how set local time on tft7789 using http
BartSr
#1 Post by BartSr » 05 Dec 2024, 16:53
Finally I got the tft screen ST7789 working.
I am able to control the screen from domoticz which commands like
 if (dz.devices(818).state == 'Unlocked') then
    dz.openURL({ url = "http://192.168.2.230/control?cmd=tft,txtfull,3,4,3,white,blue,,,Achterdeur" })
    dz.openURL({ url = "http://192.168.2.230/control?cmd=tft,txtfull,3,4,3,white,darkgreen,,,Achterdeur" })
  end
But I cannot get a localtime clock on the tft
Any suggestion howto (if possible)?
Bart
Re: how set local time on tft7789 using http
#2 Post by Ath » 05 Dec 2024, 17:21
Check the Tools/System variables page for all % variables you can use, and select the desired time variable. It's helpful to have the Latitude/Longitude set correctly and the offset to GMT (60 minutes), so the ESP clock has the correct time (assuming time is received from 1 node in your P2P network that's using NTP).
BartSr
#3 Post by BartSr » 08 Dec 2024, 12:29
Hi Ton,
this works ( %lcltime% ) but how can I update the time from rules?
Another Q: I wonder how to put text on the display from rules?
update:
found solution from rules for time : tft,txtfull,3,3,2,white,blue,,,"%lcltime%"
for text : tft,txtfull,3,3,2,white,blue,,,"Jan Jansen"
so problem solved :-)
Users browsing this forum: Bing [Bot] and 0 guests
