I have the Itho Daalderop CVE-S eco fan ventilator box RFT (bought 2022).
Will use the easy esp Itho plugin together with Domoticz. I follow the instructies on internet for the building and software settings.
I build the circuit with an Wemos D1 mini and the CC1101 868Mhz transmitter. I connecting the wires and control this.
Trying too pair the CC1101 with the Itho box will not happen.
First I unplug the Itho box, wait 15 sec, plug the Itho box and within 2 minutes I send in my browser the command:
http://YourIP-adres/control?cmd=STATE,1111
But no connection with the Itho box. I don't hear the fan speed changing.
In easy esp log, I see no packets coming.
In the instructions of Itho for a official Itho RF remote pairing with the Itho Box.
After plug the Box within 2 minutes press simultaneous the two buttons diagonally opposite each other. The middle and high speed buttons.
How I can this simulate?
What going wrong?
Jack
Easy esp will not connected with Itho Box
Re: Easy esp will not connected with Itho Box
Hmm, 15 seconds is quite short, I recall I had to leave it unplugged for over a minute (maybe even 2) before I could connect with the CC1101 to my Itho box. But eventually it workedjack100 wrote: ↑22 Nov 2024, 16:57 First I unplug the Itho box, wait 15 sec, plug the Itho box and within 2 minutes I send in my browser the command:
NB: The actual command should be "itho,1111", the "state" command is deprecated (though it still works).
I will try again.
I will try again.
My Itho ventilationbox works with easy esp and Domoticz!
But there some issues:
In the log of de itho plugin see the next:
1982531: WD : Uptime 33 ConnectFailures 0 FreeMem 19792 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
What means this?
When I change the Itho selector in Domoticz by example too Auto (medium).
The Itho box goes too the middle speed and stay, but in Domoticz the selector goes back to uit.
With the other selecting of the speed in Domoticz, the same. Back too uit.
Must I change the rules in the Itho plug. Maybe some wrong settings somewhere?
I usage the rules 1 and 2 from the site:
https://www.fam-oldenburger.nl/2020/05/ ... entilatie/
Jack
What means this?
Jack
Great
That's the WatchDog (WD) log, it's logged every 30 seconds at Info level. If you don't want that, you can set the logging level to Error, but then you'll hardly see any logging. Info level isn't an issue, as you won't be looking at that log much anyway .
I don't know how those scripts are supposed to work, so not sure how to help.jack100 wrote: ↑26 Nov 2024, 15:46 When I change the Itho selector in Domoticz by example too Auto (medium).
Jack
There isn't enough time in a day to investigate that too, sorry
Is solved!
Jack
Jack
Users browsing this forum: Bing [Bot] and 4 guests
