Sendtohttp - domoticz json
hamster
#1 Post by hamster » 18 Jun 2016, 08:47
I'm trying to use a PIR connected to my esp to make a switch connected to domoticz (esp12e with 108 running)
Using the sendtohttp I added the following rule
on Landing_PIR#Switch=1 do
sendtohttp,192.168.0.93,8080,/json.htm? type=command&param=switchlight&idx=42&switchcmd=On
However when I press submit the text is changed as below
type=command¶m=switchlight&idx=42&switchcmd=On
Can anyone make any suggestions? As it replaces '&para' to ¶
Also if I remove the 2nd a within param it submits ok without changing anything but this obviously doesn't work??
Many thanks
hamster
Re: Sendtohttp - domoticz json
#2 Post by hamster » 19 Jun 2016, 22:58
instead of using sendtohttp I found 'publish' works brilliantly :D
if [lux#lux]<2
Publish domoticz/in,{"idx":42,"command":"switchlight","switchcmd":"On"}
timerSet,2,20
On Rules#Timer=2 do
Publish domoticz/in,{"idx":42,"command":"switchlight","switchcmd":"Off"}
Jeff
#3 Post by Jeff » 16 Dec 2016, 22:50
I have exactly the same problem.
The publish doesn't work for me, I can not do it
When i do this an i push "submit"
On BP#Switch=1 do
SendToHTTP 192.168.1.12,8080,/json.htm?type=command&paramm=switchlight&idx=46&switchcmd=On
I get this
On BP#Switch=1 do
SendToHTTP 192.168.1.12,8080,/json.htm?type=command¶mm=switchlight&idx=46&switchcmd=On
Version R147
vmfs1968
#4 Post by vmfs1968 » 17 Dec 2016, 15:29
hamster wrote:instead of using sendtohttp I found 'publish' works brilliantly :D
if [lux#lux]<2
timerSet,2,20
On Rules#Timer=2 do
Can you give a help how to activate mqtt in domoticz
It's just that I can not do this.
Westcott
#5 Post by Westcott » 26 Dec 2016, 18:30
Hi Jeff,
I think you have an extra character, perhaps by using copy&paste from Windows?
Perhaps edit the rule to delete a couple of chars back from the '=', and re-add the '&param'.
EDIT!!!
Sorry, I spoke too soon. Ignore the above.
For some reason the exact string "&param" is displayed as "¶m"
Delete one of the two "m" and it seems to work OK
Domoticz, Sonoff, ESP32
DMeekelenkamp
#6 Post by DMeekelenkamp » 08 Jan 2017, 19:08
I also have the same problem running R147
On RFID#Tag do
if [RFID#Tag]=9235734
SendToHTTP
192.168.1.2:8080/json.htm?type=command&param=switchlight&idx=89&switchcmd=On
Becomes
On RFID#Tag do
SendToHTTP
192.168.1.2:8080/json.htm?type=command¶m=switchlight&idx=89&switchcmd=On
When I push enter. And nothing happens In domoticz.
The rule works when is use Gpio,13,1 instead of SendToHTTP. Gpio 13 goes high.
Is this a bug?
Greetings Dennis
ayasystems
#7 Post by ayasystems » 13 Jan 2017, 11:37
What is the solution?
I want rise http commands with several parameters but i am having the same problem
danielchagasrs
#8 Post by danielchagasrs » 13 Jan 2017, 15:51
No solution yet for the "&param" replacement problem?
And the Publish domoticz/in doesn't work for me either. I'd like to use mqtt to update a contact switch (it's a read only switch, used for reed sensors, and only updates with the "udevice" command on json/domoticz)
nick-head
#9 Post by nick-head » 22 Jan 2017, 00:37
Mine has the same problem but when I see it in the Log it is ok
and all lights switch ok.
Version 147
Sonoff 16A Switch
ESP32, Arduino's,Raspberry Pi's, ESP8266's, Nextion's, Sonoff's, LightWaveRF's, RFXCom 433, and a headache
And a HackRF One, as a present to myself.
danielchagasrs
#10 Post by danielchagasrs » 29 Jan 2017, 01:20
I updated to 147, and still have the same problem (&param gets replaced by a symbol) and the command doesnt work.
danielchagasrs
#11 Post by danielchagasrs » 29 Jan 2017, 01:35
I tried something, and it worked fine.
Just invert the commands, and put "param" as the first item, without the "&".
Normal way ("&param" gets replaced):
/json.htm?type=command&param=switchlight&idx=174&switchcmd=On
Inverted way (working fine):
/json.htm?param=switchlight&type=command&idx=96&switchcmd=On
vojtishek
#12 Post by vojtishek » 07 May 2017, 22:03
Hi guys,
could you please advise If I can use that in situation related to my post below
https://www.letscontrolit.com/forum/vie ... 687#p15687
I'm newbie in using scripts so any help more than appreciated.
V.
danielchagasrs
#13 Post by danielchagasrs » 08 May 2017, 01:10
vojtishek wrote: 07 May 2017, 22:03 Hi guys,
V.
Ok, replied there.
livebelive
#14 Post by livebelive » 08 May 2017, 23:32
danielchagasrs wrote: 29 Jan 2017, 01:35 I tried something, and it worked fine.
Thank you very much!!!
Users browsing this forum: Ahrefs [Bot] and 18 guests
