RFLink release 42 is available for download
R42:
- New Device: Mi-Light/LimitlessLED/Applamp bridge functionality (2.4 Ghz, NRF24L01 with Milight wiring required)
- New Device: Hama SD-UN5-RF switch set
- New Device: Acurite Tower sensors
- New Device: Pollin PFR-130 Temperature & Rain meter
- New Device: Gaposa Blind/Shutter control (a.o. model QCT3S)
- New Device: Byron BY35 / BY301
- Added: Command "echo" function to auto create devices without the need of remote controls
- Added: Command "rtsrecclean 9" function to clean a single rolling code table entry
- Added: Command to invert the ON/OFF handling of the Tristate protocol
- Fixed: improved Atlantic MD-210R detection
- Fixed: improved DKW2012 detection to cover variations of the signal
- Fixed: Smarthome YC-4000B detection
- Fixed: improved RTS packet detection to prevent false positives
- Fixed: improved FA500 packet detection to prevent false positives
- Fixed: Modified X10 security sensor packet detection
- Fixed: Modified maximum humidity limit
- Fixed: Improved signal ARC detection
- Fixed: Chacon EMW200 detection
- Fixed: Nexa WST-512 detection
- Fixed: Oregon UV800
- Fixed: CM113 ID
- Added: Support for another MiLight remote variant
the download is available via our blog.
http://www.nemcon.nl/blog2
- Fixed: CM113 ID
Re: RFLink release 42 is available for download
Great thanks !
Thank you.
How do you use this command ?Stuntteam wrote:- Added: Command to invert the ON/OFF handling of the Tristate protocol
Thank you.
I would like to know that tonegan wrote:Great thanks !
Thank you.
Although I suppose this is not available for the Livolo switches where on=off and off=on(for me at least)
thx
Can someone elaborate on this, does this mean that you do not need a bridge ? And is a NRF24L01 needed ? Where can I find more info ?Mi-Light/LimitlessLED/Applamp bridge functionality (2.4 Ghz, NRF24L01 with Milight wiring required)
Correct, if you have RFLink with a NRF24L01 wired for Milight you do not need any other bridge.
you can find all details on www.nemcon.nl/blog2
the wiring page shows how to connect the NRF24L01
the Frequently Asked Questions page shows various other aspects about Milight
That sounds cool, I will be looking into this.
Edit: Never mind found it in the FAQ.
Now to order a milight
Any help ?negan wrote:Great thanks !
Thank you.
Thank you
Is there a possibility to use RF Link Loader with Arduino NANO instead Arduino Mega?
Best regards
Best regards
No, sorry. RFlink wont fit on a Nano.
Btw, an Arduino Mega can be bought for as low as 6 euros..
is there available any smaller version of arduino mega (like nano) which will RFLINK fit into?
Maybe the Mega Pro mini, we did not test it though.
But why would you use a smaller version?
Thx for answer Stuntteam
I think I need to buy one...
Best regards
Best regards
I think the questions is aimed to get a smaller form factor. do you have any plans/ideas ?
Why is my question avoided ?
oops, not on purpose..
I think you were looking for the following commands:
10;TRISTATEINVERT=ON;
10;TRISTATEINVERT=OFF;
Not fully tested yet.
Note that when you turn invert on, ON becomes OFF and vice versa for ALL tristate devices.
Hi guys! I encountered a problem when trying to ad milight!
It finds the milight remote very fast. But when I click to turn milight on or off it just says
"Error sending switch command, check device/hardware !" in domoticz. How do I solve this?
You probably need a more recent Domoticz version
I am onVoyager wrote:You probably need a more recent Domoticz version
Version: 3.4834
Build Hash: 8398125
Compile Date: 2016-03-02 08:43:51
How do I get a more updated version?
Edit: Should I go for the beta?
3.5301 2016-07-14
(I am using a Raspberry pi 2 for domoticz)
Yes, you will need beta..
Thanks, Im really liking rflink so far!Stuntteam wrote:Yes, you will need beta..
edit: Was super quick to switch to beta, and milight instantly worked! Thank you!
anny news/ update for the next release incl mysensors ?
Please can we get the source uploaded?
Even better, can you put it on github and not do random google drive releases?
The nrf2401 library that I think you're using has some bugs and I'd like to use the patched/fixed version. The Milight is unreliable with some nrf2401l transmitters because of this (I think) but I can't fix it because you're only sometimes releasing source.
It should use this: http://tmrh20.github.io/RF24/
is there some update about the RFLink with MySensors intergration ?
Any news about R43 and or sourcode on github?
Target is this week..
update 16/9: slightly delayed.. nearly done..
