,720,300,300,690,720,300,300,720,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,300,720,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,330,690,300,690,300,690,300,690,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,690,720,300,300,720,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,690,720,300,330,720,720,300,720,300,300,690,300,690,300,690,720,330,720,300,720,300,720,300,720,300,720,300,720,300,720,330,300,690,300,690,300,690,300,720,300,690,300,690,300,6990;
20;21;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,270,300,300,270,300,300,300,300,300,330,300,300,300,300,3930,720,300,720,330,720,300,300,720,720,300,300,690,720,300,300,690,720,330,300,720,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,300,720,300,690,300,690,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,330,690,300,690,720,300,300,720,720,300,720,300,300,720,300,690,300,690,720,300,720,300,720,300,720,300,720,330,720,300,720,300,720,300,300,690,300,690,300,690,300,720,300,690,300,690,300,6990;
Remote 1 – STOP – Try1
20;22;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,330,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,300,720,720,300,720,300,330,690,720,300,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,300,690,720,300,300,690,300,720,300,690,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,300,690,300,720,300,720,300,690,330,690,300,690,300,690,720,300,720,300,300,690,720,330,720,300,720,300,720,300,300,690,720,300,300,690,720,330,720,300,720,300,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,330,690,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,720,300,690,300,720,300,690,300,690,300,690,300,6990;
20;23;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,270,300,300,270,270,300,270,300,300,300,300,300,300,300,300,300,330,300,3930,720,300,300,690,720,300,330,720,720,300,720,300,300,690,720,300,720,300,720,330,720,300,720,300,300,690,720,300,720,300,720,300,300,720,720,300,300,690,300,720,300,690,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,300,690,330,720,300,720,300,690,300,690,300,690,300,690,720,330,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,330,690,720,300,300,720,300,690,720,300,720,300,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,330,720,300,720,300,300,690,300,690,300,720,300,690,300,720,300,690,300,6990;
20;24;DEBUG;Pulses=182;Pulses(uSec)=390,300,270,300,270,270,300,270,300,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,300,720,720,300,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,300,690,720,300,300,690,300,720,330,720,720,300,720,300,720,300,720,300,300,720,720,330,720,300,720,300,300,690,300,690,300,720,300,690,300,720,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,300,720,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,720,300,720,300,690,300,690,300,6990;
20;25;DEBUG;Pulses=182;Pulses(uSec)=360,300,300,300,270,270,300,270,300,300,270,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,300,690,720,300,300,690,300,690,300,720,720,300,720,300,720,330,720,300,300,720,720,300,720,300,720,300,300,690,300,720,300,720,300,690,300,690,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,720,300,690,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,690,300,720,300,690,330,690,300,6990;
20;26;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,300,270,300,270,270,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,300,690,720,300,300,690,300,690,300,720,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,300,690,300,720,300,690,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,330,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,690,300,720,720,300,720,300,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,300,720,300,690,300,6990;
Remote 1 – STOP – Try2
20;27;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,330,300,300,300,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,720,300,300,690,720,300,720,330,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,720,300,330,690,720,300,300,690,720,300,300,690,720,300,300,690,330,690,300,720,300,690,720,300,720,300,300,690,720,330,720,300,720,300,720,300,300,690,720,300,300,720,720,300,720,300,720,300,300,690,300,690,300,720,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,690,330,690,720,300,720,300,300,690,300,690,720,300,720,330,720,300,720,300,720,300,720,300,720,300,720,300,300,720,300,720,300,690,300,690,300,690,300,690,300,6990;
20;28;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,300,270,300,270,270,300,270,300,270,300,300,300,300,300,300,300,330,300,3930,300,690,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,720,300,300,690,720,300,720,300,300,690,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,720,300,300,690,720,300,300,690,720,330,300,690,720,300,300,690,300,690,300,720,300,720,720,330,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,690,330,690,300,720,300,690,720,300,720,300,720,300,300,690,330,720,720,300,300,690,300,690,720,300,720,300,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,330,690,300,690,300,6990;
20;29;DEBUG;Pulses=182;Pulses(uSec)=360,300,300,300,300,270,300,300,300,270,300,300,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,720,300,300,690,720,300,720,300,330,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,720,300,300,720,720,300,300,690,720,300,300,720,720,300,300,690,300,720,300,690,300,720,720,300,720,300,300,690,690,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,330,720,300,720,300,300,690,300,720,720,300,300,690,300,720,720,300,720,300,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,330,720,300,720,300,690,300,690,300,690,300,6990;
20;2A;DEBUG;Pulses=182;Pulses(uSec)=330,300,270,300,300,270,300,270,270,270,300,300,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,720,300,720,300,690,300,690,720,300,720,300,720,300,720,300,330,690,720,300,720,300,300,720,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,690,300,690,720,330,720,300,720,300,300,690,720,300,300,690,720,300,300,720,720,300,300,690,300,690,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,690,300,690,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,300,720,300,690,300,6990;
20;2B;DEBUG;Pulses=182;Pulses(uSec)=330,300,270,300,300,270,300,270,300,300,270,300,300,300,300,300,300,300,300,300,300,3930,300,720,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,720,300,300,690,720,300,720,300,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,720,300,300,720,720,300,300,690,720,300,300,690,720,300,300,690,300,690,330,690,300,690,720,300,720,300,300,690,720,300,720,330,720,300,720,300,300,690,720,300,300,690,720,300,720,330,720,300,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,300,690,720,300,720,300,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,720,300,690,300,690,300,6990;
vincentfr1515
Re: INEL blinds-shutters not supported
#2 Post by vincentfr1515 » 12 Sep 2024, 14:06
Remote 2 , UP , Try 1
20;33;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,330,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,720,300,720,300,720,300,300,690,330,690,720,300,720,300,300,690,330,690,720,300,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,300,690,300,720,300,690,300,720,300,690,720,300,300,720,300,690,720,300,720,300,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,330,300,690,720,300,720,300,720,300,330,690,300,720,300,720,330,690,720,300,720,300,720,300,300,690,330,690,720,300,330,690,720,300,300,720,720,300,330,690,330,690,720,300,720,300,720,300,720,300,720,300,720,300,720,330,720,300,300,690,300,690,330,690,330,690,300,690,300,720,300,6990;
20;34;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,270,300,300,300,270,300,270,300,270,300,300,330,300,300,300,300,300,300,3930,720,300,330,690,720,300,720,300,720,300,720,300,300,690,300,720,720,300,720,300,300,690,300,720,720,300,720,300,720,330,720,300,720,300,300,690,720,300,720,300,720,300,330,720,300,690,300,690,300,690,330,690,720,300,300,690,330,690,720,300,720,300,720,300,720,300,720,300,300,690,330,690,720,300,300,690,720,300,720,300,720,300,720,330,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,330,690,720,300,300,720,720,300,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,330,690,330,690,300,690,300,6990;
20;35;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,270,300,300,270,300,300,270,300,270,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,720,300,720,330,720,300,300,690,300,690,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,300,690,300,690,300,690,300,690,330,690,720,300,300,720,300,720,720,300,720,300,720,330,720,300,720,300,300,690,330,690,720,300,330,690,720,330,720,300,720,300,720,300,720,300,330,690,720,300,300,720,720,300,720,300,720,300,330,690,300,720,300,690,330,690,720,300,720,300,720,300,300,720,300,690,720,300,330,690,720,300,300,720,720,300,300,690,330,690,720,330,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,330,690,300,690,330,690,300,720,330,6990;
20;36;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,270,300,300,300,270,300,270,300,270,300,300,300,300,330,300,300,300,300,3930,720,300,300,720,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,300,690,330,690,300,690,330,690,300,690,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,300,690,300,720,720,300,300,690,720,300,720,300,720,300,720,300,720,300,330,690,720,300,300,690,720,300,720,300,720,300,330,690,300,690,300,690,330,690,720,300,720,300,720,330,300,690,300,690,720,300,300,690,720,300,300,720,720,330,300,690,330,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,690,330,690,300,690,300,720,300,6990;
20;37;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,270,300,270,300,270,300,300,300,270,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,720,300,720,300,720,300,300,720,300,690,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,300,690,330,690,300,690,300,690,330,720,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,300,690,300,690,720,300,330,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,330,690,300,690,300,720,720,300,720,300,720,300,300,720,300,690,720,300,300,720,720,300,330,690,720,300,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,330,720,300,690,300,690,300,690,300,690,300,690,300,6990;
Remote 2 , UP , Try 2
20;38;DEBUG;Pulses=69;Pulses(uSec)=120,180,60,180,60,150,90,180,60,180,30,180,30,180,30,180,30,180,30,180,30,180,60,180,30,180,30,180,60,180,30,180,450,600,60,180,450,600,30,180,30,180,30,180,30,180,30,180,30,390,30,180,30,180,240,180,30,180,30,180,60,180,30,180,30,120,90,180,30;
20;39;DEBUG;Pulses=180;Pulses(uSec)=390,300,330,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,720,300,690,300,690,300,720,300,690,300,720,720,300,720,300,300,690,690,300,720,300,690,300,300,690,720,300,720,300,300,690,690,300,720,300,720,300,720,300,690,300,300,690,300,720,720,300,720,300,300,690,300,690,690,300,690,300,690,300,720,330,690,300,720,300,300,720,300,720,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,720,720,300,720,300,720,300,300,690,300,690,300,720,330,690,720,300,720,300,720,300,300,690,300,720,690,330,300,690,720,300,300,690,690,300,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,690,300,720,300,300,720,300,720,300,690,300,690,300,690,300,690,330,6990;
20;3A;DEBUG;Pulses=180;Pulses(uSec)=360,300,270,300,270,270,300,300,300,300,300,300,300,330,300,300,300,300,300,3930,720,300,300,720,300,690,300,690,300,690,300,690,300,720,690,300,720,300,300,690,690,300,690,300,690,300,300,690,720,300,720,300,300,690,690,300,720,300,720,300,720,300,690,330,300,690,300,720,720,300,720,300,300,690,300,690,690,330,720,300,720,300,720,300,690,300,690,300,300,690,300,720,690,300,300,690,690,300,690,300,690,300,690,300,720,300,300,690,720,300,300,690,690,300,690,300,720,300,330,690,300,690,300,720,300,720,690,300,720,300,720,330,300,690,300,720,690,300,300,690,690,300,300,690,720,300,300,720,300,690,720,300,690,300,720,300,720,300,720,300,720,300,720,300,690,300,300,690,300,720,300,690,330,690,300,690,300,690,300,6990;
20;3B;DEBUG;Pulses=180;Pulses(uSec)=360,300,270,300,300,270,300,300,300,300,300,300,300,300,300,300,300,300,300,3930,690,300,300,720,300,720,300,690,300,690,330,690,300,690,690,300,720,300,300,690,690,300,720,300,720,300,300,720,690,300,720,300,300,690,690,300,720,330,690,300,720,300,720,300,300,690,300,690,690,300,720,300,300,690,300,690,720,300,690,300,690,300,720,300,720,300,720,300,300,690,300,720,720,300,300,690,690,300,720,300,720,300,690,300,690,300,300,690,720,300,300,720,720,300,690,300,720,300,300,690,300,690,300,690,300,720,690,300,720,300,720,300,300,690,300,720,690,300,300,720,720,300,300,690,690,300,300,720,300,690,720,300,720,300,690,300,690,300,690,300,720,300,720,300,690,330,300,690,300,720,300,690,300,690,300,690,300,690,300,6990;
20;3C;DEBUG;Pulses=182;Pulses(uSec)=390,300,270,270,270,300,300,270,300,300,300,300,300,300,300,300,300,330,300,300,300,3930,720,300,300,690,330,690,300,690,300,690,300,690,300,690,720,300,720,330,300,690,720,300,720,300,720,300,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,720,330,690,720,300,720,300,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,330,690,720,300,720,300,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,330,720,300,690,720,300,300,690,720,300,300,690,720,300,330,690,300,720,720,300,720,300,720,300,720,300,720,330,720,300,720,300,720,300,300,690,300,690,300,690,300,720,300,690,300,690,300,6990;
20;3D;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,270,300,300,270,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,300,690,300,720,300,690,300,720,300,690,720,300,720,300,300,690,720,300,720,300,720,330,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,330,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,720,300,330,690,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,720,300,690,300,690,300,720,300,690,300,690,300,6990;
Remote 2 , DOWN , Try 1
20;3E;DEBUG;Pulses=182;Pulses(uSec)=360,300,300,300,300,300,300,300,300,300,300,300,300,300,330,300,300,300,300,300,300,3930,720,300,330,690,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,720,720,300,300,690,300,690,690,300,720,330,720,300,300,690,720,300,300,690,300,690,300,720,720,300,720,300,300,690,300,690,300,690,690,300,300,690,720,300,720,300,300,690,720,300,720,300,720,300,300,690,330,690,720,300,300,720,720,300,720,300,720,300,690,330,720,300,300,720,720,300,300,690,720,300,690,300,720,300,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,690,300,300,720,720,300,720,300,330,690,300,690,300,690,690,300,720,300,720,300,720,330,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,720,300,690,300,690,300,6990;
20;3F;DEBUG;Pulses=182;Pulses(uSec)=360,300,300,300,270,300,270,270,300,270,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,300,690,720,300,690,330,720,300,720,300,300,690,720,300,300,720,720,300,300,720,300,690,720,300,720,300,720,300,300,690,720,300,300,720,300,690,300,720,720,300,720,300,300,690,300,690,330,690,720,300,300,690,720,300,720,300,300,690,720,330,720,300,720,300,300,690,300,690,690,300,300,720,720,330,720,300,720,300,720,300,720,300,300,720,720,300,300,720,720,300,720,300,720,300,300,720,300,690,300,690,330,690,720,300,720,300,720,300,300,690,300,690,690,300,330,720,720,300,720,300,300,690,300,690,300,690,720,330,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,690,300,720,300,690,300,690,330,6990;
20;40;DEBUG;Pulses=182;Pulses(uSec)=240,270,300,300,270,270,300,270,300,270,270,300,300,300,300,300,330,300,300,300,300,3930,720,300,300,720,300,690,690,300,720,300,720,300,720,300,300,690,720,300,300,720,720,300,300,690,300,690,690,300,720,300,720,300,300,690,720,300,300,690,300,690,300,720,720,300,720,300,300,690,300,690,300,690,720,300,300,690,720,300,720,300,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,330,720,300,690,300,690,300,690,720,300,720,300,720,330,300,690,300,690,690,300,300,690,690,300,720,300,300,720,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,690,300,300,690,300,690,300,690,330,720,300,720,300,690,300,6990;
20;41;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,300,270,270,300,300,300,270,270,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,300,690,720,300,720,300,720,300,720,300,300,690,690,300,300,720,720,300,300,690,330,690,720,300,720,300,720,300,300,690,720,300,300,720,300,690,300,690,690,300,720,300,300,690,300,690,300,720,690,300,300,690,720,300,720,300,300,690,720,300,720,300,720,300,300,690,300,690,690,300,300,720,720,300,720,300,720,300,720,300,720,300,300,720,690,300,300,690,720,300,690,300,720,300,300,720,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,690,690,300,300,720,720,300,720,300,300,690,300,690,300,690,690,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,330,690,300,690,300,690,300,690,300,720,300,690,300,6990;
20;42;DEBUG;Pulses=180;Pulses(uSec)=360,300,270,270,300,270,270,300,270,300,300,300,300,300,300,330,300,300,300,3930,690,300,300,690,300,720,690,300,720,300,720,300,720,300,300,690,720,300,330,690,690,300,300,690,300,690,690,300,720,300,720,330,300,720,690,300,300,690,300,690,300,690,720,300,720,300,300,690,300,690,300,690,690,300,300,720,690,300,720,300,300,690,690,300,690,300,690,300,300,690,300,690,720,300,300,690,690,300,690,300,720,300,690,300,690,330,300,720,690,300,300,690,720,300,690,300,690,300,300,720,300,690,300,690,300,690,690,300,720,300,720,300,300,720,300,690,690,300,300,690,720,300,720,300,300,690,330,690,300,690,690,300,690,300,690,300,720,300,690,300,720,300,720,300,690,300,300,690,300,690,300,690,300,720,300,720,300,690,300,6990;
Remote 2 , DOWN , Try 2
20;48;DEBUG;Pulses=180;Pulses(uSec)=390,300,300,300,300,300,300,330,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,720,300,690,300,300,690,300,690,720,300,720,300,300,690,720,300,300,690,300,720,720,300,720,300,330,690,300,690,300,690,300,720,300,690,300,690,300,720,300,690,300,720,300,720,720,300,300,690,300,690,720,300,300,720,720,300,300,690,720,300,300,690,690,300,720,300,300,690,300,690,720,300,300,690,690,300,690,300,720,300,720,300,720,300,300,690,690,300,300,690,720,330,690,300,690,300,300,720,300,720,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,300,690,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,690,300,720,300,300,720,300,690,300,690,300,690,300,720,300,690,300,6990;
20;49;DEBUG;Pulses=182;Pulses(uSec)=300,300,300,270,300,270,270,300,270,300,300,300,300,300,300,300,300,300,300,300,330,3930,720,300,720,300,720,300,330,690,300,720,720,300,720,300,300,690,720,300,300,720,300,720,720,300,720,300,300,690,300,690,300,690,300,720,300,690,300,690,300,690,300,690,300,720,300,690,720,300,300,690,300,690,690,300,300,720,720,300,300,690,720,300,300,690,690,300,720,300,300,690,300,690,690,330,300,690,720,300,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,720,300,720,300,690,300,690,720,300,720,300,720,300,300,690,330,690,720,300,300,690,720,300,720,300,300,690,300,690,330,690,720,300,720,300,720,300,720,300,690,300,720,330,720,300,720,300,300,690,300,690,300,690,300,690,300,720,300,690,300,6990;
20;4A;DEBUG;Pulses=180;Pulses(uSec)=360,270,270,270,270,300,300,270,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,690,300,720,720,300,720,330,300,690,690,300,300,690,300,720,720,300,720,300,300,720,300,690,300,720,300,720,300,690,300,690,300,690,330,690,300,720,300,690,720,300,300,690,300,690,720,300,330,720,720,300,300,690,690,300,300,690,690,300,720,330,300,690,300,690,720,300,300,690,690,300,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,330,720,300,300,690,300,690,300,690,690,300,690,300,690,330,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,300,720,300,690,300,6990;
20;4B;DEBUG;Pulses=180;Pulses(uSec)=360,270,300,300,270,300,270,300,300,300,300,300,300,300,300,300,300,300,300,3960,690,300,720,300,720,300,300,720,300,720,720,300,720,300,300,690,720,300,300,690,300,720,720,300,720,300,300,690,300,690,300,720,300,690,330,690,300,690,300,690,300,690,300,720,300,690,720,330,300,690,300,690,690,300,300,720,690,300,300,690,690,330,300,690,690,300,720,300,300,690,300,690,720,300,300,720,720,300,720,300,720,300,690,300,720,300,300,720,720,300,300,690,720,300,690,300,720,300,300,720,300,690,330,690,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,690,690,300,720,300,300,690,300,690,300,720,720,300,720,300,720,300,720,300,690,300,720,300,720,300,720,300,300,690,300,690,300,690,300,690,300,720,330,690,300,6990;
20;4C;DEBUG;Pulses=180;Pulses(uSec)=360,270,270,270,300,270,300,300,300,300,330,300,300,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,690,300,720,720,300,720,300,300,720,720,300,300,690,300,720,720,300,720,300,300,690,330,690,300,720,300,720,300,690,300,690,300,690,300,720,300,720,300,690,720,300,300,690,300,690,720,300,300,720,690,300,300,690,720,300,300,690,720,300,720,300,300,720,300,690,720,300,300,690,690,300,690,300,720,300,720,300,690,300,300,720,720,300,300,690,720,300,720,330,720,300,300,720,300,690,300,690,300,690,690,300,720,330,720,300,300,690,300,690,720,300,300,690,690,300,720,300,300,690,300,690,300,690,720,300,720,300,720,300,720,300,690,300,720,300,720,300,720,300,300,690,300,690,330,690,300,690,300,720,300,690,300,6990;
Remote 2 , STOP , Try 1
20;4D;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,300,330,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,300,690,690,300,300,720,300,690,720,300,720,300,300,690,690,300,690,300,300,690,300,720,300,690,720,300,300,720,300,690,720,300,720,300,300,720,300,720,690,300,720,300,300,690,300,690,300,690,720,300,720,300,300,690,300,690,690,300,720,300,720,300,720,300,300,690,300,690,690,300,300,720,720,300,720,300,720,300,720,300,720,300,300,720,720,300,300,690,690,330,690,300,720,300,300,690,300,690,300,690,300,690,720,300,690,300,720,300,300,690,300,690,720,300,300,720,300,720,720,300,720,300,300,690,300,690,720,300,720,300,720,300,720,300,720,300,690,300,690,300,690,300,300,720,300,690,300,690,300,720,300,690,300,690,300,6990;
20;4E;DEBUG;Pulses=182;Pulses(uSec)=90,300,270,270,300,270,270,270,300,270,270,300,270,300,300,300,300,300,300,300,330,3930,720,300,300,690,300,690,720,300,300,720,300,690,720,300,690,300,300,690,690,330,690,300,300,690,300,690,300,690,690,300,300,720,300,720,720,300,690,300,300,690,300,720,720,300,720,300,300,720,300,690,300,690,720,300,690,300,300,690,300,690,720,300,690,300,720,300,720,300,300,690,300,690,720,330,300,720,720,300,720,300,690,300,720,300,720,300,300,720,720,300,300,690,690,300,720,300,720,300,300,720,300,720,300,690,300,690,690,300,720,300,720,300,300,690,330,690,690,300,300,720,300,720,720,300,720,300,300,690,330,690,690,300,690,300,720,300,720,300,690,300,720,330,720,300,720,300,300,690,300,690,300,690,300,720,300,720,300,690,300,6990;
20;4F;DEBUG;Pulses=180;Pulses(uSec)=360,300,270,270,300,270,300,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,300,690,690,300,300,720,300,690,720,330,720,300,300,690,690,300,720,300,300,690,300,690,300,720,690,300,300,720,300,690,720,300,690,300,300,690,330,720,690,300,690,300,300,690,300,690,300,690,720,300,720,300,300,690,300,690,720,300,720,300,720,300,720,330,300,690,300,690,720,300,300,720,690,300,720,300,720,300,690,300,720,300,300,720,690,300,300,690,690,300,720,300,690,300,300,720,300,690,300,690,300,690,690,300,720,300,690,300,300,690,300,690,690,300,300,690,300,720,690,300,720,300,300,690,300,690,690,300,690,300,690,330,720,300,720,300,720,300,690,300,690,300,300,690,300,720,300,690,300,690,300,720,300,690,300,6990;
20;50;DEBUG;Pulses=180;Pulses(uSec)=360,300,270,270,300,270,270,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,300,690,690,330,300,720,300,690,720,300,720,300,300,690,720,300,720,300,300,690,300,690,300,690,690,300,300,690,300,720,720,300,720,300,300,690,300,690,690,300,720,300,300,720,300,690,300,690,720,300,690,300,300,690,300,690,690,330,720,300,690,300,720,300,300,690,300,690,690,300,300,720,720,300,720,300,720,300,690,300,720,300,300,690,720,300,300,690,720,300,720,300,690,300,300,720,300,690,330,690,300,690,690,300,690,300,720,300,300,690,300,720,720,300,300,690,300,720,720,300,720,300,300,690,300,720,690,300,720,300,720,300,720,300,690,300,690,300,720,300,690,300,300,690,300,690,300,690,300,690,300,720,330,690,300,6990;
20;51;DEBUG;Pulses=180;Pulses(uSec)=360,300,300,270,270,300,270,300,300,300,330,300,300,300,300,300,300,300,300,3930,720,300,300,690,300,690,720,300,300,690,300,720,690,300,720,300,300,690,690,300,720,300,300,720,300,690,300,690,720,300,300,690,300,720,690,300,720,300,300,690,300,720,720,300,720,300,300,690,300,690,300,690,690,300,720,300,300,720,300,690,720,300,690,300,720,300,720,300,300,720,300,690,690,300,300,690,720,300,690,300,690,300,720,300,720,300,300,690,690,300,300,690,720,300,720,330,690,300,300,690,300,720,300,690,300,690,720,300,720,330,720,300,300,720,300,690,720,300,300,690,300,690,720,300,690,300,300,690,300,690,720,300,690,300,720,300,720,300,720,300,720,300,720,300,690,300,300,690,300,690,330,690,300,690,300,690,300,720,300,6990;
Remote 2 , STOP , Try 2
20;52;DEBUG;Pulses=182;Pulses(uSec)=330,300,300,300,300,330,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,3930,690,300,300,690,720,300,720,300,720,300,330,690,720,300,300,720,300,720,300,690,300,690,690,330,720,300,300,720,300,690,720,300,300,690,300,690,720,300,300,720,300,690,300,690,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,720,720,300,720,300,720,300,300,690,300,720,720,300,300,690,720,330,690,300,720,300,720,300,720,300,300,690,720,300,300,720,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,690,720,300,330,690,300,690,690,300,720,300,300,720,300,720,720,330,720,300,720,300,720,300,720,300,720,300,720,300,690,330,300,690,300,690,300,720,300,690,300,690,300,690,300,6990;
20;53;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,270,300,270,270,300,270,300,300,270,300,300,300,330,300,300,300,300,3930,690,300,300,720,720,300,720,300,720,300,300,690,720,300,300,690,300,720,300,690,300,690,690,300,720,300,300,720,300,690,720,300,300,690,300,690,720,300,300,720,300,690,300,690,720,300,720,300,300,720,720,300,300,690,720,300,690,300,720,300,300,720,720,300,720,300,720,300,300,690,300,720,690,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,690,300,330,690,300,690,300,690,300,720,720,300,720,300,720,300,330,690,300,690,720,300,300,690,300,690,720,300,690,330,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,720,300,690,300,690,300,6990;
20;54;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,270,300,300,300,300,270,300,300,270,300,300,300,300,300,300,300,300,3930,690,300,300,690,690,300,720,300,720,300,300,720,720,300,300,690,300,720,300,690,300,690,720,300,720,300,300,720,300,720,720,300,300,690,300,690,720,300,330,720,300,690,300,690,690,300,720,300,300,690,720,330,300,690,720,300,690,300,720,300,300,720,720,300,720,330,720,300,300,690,300,690,720,300,300,690,720,300,720,300,690,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,690,300,690,300,720,300,300,690,300,690,690,300,300,720,300,690,720,300,690,300,300,690,300,720,690,300,720,300,720,300,690,300,720,300,720,300,720,300,720,300,330,690,300,690,300,720,300,690,300,690,300,690,300,6990;
20;55;DEBUG;Pulses=180;Pulses(uSec)=360,300,270,300,300,270,300,270,300,300,270,300,300,300,300,300,330,300,300,3930,720,300,300,690,720,300,720,300,720,300,300,690,690,300,300,690,300,720,330,690,300,690,720,300,690,300,300,690,300,720,720,300,330,690,300,690,720,300,300,720,300,690,300,690,720,330,720,300,300,690,690,300,300,690,720,300,720,300,720,300,300,720,720,300,690,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,720,300,720,300,720,300,330,690,720,300,300,690,690,300,690,300,720,300,300,720,300,690,300,690,300,690,690,300,720,300,720,300,300,720,300,690,690,300,300,720,300,690,720,300,720,300,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,720,300,690,300,690,300,6990;
20;56;DEBUG;Pulses=180;Pulses(uSec)=360,300,270,270,300,270,300,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,720,300,720,300,300,690,720,300,300,690,300,720,300,720,300,690,720,300,720,330,300,690,300,720,690,300,300,690,300,690,720,300,300,720,300,720,300,690,720,300,720,300,300,690,690,300,300,720,720,300,720,300,690,300,300,690,690,300,720,300,720,300,300,690,300,690,720,300,300,720,690,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,690,330,690,300,720,300,300,690,300,690,300,690,300,690,720,300,690,300,720,300,300,690,300,690,690,300,300,720,330,690,720,300,720,300,300,690,300,720,720,300,720,300,720,300,690,300,720,300,720,300,720,300,720,300,300,720,300,690,300,690,300,720,300,690,300,690,300,6990;
