Well darn it - it must be child-proof!
davecason
#1 Post by davecason » 18 Nov 2024, 20:27
Hi Folks,
A while ago (about 2019 - grin) I got a few Wemos ESP8266 and used them to monitor my hot tubs temperature, they worked great and were happy.
I ordered some new ones last week with a new set of DS18b20 probes and some new SSD1315 OLEDs to build more......
My problem is right now I can't see the Wemos when they're plugged in to my computers, the USB to serial drivers are unhappy.
I've tried 4 different PC's from old WIn7 to Win10 tables and old Tecra laptops and no joy, I do use the laptop's to program ham radios with Chirp so I know they work(ed).
I've installed SPARKFUNS CH340 driver and some older USB ones and still nothing and swapped out various cables - I have two Wemos units here now that are from before
and plugged in to the PC they both power up happy but I can't program them or update the firmware.
Now it has been a while since I used these - but I'm pretty sure you can just plug Esp8266 D1 Mini Pro's in to any USB serial port with a micro USB to USB A cable and see and flash them.
I'm at a loss ..... am I missing something? I don't recall using a ModeMCU before so I don't think that's the problem. For now I go with: "there child-proof!" :-)
Cheers'
Dave
Re: Well darn it - it must be child-proof!
#2 Post by Ath » 18 Nov 2024, 21:12
Have you tried swapping the micro-usb cable with another one? Seen too many issues like this just because the cable was wonky... :shock:
#3 Post by TD-er » 18 Nov 2024, 22:01
Does the device get recognized in Windows device manager?
Also you mention the SSD1315 OLED displays.
I don't recognize those numbers, but maybe Ton does know whether those can be used in ESPEasy?
#4 Post by Ath » 18 Nov 2024, 22:24
The SSD1315 seems to be compatible with the SSD1306 (at least some example code I found was using the ug8l library with the SSD1306 driver, and it's monochrome), but haven't seen such display yet. YMMV.
davecason
#5 Post by davecason » 28 Nov 2024, 00:28
Well a bit further progress - in a way - I have two ESP that's programmed up but I can't get in to one of them .......
The AP comes up when I power it up the segments light up on the display (even tho a few pixels are optional)
The name of the unit still comes up: Dave_Temp It says: IP (IP Unset)
I can see it on my cell phone too but the password is long gone - does the reset button on these D1 Mini actually do a hard factory reset or is it just a power off/on thing?
Cheers'
Dave
bidrohini
#6 Post by bidrohini » 01 Dec 2024, 07:50
davecason wrote: 28 Nov 2024, 00:28 Hi,
Cheers'
Dave
Did you test the Wemos board in any platform other than ESPeasy ? Like the Arduino IDE? I think you need to check the board in other platforms. If it fails, you can be sure that the board is damaged.
#7 Post by TD-er » 01 Dec 2024, 10:13
To do a factory reset, you can also short RX and TX and then boot the device.
The reset button only pulls the EN pin so the device reboots.
