Hi all
Hi all
My name is remco.
I live in the netherlands and love domotica.
admin @ domoticz forum and a newbie in the world of esp arduino etc.
I'm a little bit lost in world of arduino and esp with all the versions, options and boards
And still looking for the best way to go.
for sensors connected to domoticz I think EasyESP it is.
mysensors software has more options (act as gateway, lots of sketches etc) but not as easy..
So I'm here to learn, test and having fun with elektronics..
Re: Hi all
5xESP-01 - 3xESP-12 - 2xESP-12E 3xRPIb+ - 1xBPIm1 - 3xACTi DOME - 7xACTi Indoor cam. Lot off cisco equ.
Re: Hi all
Strong advice to all new users: Buy a NodeMCU V1 devboard to get you started for about 8 dollars on eBay...remb0 wrote:I'm a little bit lost in world of arduino and esp with all the versions, options and boards
Just plugin to USB, get the CP2102 serial driver and soon you will have your first ESP Easy running.
For production, you could use cheaper models without the USB.
Better focus on boards using the 4MB Flash instead of 512K on earlier versions.
If you buy the ESP01, there are newer versions (seen with black color pcb) that have 1MB flash.
Flash size will become more important because of the growing size of SDK + IDE Package + sketch. And the next release of ESP Easy will start to use the SPIFFS file system. (ESP01 has only 64kB left for SPIFFS, ESP12E can use 3MB!)
Re: Hi all
Thank you for your recommendation .
What is the difference between nodeMCU V1 and V2 ?
How do we know if they come with 4MB of flash. Or do we just assume they do ?
Many thanks.
James.
Many thanks.
James.
Re: Hi all
They should be addressed as V0.9 and V1.0.Foggy wrote:Thank you for your recommendation .
Many thanks.
James.
Changes on V1 are different USBSerial chip, smaller footprint and ESP12E module with a larger flash memory chip.
This is how the V1.0 version looks like:
This is how the V0.9 looks like:
Re: Hi all
http://nl.aliexpress.com/item/NodeMcu-L ... 97795.html
china has also an improved version of the 1.
Re: Hi all
I think this is also the version based on the devkit 1.0 schematics. As far as I know, this is the official Node MCU devkit website:remb0 wrote:http://nl.aliexpress.com/item/NodeMcu-L ... 97795.html
https://github.com/nodemcu
https://github.com/nodemcu/nodemcu-devkit-v1.0
You will find the schematics in pdf with versions devkit 0.9 and devkit 1.0.
But by others they are also referred to as V1 and V2 version boards.
I think that the black colored board is always the 1.0 with 4MB Flash on a ESP12E module.
The older one is a blue or yellow colored board.
Re: Hi all
I have postet a link that shows the moduls
