Kerui cheap chinese pir detector
slash133
#1 Post by slash133 » 27 Mar 2016, 13:10
Hi friends,
I bought pir sensors Chinese brand but I noticed that it was poorly recognized by the RFLINK. Sometimes they are recognized as "20; D3; EV1527; ID = 0051fc; 0a = SWITCH; CMD = ON;" and sometimes as "20; D0; Eurodomest; ID = 07ae03; SWITCH = 02; CMD = OFF;" This is annoying for recognition under domoticz.
I make you a debug for Each one of the three sensors I have. hoping you can correct the problem.
Thanks for your work.
The device
Device 1
20;DD;DEBUG;Pulses=50;Pulses(uSec)=900,180,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;DE;Eurodomest;ID=07ae03;SWITCH=02;CMD=OFF;
20;DF;DEBUG;Pulses=50;Pulses(uSec)=870,210,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;E0;DEBUG;Pulses=50;Pulses(uSec)=840,210,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;E1;DEBUG;Pulses=50;Pulses(uSec)=840,180,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;E2;DEBUG;Pulses=50;Pulses(uSec)=840,210,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;E3;DEBUG;Pulses=50;Pulses(uSec)=840,180,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;E4;DEBUG;Pulses=50;Pulses(uSec)=840,180,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;E5;DEBUG;Pulses=50;Pulses(uSec)=840,210,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;E6;DEBUG;Pulses=50;Pulses(uSec)=840,210,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;E7;DEBUG;Pulses=50;Pulses(uSec)=840,180,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;E8;DEBUG;Pulses=50;Pulses(uSec)=840,210,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;E9;DEBUG;Pulses=50;Pulses(uSec)=840,210,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;EA;DEBUG;Pulses=50;Pulses(uSec)=840,180,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
20;EB;DEBUG;Pulses=50;Pulses(uSec)=870,210,210,780,210,780,210,780,210,780,810,180,210,780,810,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,810,180,810,180,810,180,210,780,210,780,810,180,210,780,810,180,210,780,210,6990;
Device 2
20;FF;DEBUG;Pulses=50;Pulses(uSec)=870,210,810,210,810,210,210,780,810,180,210,780,210,780,810,210,210,780,780,180,210,780,210,780,810,210,210,780,810,210,810,210,810,180,210,780,810,210,210,780,780,210,180,780,780,180,210,780,210,6990;
20;00;Eurodomest;ID=016b45;SWITCH=02;CMD=OFF;
20;01;DEBUG;Pulses=40;Pulses(uSec)=270,780,210,780,810,210,210,780,810,180,210,780,210,780,810,210,210,780,810,210,810,210,810,180,210,780,810,210,210,780,810,210,210,780,780,180,210,780,210,6990;
20;02;DEBUG;Pulses=50;Pulses(uSec)=870,210,780,210,810,210,210,780,810,180,210,780,210,780,780,210,210,780,810,210,210,780,210,780,810,210,210,780,810,210,810,210,810,210,210,780,810,180,210,780,810,210,210,780,810,210,210,780,210,6990;
20;03;Eurodomest;ID=016b45;SWITCH=02;CMD=OFF;
20;04;DEBUG;Pulses=40;Pulses(uSec)=270,780,210,780,810,210,210,780,810,210,210,780,210,780,810,210,210,780,810,210,810,210,810,210,210,780,810,180,210,780,810,210,210,780,810,210,210,780,210,6990;
20;05;DEBUG;Pulses=50;Pulses(uSec)=870,180,810,210,810,210,210,780,810,210,210,780,210,780,810,210,210,780,810,210,210,780,180,780,810,180,210,780,810,210,810,210,810,210,210,780,780,180,210,780,810,210,210,780,810,210,210,780,210,6990;
20;06;Eurodomest;ID=016b45;SWITCH=02;CMD=OFF;
Device 3
20;0D;DEBUG;Pulses=50;Pulses(uSec)=930,210,840,210,210,810,840,210,840,210,210,810,840,210,840,210,210,810,840,210,210,810,210,810,210,810,840,210,840,210,840,210,210,810,210,810,840,210,210,810,840,210,210,810,840,210,210,810,210,6990;
20;0E;Eurodomest;ID=024b8d;SWITCH=02;CMD=OFF;
20;0F;DEBUG;Pulses=50;Pulses(uSec)=900,210,840,210,210,810,840,210,840,210,210,810,840,210,840,210,210,810,840,210,210,810,210,810,210,810,840,210,840,210,840,210,210,810,210,810,840,210,210,810,840,210,210,810,840,210,210,810,210,6990;
20;10;Eurodomest;ID=024b8d;SWITCH=02;CMD=OFF;
20;11;DEBUG;Pulses=50;Pulses(uSec)=930,210,840,210,210,810,840,210,840,210,210,810,840,210,840,210,210,810,840,210,210,810,210,810,210,810,840,210,840,210,840,210,210,810,210,810,840,210,210,810,840,210,210,810,840,210,210,810,210,6990;
20;12;Eurodomest;ID=024b8d;SWITCH=02;CMD=OFF;
Dylantje
Re: Kerui cheap chinese pir detector
#2 Post by Dylantje » 05 May 2016, 15:07
And are these workings/ supported?
What is the battery live?
timoline
#3 Post by timoline » 26 Aug 2016, 14:57
Bought the same and looks like i have the same issue
