In the firmware changelog of RFLink v1.1 - R51: (12/01/2024) I read that the TFA Dostmann 30.3222.02 is supported which is great as I own this sensor and the accompanying display. However I notice that the humidity value reported via the RFLink is off from the value displayed on the accompanying display. Also the wind speed is not reported/identified at all. I don't know if this is a bug or that wind speed is not able to be received by the RFLink.
Values on the accompanying display at time of debug capture:
- Temperature: 8,7 C
- Humidity: 82 %
- Wind speed: +/- 10 km/h
Session 1
10;version;
20;01;VER=1.1;REV=51;BUILD=01;
10;status;
20;02;STATUS;RF433/868=ON;NodoNRF=OFF;Milight=OFF;LivingColors=OFF;Ansluta=OFF;GPIO=OFF;BLE=OFF;Mysensors=OFF;
20;03;TFA;ID=0f5f04;TEMP=0057;HUM=52;
10;rfdebug=on;
20;04;RFDEBUG=ON;
20;05;DEBUG;Pulses=511;Pulses(uSec)=180,630,660,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,390,180,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150;
20;06;TFA;ID=0f5f04;TEMP=0058;HUM=52;
20;07;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,150,360,150,360,120,150,360,150,360,360,120,150,360,150,360,360,120,120,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,150,390,390,150,150,390,150,390,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,150,390,390,150,150,390,150,390,150,6990;
20;08;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,390,870,390,870,390,870,1350,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,6990;
20;09;AlectoV3;ID=306f;TEMP=0048;BAT=OK;
20;0A;DEBUG;Pulses=511;Pulses(uSec)=210,630,660,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,120,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,420,630,630,660,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,120,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,390,180,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150;
20;0B;TFA;ID=0f5f04;TEMP=0058;HUM=52;
20;0C;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,150,360,120,360,120,150,360,150,360,360,120,150,360,150,360,360,150,120,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,390,150,390,120,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,390,150,390,150,390,150,390,150,150,390,150,6990;
20;0D;DEBUG;Pulses=511;Pulses(uSec)=240,630,660,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,120,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,390,180,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,150,390,150;
20;0E;TFA;ID=0f5f04;TEMP=0058;HUM=52;
20;0F;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,120,360,120,360,120,150,360,150,360,360,120,150,360,150,360,360,120,150,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,390,150,150,390,150,390,150,390,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,120,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,390,150,150,390,150,390,150,390,150,6990;
20;10;DEBUG;Pulses=511;Pulses(uSec)=180,630,660,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,120,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;11;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;12;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,150,360,150,360,120,150,360,150,360,360,120,150,360,120,360,360,150,150,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,390,150,390,150,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,120,390,150,390,150,390,150,390,150,390,150,390,150,150,6990;
20;13;DEBUG;Pulses=511;Pulses(uSec)=180,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,120,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,120,150;
20;14;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;15;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,150,360,150,360,120,150,360,150,360,360,120,150,360,150,360,360,150,120,360,120,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,150,390,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,120,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,120,390,150,150,390,390,150,390,150,390,150,150,390,150,6990;
20;16;DEBUG;Pulses=511;Pulses(uSec)=180,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,120,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,120,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;17;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;18;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,150,360,150,360,120,150,360,150,360,360,120,150,360,150,360,360,150,120,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,390,150,390,150,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,120,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,390,150,390,150,150,6990;
20;19;DEBUG;Pulses=511;Pulses(uSec)=210,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,120,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,390,180,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;1A;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;1B;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,150,360,120,360,120,360,150,360,120,150,360,150,360,360,120,150,360,150,360,360,120,150,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,120,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,390,150,150,390,150,6990;
20;1C;DEBUG;Pulses=511;Pulses(uSec)=180,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;1D;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;1E;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,150,360,120,360,120,150,360,150,360,360,120,150,360,150,360,360,150,120,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,150,390,390,120,150,390,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,150,390,390,120,150,390,150,390,150,6990;
20;1F;DEBUG;Pulses=511;Pulses(uSec)=180,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,120,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,120,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,120,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;20;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;21;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,150,360,120,360,150,360,150,360,120,150,360,150,360,360,120,150,360,150,360,360,150,150,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,120,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,6990;
10;rfdebug=off;
20;22;RFDEBUG=OFF;
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R51
10;version;
10;status;
20;02;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;03;STATUS;RF433/868=ON;NodoNRF=OFF;Milight=OFF;LivingColors=OFF;Ansluta=OFF;GPIO=OFF;BLE=OFF;Mysensors=OFF;
10;rfdebug=on;
20;04;RFDEBUG=ON;
20;05;DEBUG;Pulses=511;Pulses(uSec)=180,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,120,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,390,180,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;06;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;07;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,120,360,150,360,120,150,360,150,360,360,120,150,360,150,360,360,150,120,360,150,360,120,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,150,390,390,150,150,390,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,120,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,150,390,390,150,150,390,150,390,150,6990;
20;08;DEBUG;Pulses=511;Pulses(uSec)=180,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,120,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,120,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,120,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;09;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;0A;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,150,360,120,360,120,360,150,360,120,150,360,150,360,360,120,150,360,150,360,360,150,120,360,150,360,120,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,390,150,390,150,150,390,390,150,390,150,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,390,150,390,150,150,390,390,150,390,150,150,6990;
20;0B;DEBUG;Pulses=511;Pulses(uSec)=180,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,120,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,120,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,120,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;0C;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;0D;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,150,360,150,360,120,150,360,150,360,360,120,150,360,150,360,360,150,150,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,390,120,150,390,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,390,150,150,390,150,390,150,6990;
10;rfdebug=off;
20;0E;RFDEBUG=OFF;
20;17;AlectoV3;ID=306f;TEMP=0049;BAT=OK;
20;18;TFA;ID=0f5f04;TEMP=0057;HUM=52;
10;version;
10;status;
20;04;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;05;AlectoV3;ID=306f;TEMP=0049;BAT=OK;
10;rfdebug=on;
20;06;RFDEBUG=ON;
20;07;DEBUG;Pulses=511;Pulses(uSec)=180,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,120,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,120,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,120,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;08;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;09;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,120,360,150,360,120,150,360,150,360,360,120,150,360,150,360,390,120,120,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,390,120,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,390,120,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,6990;
20;0A;DEBUG;Pulses=511;Pulses(uSec)=210,630,660,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,120,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,660,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,660,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,120,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,120,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;0B;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;0C;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,150,360,120,360,120,150,360,150,360,360,120,120,360,150,360,360,120,120,360,120,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,390,150,390,150,150,390,390,150,390,150,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,390,150,150,390,390,150,390,120,150,390,390,150,390,120,150,6990;
20;0D;DEBUG;Pulses=511;Pulses(uSec)=180,630,660,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;0E;TFA;ID=0f5f04;TEMP=0057;HUM=52;
20;0F;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,120,390,120,360,120,150,360,150,360,360,120,150,360,150,360,360,120,120,360,150,360,150,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,390,150,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,660,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,390,150,390,150,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,390,150,390,150,150,390,150,6990;
20;10;DEBUG;Pulses=511;Pulses(uSec)=210,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,390,180,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150,390,150,390,150,390,150,390,150,390,390,150,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,420,630,630,630,630,660,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,390,150,390,150,150;
20;12;DEBUG;Pulses=248;Pulses(uSec)=90,360,360,120,360,120,360,150,360,150,360,120,150,360,150,360,360,120,150,360,150,360,360,120,150,360,150,360,120,360,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,420,630,630,630,630,630,630,630,630,150,390,150,390,150,390,150,390,390,150,390,150,390,150,390,150,150,390,390,150,150,390,390,150,390,150,390,150,390,150,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,120,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,390,150,150,390,390,150,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,390,390,150,150,390,150,6990;
10;rfdebug=off;
20;13;RFDEBUG=OFF;
Thanks in advance.
Best, Maarten
