Unfortunately I tried all of methods you mention, but the issues are not solved.
Here is longish dump of the latest tinkering I have done on my SparkFun ESPthing:
INIT : Booting Build nr:107
WIFI : No SSID!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
>settings
System Info
IP Address : 0.0.0.0
Build : 107
Unit : 0
WifiSSID : ssid
WifiKey : wpakey
Free mem : 26592
Ok
>wifiscan
WIFI : SSID Scan start
WIFI : 5 networks found
WIFI : 1: ***** (-77)
WIFI : 2: ***** (-43)
WIFI : 3: ***** (-88)
WIFI : 4: ***** (-34)
WIFI : 5: ***** (-89)
Ok
WD : Uptime 0 ConnectFailures 0 FreeMem 26384
WD : Uptime 1 ConnectFailures 0 FreeMem 26352
>wifissid *****
Ok
>wifikey *****
Ok
>save
FLASH: Settings saved
Ok
>wificonnect
WIFI : Connecting... 1
WIFI : Connected!
Ok
>settings
System Info
IP Address : 192.168.5.113
Build : 107
Unit : 0
WifiSSID : *****
WifiKey : *****
Free mem : 25656
Ok
WD : Uptime 1 ConnectFailures 0 FreeMem 25784
Exception (0):
epc1=0x40214e30 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff39a0 end: 3fff3b70 offset: 01a0
>>>stack>>>
3fff3b40: 00000000 00000000 00000001 402223d1
3fff3b50: 3fffdad0 00000000 3fff2b39 402223ff
3fff3b60: feefeffe feefeffe 3fff2b50 40100958
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
�U
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�U
Exception (0):
epc1=0x40104863 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: sys
sp: 3ffffcc0 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffffe60: 00000022 40104879 00040000 4010368a
3ffffe70: 3ffee850 40103856 00000003 00000000
3ffffe80: 00000000 00347069 53000000 4000050c
3ffffe90: 3fffc278 401036ac 3fffc200 00000022
3ffffea0: 3ffffeb0 3fff3d60 3ffeea8c 00000000
3ffffeb0: 40000f68 00000030 0000001c ffffffff
3ffffec0: 40000f58 00000000 00000020 00000000
3ffffed0: 0010c59f 00000001 00003a98 00000000
3ffffee0: ffffffff 3fffc6fc 60000600 3fffdab0
3ffffef0: 00000000 3fffdcb0 3ffeff80 00000030
3fffff00: 0000001c 00000000 00000000 40105d5c
3fffff10: 0010a6ca 3ffefc84 0000001c 401006d8
3fffff20: 3ffea504 401064e7 00000064 401077a4
3fffff30: 00000000 00000001 40225bab 3ffea504
3fffff40: 3ffeff60 3ffea500 3ffeff60 00000001
3fffff50: 40225c14 3ffea504 3ffeff60 0035c5d6
3fffff60: 4010638e 40242d31 3ffeff38 3ffeff60
3fffff70: 40242d50 60000600 3ffea7a8 3ffea7a8
3fffff80: 40242d76 3fffdab0 00000000 3fffdcb0
3fffff90: 3ffeff80 3fffdab0 00000000 4022236b
3fffffa0: 40000f49 40000f49 3fffdab0 40000f49
<<<stack<<<
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�U
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�U
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�U
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�U
Exception (9):
epc1=0x40103873 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000016 depc=0x00000000
ctx: sys
sp: 3ffffcd0 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffffe70: 3ffee850 40103856 3fff4d2c 00000000
3ffffe80: 60000600 00000000 00000000 4000050c
3ffffea0: 3ffffeb0 4022616b 3fff4d2c 3fff400c
3ffffeb0: 40000f68 00000030 0000001e ffffffff
3ffffed0: 3ffeade0 c0633d0c 3ff20a00 c0000000
3ffffee0: 00000000 00000000 00000033 3fffdab0
3ffffef0: 00000000 3fffdcc0 3ffea738 00000030
3fffff00: 3ffef258 401064e7 3ffeeb10 40105d5c
3fffff10: 00000000 00000001 40231d38 3ffef258
3fffff20: 3ffef238 3ffef258 00000064 401077a4
3fffff30: 3ffeeb28 40231cd4 3ffef178 3ffeff60
3fffff40: 00000000 00000000 40105d75 00000100
3fffff50: 00000033 00000001 4010585a 3ffee850
3fffff60: 3fff4d2c 401021c6 00000000 00000000
3fffff70: 40242d50 40101f93 00000000 00000000
3fffff80: 40101fce 00000000 00000002 3fffdcb0
3fffff90: 40225e2a 3fffdab0 00000000 4022236b
3fffffa0: 3ffea738 40000f49 3fffdab0 40000f49
<<<stack<<<
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�U
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�U
Exception
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�USystem will reset in 10 seconds...
RESET: Reboot count: 0
FLASH: Zero Fill Sector: 107
FLASH: Zero Fill Sector: 108
FLASH: Zero Fill Sector: 109
FLASH: Zero Fill Sector: 110
FLASH: Zero Fill Sector: 111
FLASH: Zero Fill Sector: 112
FLASH: Zero Fill Sector: 113
FLASH: Zero Fill Sector: 114
FLASH: Zero Fill Sector: 115
FLASH: Zero Fill Sector: 116
FLASH: Zero Fill Sector: 117
FLASH: Zero Fill Sector: 118
FLASH: Zero Fill Sector: 119
FLASH: Zero Fill Sector: 120
FLASH: Zero Fill Sector: 121
FLASH: Zero Fill Sector: 122
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
RESET: Reboot count: 1
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
RESET: Reboot count: 2
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
RESET: Reboot count: 3
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�U
WIFI : No SSID!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
>wifiscan
WIFI : 1: ***** (-78)
WIFI : 2: ***** (-41)
WIFI : 3: ***** (-87)
WIFI : 4: ***** (-42)
WIFI : 5: ***** (-87)
Ok
>wifissid *****
Ok
>wifikey *****
Ok
>save
Ok
>wificonnect
WIFI : Connected!
Ok
>save
Ok
>settings
System Info
Build : 107
Unit : 0
WifiSSID : *****
WifiKey : *****
Free mem : 25656
Ok
Exception (0):
epc1=0x40e2267b epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff3980 end: 3fff3b70 offset: 01a0
>>>stack>>>
3fff3b20: 00000000 00000000 3fff0a5c 40222428
3fff3b30: 3fffdad0 00000000 3fff0a5c 40203ac4
3fff3b40: 00000000 00000000 3fff0a5c 40214ea4
3fff3b50: 3fffdad0 00000000 3fff2b39 402223fc
<<<stack<<<
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�U
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
�U
I have both given the erase command, and connected together the TX and RX pin, which triggered the "FLASH: Zero Fill Sector" sequence followed by the "FLASH: Settings saved".
Still, this did not solve the issue.
I am very open to any other suggestion you might. I am good at tinkering on both my OS X and Linux machines, if need be.
Many thanks,
Luca
