More support for i2c modules/sensors [UPDATED 25.09.2016]
Hi there,
Is there any chance to add more i2c modules/sensors like on my list bellow?
I found a few of them on AliExpress and they seems to be wort for adding them as new plugins/devices.
These are just my toughs, but maybe someone will like the idea too, because I'm using the ESP-01 and ESP-01S modules with 1Mb, and you know, there only two data line available!
1. LM75A High-Speed Temperature Sensor
https://www.aliexpress.com/item/LM75A-T ... 27860.html
2. SI1145 UV IR Visible Sensor
https://www.aliexpress.com/item/SI1145- ... 05707.html
3. APDS-9960 RGB and Gesture Sensor Module
https://www.aliexpress.com/item/GY-9960 ... 14031.html
4. RTC DS1307 AT24C32 Real Time Clock Module
https://www.aliexpress.com/item/2016-Ne ... 35694.html
5. MCP4725 I2C DAC Breakout Board 12-Bit DAC w/I2C Interface
https://www.aliexpress.com/item/1pcs-MC ... 78308.html
6. MPR121 Breakout v12 Capacitive Touch Sensor Controller Module
https://www.aliexpress.com/item/New-MPR ... 32709.html
7. TCA9548A 1-to-8 I2C 8-way Multi-Channel Expansion Board
https://www.aliexpress.com/item/CJMCU-9 ... 64206.html
8. ADS1110 16-bit ADC with Onboard Reference
https://www.aliexpress.com/store/produc ... 96465.html
To be continued...
To be continued...
Re: More support for i2c modules/sensors
@ beic
You did not do your homework very well.
ADS1115 is already supported since version R60.
Support for clock boards like DS1307 and DS3231 is pretty useless because over WiFi you can connect to a NTP timeserver, much more accurate than a DS1307.
Sorry, I didn't see it! I will remove it!costo wrote: You did not do your homework very well. ADS1115 is already supported since version R60.
I just tough, for that to be able to display the current time and date on OLED 128x64 Display with ESP Easy.costo wrote: Support for clock boards like DS1307 and DS3231 is pretty useless because over WiFi you can connect to a NTP timeserver, much more accurate than a DS1307.
Thank you!
EDIT: Ahh, I found it under menu TOOLS > ADVANCED ... Use NTP and NTP Hostname (optional: Timezone Offset), but there is only TIME shown on MAIN menu, I tough that the DATE will appear too!
Re: More support for i2c modules/sensors [UPDATED 25.09.2016]
The APDS-9960 would be really interesting:
https://youtu.be/A3QRyixnEl8
The REAL question here is, what's keeping you from:
- Buying the sensor from Ali
- Build a plugin for it
- Test the plugin
- Publish the plugin
It's always easy to ask others to do your work...
it was enough to look at GitHub to see there's already a plugin unde development in the dev11 release --> _P064_APDS9960.inovibrog wrote: ↑24 Aug 2017, 12:14 The APDS-9960 would be really interesting:
If we all build just ONE plugin, we'll have a plugin library spanning all sensors...papperone wrote: ↑24 Aug 2017, 19:46it was enough to look at GitHub to see there's already a plugin unde development in the dev11 release --> _P064_APDS9960.inovibrog wrote: ↑24 Aug 2017, 12:14 The APDS-9960 would be really interesting:
Chill people I am sure you both contribute to best you can. It's not a competition... not everyone has same abilities/time to spare/energy, everyone to their abilities.
Users browsing this forum: Bing [Bot] and 131 guests
