Reboot causes
Reboot causes
First I want co congratulate this wonderfull project.
Sometimes my ESP01 is rebooting without any visible reason, so it was be great to know this reason. It is possible to publish reboot causes after boot?
Re: Reboot causes
Have a look at the bottom of the main page on the ESP. There is a boot cause field. I don't think it will tell you what you want to know, as I don't think the system has the ability to diagnose what part of the problem. It will give you "Cold Boot" if you unplug and plug in again, "Manual Reboot" if you reset, and maybe probably something for the watchdog. Watchdog would probably indicate a software issue, and cold boot would probably indicate a power issue. I think that is about all you will get. Not sure what it gives if you short a pin and cause a reboot.
Search and read, you will find a wealth of information...
Re: Reboot causes
Read carefully http://www.esp8266.nu/index.php/Power . All my reboot problems was from power issues.
Pozdrowienia z Tychów
![Lach :)](./images/smilies/icon_e_smile.gif)
Re: Reboot causes
Hi Pawel,pawel3410 wrote:First I want co congratulate this wonderfull project.
Reboots can be troublesome and I have experienced them quite a bit trying to get my system up and running. I currently have 18 ESPs running ESPEasy on my network and they are all working quite well.
What version of ESPEasy are you using? You must assign a unit number between 1 and 30 (unless you have modified the code to allow higher). If you don't this could cause resets. Under Tools\Advanced there is a field called Connection Failure Threshold. The original default value was 30 so if you had 30 MQTT connection failures the ESP would reset. Set this to 0 for awhile and see if your problem gets better.
Did this problem just start with a firmware upgrade or have you always had the issue? I have noticed sometimes when you upgrade firmware the internal storage can get messed up as to any tasks etc that you might have previously set up. The ESP will usually just act weird like fields entered while assigning tasks will not show up (Things like value names etc). If left to run the ESPs will reset a lot. You can go to the tools menu and issue a "RESET" command in the command dialog. This will return the ESP to its default state including making it forget all of the router settings. You will need to re-do all of the settings.
Power is also a big issue. I manufacture several ESP based boards and I routinely use 3.3 volt regulators. (Specifically the LT1129CST-3.3) I get them in bulk from China. I had one batch that looked and smelled and for the most part acted like the LT1129CST-3.3 but when asked to provide more than 200ma they would drop down to 1.5 volts. Naturally this caused a reset. Make sure your power supply can really output at least 600ma. Add the caps to your circuit just like the blog post suggests and others have pointed you towards.
Is your circuit switching relays on and off? Does it reset occasionally when the CPU tries to close the relay? If so you might have some power spiking when the coil is energized. This can be handled by putting a larger power supply. You can try to put a very large capacitor across you power and preferably do not try to energize the coil with the same power rail that's providing power to the CPU.
Tell us more about your circuit!
I hope this helps
Best regards
Dave
Re: Reboot causes
My problem is little complicated. I have one ESP12 with 108 espeasy version. Connection Failure Threshold is set to 0. I set static IP and connect to router with WIFI. Everything is ok (so supply is ok) until connecting raspberry pi3 with wire to router. ESP is start rebooting after 1-5 minutes and I dont know what is the reason. What is must to be done to reboot ESP without reboot command?.
Re: Reboot causes
Is your static IP address within the DHCP address range? Is your RSPi also a static IP? Could they be the same address?
Can you set the Serial logging to level 4 and connect to the ESP via USB and a terminal program? Watch the logging and see if you get any clue there.
Dave
Dave
Re: Reboot causes
Static IP in esp12 and raspberry is outside DHCP range and they have different address. esp12 is only one device connected to wifi. Today I will try connect another esp12 with serial terminal and watch logs.
Re: Reboot causes
I have this when device is in reboot loop :/
And sometimes this:
Fatal exception 9(LoadStoreAlignmentCause):
epc1=0x40227e85, epc2=0x00000000, epc3=0x00000000, excvaddr=0x3ffeecfd, depc=0x00000000
Exception (9):
epc1=0x40227e85 epc2=0x00000000 epc3=0x00000000 excvaddr=0x3ffeecfd depc=0x00000000
ctx: sys
sp: 3ffffda0 end: 3fffffb0 offset: 01a0
>>>stack>>>
3fffff40: 40227e65 00000000 00000001 00000100
3fffff50: 4022a4bf 3ffeecb0 00000040 00000001
3fffff60: 3ffe8004 00000006 00000000 3ffee7b4
3fffff70: 3ffee2c0 40226abf 00000006 00000000
3fffff80: 3ffee2c0 402264b6 3fffdab0 00000000
3fffff90: 3fffdcc0 3ffeaab0 00000000 40222957
3fffffa0: 3ffeaab0 40000f49 3fffdab0 40000f49
<<<stack<<<
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
ŞU
INIT : Booting Build nr:108
bcn 0
del if1
usl
add if1
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
bcn 100
bcn 0
del if1
usl
mode : sta(18:fe:34:d5:a2:cc)
add if0
IP : Static IP :192.168.1.202
WIFI : Connecting... 1
f r-1, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
ŞU
bcn 0
del if1
usl
add if1
bcn 100
bcn 0
del if1
usl
add if0
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
Re: Reboot causes
Hi Pawel,
The first log has the Fatal Exception 9 issue. I have seen this many times when I have had power issues. That is exactly what mine did when I had the bogus voltage regulators. Do you have an oscilloscope? I would put a scope probe on the +3.3V rail and watch it. You might need to trigger properly to see it. You might find a significant dip in the supply voltage when the processor tries to transmit. You also might try hanging a really large capacitor on the 3.3V rail. Try 1000uf and see if the problem improves.
regards
Dave
regards
Dave
Re: Reboot causes
Power, Power and more power.
In my experience there is only two power related issues that cause units to reboot.
1. The most important one - CLEAN Power.
Make sure your power on the unit is "Clean". I always put an inductor inline with the micro controller supply pin with a 100nF cap as close to the supply pin as possible. You can now buy a unit that has both in one three pin module.Bad or "dirty" power is most often the cause of random reboot.
2. Current, or the lack there of.
Many designs under estimate the power requirements and try to get away with the minimum. This is most often the cause of reboot.
Re: Reboot causes
Hi zodiac69, re
"inductor inline with the micro controller supply pin with a 100nF cap as close to the supply pin as possible. You can now buy a unit that has both in one three pin module"
Could you guve us a link to an example unit, say on eBay?
Re: Reboot causes
Like you say it was a power supply problem. ESP was powered from mini360 3,3V module and other mini360 5V was for contactors. Now one mini360 5V is for contactors and from this AMS1117 3,3V for ESP. For now reboot problem is gone;)
