Now i have 100% CPU usage don know why. Unit can not connect to MQTT server.
I try to disable WOL module byt result was the same.
Below main menu output:
Any help?
Unit Number: 1
Local Time: 2024-12-16 13:02:33
Time Source: NTP
Time Wander: 0.000 [ppm]
Uptime: 00h02m
Load: 100.00 [%] (LC=119)
CPU Eco Mode: false
Boot: Cold Boot (0)
Reset Reason: Power On
Last Action before Reboot: Background Task
SW WD count: 0
Memory
Free RAM: 8464 [byte] (8424 - )
Heap Max Free Block: 7944 [byte]
Heap Fragmentation: 7 [%]
Free Stack: 3664 [byte] (1264 - )
Network
IP Config: Static
IP / Subnet: 192.168.0.18 / 255.255.255.0
Gateway: 192.168.0.1
Client IP: 192.168.0.8
DNS: 192.168.0.201 / (IP unset)
Allowed IP Range: 192.168.0.0 - 192.168.0.255
Connected: 00:01:49.961
Number Reconnects: 0
WiFi ?
WiFi Connection: 802.11n (RSSI -65 dBm)
SSID: maciek24 (34:60:F9:26:28:C5)
Channel: 1
Encryption Type: WPA2/PSK
Last Disconnect Reason: (202) Auth fail
Configured SSID1: maciek24
Configured SSID2:
STA MAC: 84:F3:EB:E3:62:B2
AP MAC: 86:F3:EB:E3:62:B2
WiFi Settings
Force WiFi B/G: false
Restart WiFi Lost Conn: true
Force WiFi No Sleep: true
Periodical send Gratuitous ARP: false
Connection Failure Threshold: 0
Max WiFi TX Power: 17.50 [dBm]
Current WiFi TX Power: 14.00 [dBm]
WiFi Sensitivity Margin: 3 [dB]
Send With Max TX Power: false
Extra WiFi scan loops: 0
Use Last Connected AP from RTC: false
Extra Wait WiFi Connect: false
Hidden SSID Slow Connect: true
Include Hidden SSID: false
Enable SDK WiFi Auto Reconnect: false
Firmware
Build:⋄ 20241210 - Mega
System Libraries:⋄ ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support
Git Build:⋄ Skrzypowa: Dec 10 2024 12:20:13
Plugin Count:⋄ 30 []
Build Origin: Self built
Build Time:⋄ Dec 10 2024 12:20:13
Binary Filename:⋄ ESP_Easy_mega_20241210_custom_274_ESP8266_4M1M
Build Platform:⋄ Linux-6.6.61-desktop-1.mga9-x86_64-with-glibc2.36
Git HEAD:⋄ No_.git_dir
System Status
Syslog Log Level: None
Serial Log Level: None
Web Log Level: None
Enable Serial Port Console: false
Console Serial Port: -
I2C Bus State: OK
I2C bus cleared count: 0
Network Services
Network Connected: ✔
NTP Initialized: ✔
MQTT Client Connected: ❌
ESP Board
ESP Chip ID: 14901938 (0xE362B2)
ESP Chip Frequency: 80 [MHz]
ESP Chip Model: ESP8266EX
ESP Chip Cores: 1
ESP Board Name: Espressif Generic ESP8266 ESPEasy 4M Flash 1M FS
Storage
Flash Chip ID: Vendor: 0x68 Device: 0x4016
Flash Chip Real Size: 4096 [kB]
Flash IDE Size: 4096 [kB]
Flash Chip Speed: 40 [MHz]
Flash IDE Speed: 40 [MHz]
Flash IDE Mode: DIO
Flash Writes: 0 daily / 0 boot
Sketch Size: 903 [kB] (2168 kB free)
Max. OTA Sketch Size: 1019 [kB] (1044464 bytes)
OTA possible: true
OTA 2-step Needed: false
SPIFFS Size: 934 [kB] (836 kB free)
Page size: 256 [byte]
Block size: 8192 [byte]
Number of blocks: 116
Maximum open files: 5
Maximum path length: 32
Partitions
Partition Table:
903.08k
sketch
2.12M
ota
1000k
fs
SPIFFS
4k
eeprom
sector:1019
4k
RFcal
12k
WiFi
