dht11 can read in easy esp. but not in domoticz
henrybcn
#1 Post by henrybcn » 02 Sep 2016, 18:05
I am fascinated with the easy esp firmware and how easy it is. My relay works perfectly and I can control through domoticz. Now I am trying to connect a DHT11 and for the ESP no issues at all. I can see the temp and humidity through the terminal, but I can not get it to show up in domoticz.
Anyone can help me to set it up? I believe I am doing something very basic/stupid, but already stuck on this for a week.
tks Much!
Henry
jdemas
Re: dht11 can read in easy esp. but not in domoticz
#2 Post by jdemas » 02 Sep 2016, 18:53
did you creat a dummy sensor in domoticz?
please create a dummy device wit temp & hum.
after that is done you have to look witch idx numer he has got this number you have to insert in de device idx in the ESP node
check send data on
and i hope you did configer your domoticz ip adres en port number in the esp.
then it should be working
good luck
henrybcn
#3 Post by henrybcn » 03 Sep 2016, 17:20
tks Jdemas! I did all that. My relay works perfectly and I can also see the values on the ESP + TERMINAL, but not in domoticz. That is what I see in my IDE terminal:
DHT : Temperature: 30.00
DHT : Humidity: 16.00
WD : Uptime 11 ConnectFailures 18 FreeMem 27032
Also on the domoticz console I see a message: Incoming connection from: (MY ESP IP ADD)
But still no way to see the values in domoticz. Any other hint?
henrybcn
#4 Post by henrybcn » 03 Sep 2016, 17:30
ops. just figured out that probably my user was wrong in website protection (domoticz setup). Also changed the authorization to Basic-Auth and everything is working! Tks much! :) The post can be closed
homerruma
#5 Post by homerruma » 11 Mar 2017, 00:44
jdemas wrote: 02 Sep 2016, 18:53
Where to look Domoticz IP address and port?
Where do I type an address in ESPEasy?
Thank you
Users browsing this forum: Ahrefs [Bot] and 28 guests
