Lctech relay board
Tooter
Lctech relay board
#1 Post by Tooter » 12 Nov 2024, 12:45
Hi all. I'm very new to espeasy so pls be gentle with me. I have a lctech relay board the same as this http://www.chinalctech.com/uploads/alli ... 1423-0.jpg I've managed to flash espeasy on the esp-01 micro controller and can access it via http. My question is how do I set it up so I can automatically turn on the relay using a temp sensor when the temp is below a temp and off when above. Thank you for any input.
chromo23
Re: Lctech relay board
#2 Post by chromo23 » 13 Nov 2024, 08:40
Tooter wrote: 12 Nov 2024, 12:45 My question is how do I set it up so I can automatically turn on the relay using a temp sensor when the temp is below a temp and off when above. Thank you for any input.
this is actually quite simple. Add the temperature sensor in the devices page an then also add the level control plugin.
Tooter
#3 Post by Tooter » 13 Nov 2024, 11:43
chromo23 wrote: 13 Nov 2024, 08:40
Thank you I'll give it a go.
Users browsing this forum: Bing [Bot] and 0 guests
