This unit is now "officially" supported by ESP Easy: https://www.letscontrolit.com/wiki/inde ... ff_DIY_4chstofakiller wrote: ↑21 Sep 2017, 15:07 Hi,
I have a 5-32v Sonoff/Itead 4ch, but i cant figure out how to flash it. I have flash many types of Sonoff's, i have Sonoff POW, normal 1ch Sonoffs and bulbs... I have triede both thrue my Arduino to flash it and also tried to erase it with ESP_Basic_Flasher... I always get cant open the port. Anyone triede or have any suggestions?
Sonoff 4CH with ESPEasy
Re: Sonoff 4CH with ESPEasy
Any chance of formal support for the Sonoff Pow? Looks like a very handy little device to help understand power consumption...
Since Tasmota is supporting that device it should be possible to write a plugin for ESP Easy as well. If you do some research on the subject and bring all your findings and suggest a enhancement on GitHub someone might pick up the idea.
There's already a long thread about sonoff pow in the forum.
http://www.letscontrolit.com/forum/view ... POW#p20950
I noticed, and managed to read half way through it.Shardan wrote: ↑12 Dec 2017, 20:10There's already a long thread about sonoff pow in the forum.
At some point the discussion drifted off towards liability and how people will try to electrocute themself.
I was hoping to find a firm "yes" or "no" answer to the support question, or (if that can't be given) perhaps a careful "maybe in the near future"...
Ah, yes...grovkillen wrote: ↑12 Dec 2017, 17:04Since Tasmota is supporting that device it should be possible to write a plugin for ESP Easy as well. If you do some research on the subject and bring all your findings and suggest a enhancement on GitHub someone might pick up the idea.
Unfortunately I am more of a tester than a developer these days... I'm sure I would eventually even be able to write a plugin, but the learning curve would be a bit steep!
But you can always do something, like finding places where to find more information etc. Links are valuable assets.manjh wrote: ↑12 Dec 2017, 20:48Ah, yes...grovkillen wrote: ↑12 Dec 2017, 17:04Since Tasmota is supporting that device it should be possible to write a plugin for ESP Easy as well. If you do some research on the subject and bring all your findings and suggest a enhancement on GitHub someone might pick up the idea.
What do you mean? I already wrote a plugin to support POW current/voltage reading feature.
The relay and led can be activated with standard plugin, what else you need?
you just made my day!
This information is probably somewhere in the seond half of that long thread, which I have not read yet. I also checked the Wiki, found a number of Sonoff products that are supported but did not see any reference to the pow.
Can I assume the plugin is in Github?
Yes, it's in the playground still but fully functional...manjh wrote: ↑13 Dec 2017, 08:45you just made my day!
Great. Now I will have to figure out how to get it from that "playground", and compile....papperone wrote: ↑13 Dec 2017, 17:34Yes, it's in the playground still but fully functional...manjh wrote: ↑13 Dec 2017, 08:45you just made my day!
For the time being, I am using the Sonoff with their app. Works great, but not integrated with other devicecs via Domoticz.
I have managed to operate the sonoff 4ch correctly, with ESP, what I do not get is that none of the physical buttons work.
You need to create rules for that.
Example:
On TurnOn1 do
gpio, 12, 1
On TurnOff1 do
gpio, 12, 0
On TurnOn2 do
gpio, 5, 1
On TurnOff2 do
gpio, 5, 0
On TurnOn3 do
gpio, 4, 1
On TurnOff3 do
gpio, 4, 0
On TurnOn4 do
gpio, 15, 1
On TurnOff4 do
gpio, 15, 0
on Toggle1 do
if [relais1#state]=1
Event TurnOff1
Event TurnOn1
on Toggle2 do
if [relais2#state]=1
Event TurnOff2
Event TurnOn2
on Toggle3 do
if [relais3#state]=1
Event TurnOff3
Event TurnOn3
on Toggle4 do
if [relais4#state]=1
Event TurnOff4
Event TurnOn4
on button1#state do
Event Toggle1
on button2#state do
Event Toggle2
on button3#state do
Event Toggle3
on button4#state do
Event Toggle4
sorry ..., I had not restarted the sonoff.
now it works, but only the first time it turns on and off, then I press the button and it does not do anything
this is the rule
On Channel1#Switch do
if [Channel1#Switch]=1
event,Channel1_On
event,Channel1_Off
On Channel2#Switch do
if [Channel2#Switch]=1
event,Channel2_On
event,Channel2_Off
On Channel3#Switch do
if [Channel3#Switch]=1
event,Channel3_On
event,Channel3_Off
On Channel4#Switch do
if [Channel4#Switch]=1
event,Channel4_On
event,Channel4_Off
on Channel1_On do
gpio,12,1
inputswitchstate 0,1
on Channel1_Off do
gpio,12,0
inputswitchstate 0,0
on Channel2_On do
gpio,5,1
inputswitchstate 9,1
on Channel2_Off do
gpio,5,0
inputswitchstate 9,0
on Channel3_On do
gpio,4,1
inputswitchstate 10,1
on Channel3_Off do
gpio,4,0
inputswitchstate 10,0
on Channel4_On do
gpio,15,1
inputswitchstate 14,1
on Channel4_Off do
gpio,15,0
inputswitchstate 14,0
What version of ESPeasy?
I recently (last week) fixed an issue with the switch plugin.
In the first piece of code, you're checking on the state of the switch. Should be the state of the gpio.
I just put the last update today, I'll try it
nothing, with the new update they do not work either
Is there an IO-mapping for the Sonoff 4CH PRO available?
Thanks for help...
Thanks for help...
in the end I got it, thanks
at first pressing the button would turn on, but turning it off at the time it was turned on again.
After several tests I got it to work changing "normal switch" to "push button active low"
these are the rules that you create
now all switch works fine, I just need to try it with my veraedge
on Boton1#Switch do
if [Boton1#Switch]=1
gpio,12,0
gpio,12,1
on Boton2#Switch do
if [Boton2#Switch]=1
gpio,5,0
gpio,5,1
on Boton3#Switch do
if [Boton3#Switch]=1
gpio,4,0
gpio,4,1
on Boton4#Switch do
if [Boton4#Switch]=1
gpio,15,0
gpio,15,1
I tried to find the GPIO IO-mapping for the 4CH Pro using HTTP commands. At GPIO-6 relay one got on but I could not switch it off again. Tried also to switch on GPIO 4 and 5. Then I could not connect to the GUI any more and now the 4CH Pro is in a boot-loop:
When I change the onboard "Work Mode Switch" from "Interlock" to "Self-locking/Inching" it's still in a loop but the boot mode changes to (3,2). Also the top 3 LED are on.
Installed software v2.0-20180123, no change.
What to do? Is there a "GPIO of death"?
Thanks for some help.
INIT : Booting version: v2.0-20180120
INIT : Cold Boot
FS : Mounting...
FS : Mount successful, used 75802 bytes of 113201
INIT : Free RAM:26000
INIT : I2C
INIT : SPI not enabled
WIFI : AP Mode disabled
WIFI : AP Mode ssid will be ESP_water_0 with address 192.168.4.1
WIFI : Connecting XXXX attempt #1
WIFI : Connected! IP: 192.168.10.35 (ESP_water_0)
ets Jan 8 2013,rst cause:4, boot mode:(3,0)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
⸮U
INIT : Warm boot #1
FS : Mounting...
INIT : I2C
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
⸮U
Sonoff 4CH Pro:
GPIO mapping is the same. All K5 switches should be set to "on", the S6 switch to 1. Then it works like the standard one.
Hello All,
I have this scheme wiring: http://prntscr.com/i0qrfb
I used homebridge plugin and iphone app HOME and I have problem about inform state.
Example:
1. State Lights on HOME app is OFF.
2. Turn on Lights with HOME app on R1 relay, snd Sonoff PRO switch reley and Lights is ON. On app HOME change state to ON.
3. When I pressing physical key "WALL SWITHC" Disconnect Electric Cricuit and turn off Light.
State continue ON on HomeAPP.
How to inform app that state is change?
Is there firmware has this possibility?
Rade
Example:
Rade
- Methuselah
Greetings folks.
Has anyone attempted to solder an I-PEX connector on PSF-A's wifi antenna solder traces?
I need to install my Sonoff outside, in a weatherproof electrical enclosure which will attenuate the wifi signal. I can drill a hole and install an SMA barrel connector, and place an wifi antenna on the exterior of the enclosure, and run a I-PEX cable to the Sonoff, but need to solder a I-PEX female connector to the PSF-A board
Assuming this will work... wondering if anyone has tried it.
N00b to the world of ESPEasy, but I've been programming since the days of punch cards and paper tape
I-PEX and PSF-A
Could this solve you problem?
https://nl.aliexpress.com/item/1set-2-4 ... 04091.html
- Methuselah
Pretty much what I was going to do...
but requires the male connector soldered to the traces on the chip...
was wondering if anyone has attempted or done it already. I've ordered everything I need off amazon, should be here friday.
- Methuselah
Was a little tough to get the I-PEX connector soldered on (I had to order a different set of tips for my Weller), but I managed to do it, and it works great. After soldering on the connector, you can check if it is seated correctly by testing connectivity between the antenna pin (marked in red) and the center conductor on the I-PEX connector. The outer ring connects to ground, so just test connectivity between it and any ground on the motherboard. I connected a pigtail and secured it with some hot glue to the motherboard so it would not work itself loose. I then drilled a hole through the side of the Sonoff case and mounted the SMA connector. I connected a spare wifi antenna, but, when I mount it in the electrical enclosure outside, I will use an SMA extension cable through a drilled hole in the enclosure itself and mount the antenna on the outside of the cabinet.
Good job!
Yes, looks very sharp. Good job!
- Methuselah
Final installation:
left-upper unit is wired to a 4-port VHF antenna switch on my tower, which uses 12vdc on 3 different pins to select which port (no voltage = port 1). I've programmed it to accept different commands to select which port on the switch to choose, e.g. /ip/control?cmd=event,Antenna3 will flip relay 3 to select port 4 on the switch.
upper-right unit is wired to an 8-port HF antenna switch (Ameritron RCS-10) which uses 12vdc BCD logic on 3 pins to select a port (000 = port 1, 111 = port 7, etc.) Again, programmed some commands, e,g, /ip/control?cmd=event,Antenna4 to turn on and off the appropriate relays via GPIO to select the correct port.
This allows me to run 2 line of Andrews LDF6-50 (~250' each) from my shack to the tower base, rather than a different run for each antenna (mega $$$$ - $10+/foot), and I can select which antenna I want to operate off of via a web command.
The bottom sonoff is used to control a winch to automatically raise and lower the tower fixture (a TX-455 crank up, retrofitted with a KF9P hoist plate and harbor freight 2000 lb hoist (see https://www.youtube.com/watch?time_cont ... TQiq-WGNFE). One relay is used to power on and off the hoist w/ 120vac (switching the hot wire), and two relays are used to select up or down motion (by directing current to one of two wires).
And the sonoff's are not interfering with the antenna signal itself?
Hope you're not switching to much current with these sonoffs. Even though they are rated for up to 10 Amps (some even 16 Amps), I wouldn't let them switch currents even half those limits.
- Methuselah
No. They switch relays which control an RF path from an input source to an output port. No RF travels through the Sonoff. It simply provides a 12vdc current source to the switching relays (not the unit I have, but along the same principle):
The antenna switches themselves use about 1/3rd of an amp to control the switching logic. The hoist uses a couple of amps to raise and lower the tower -- the hoist is significantly oversized for my application, but that's what the manufacturer of the hoist plate recommends (he sells one plate which will work with towers ranging from 40 to 90 feet, so the hoist in question is really designed for a tower twice the height of mine.) I expect it to draw about 3-5 amps maximum.Hope you're not switching to much current with these sonoffs. Even though they are rated for up to 10 Amps (some even 16 Amps), I wouldn't let them switch currents even half those limits.
Hi all!
I'have flashed Sonoff 4ch with EspEasy v2.0-20180322, connected to domoticz and all works very well.
I connected a Pulse counter (TCRT5000 https://it.aliexpress.com/item/Free-shi ... lsrc=aw.ds) to GPIO2 on the board and followed the wiki https://www.letscontrolit.com/wiki/index.php/LJ12A3 but it doesn't work. Anyone can help? Thank you
What task number is the pulse counter on? Only 1..4 is allowed.
Ok now with task 4 it reads the values...
but if I power cycle Sonoff it does not boot up if the tctr5000 Digital Output is connected to GPIO2..
If I connect TCTR to GPIO2 after the sonoff is boot up, all works.
What can I do?
Thank you
What can I do?
Thank you
https://www.letscontrolit.com/wiki/inde ... figuration
It need to be high on boot so please see if it's possible to activate a pull-up or you might need to fix a external pull-up.
I soldered a 4.7k resistance between 3.3v and gpio2 but it does not work.
I tried to use the gpio13 of the led of the wifi but during the start the relay 4 turns on and off immediately ..
Where did I go wrong?
Can you measure what the TCRT5000 is delivering to GPIO 2? I mean, can it be that it pulls the voltage down still even with the pull-up?
I'm no electronics guy so I'm just throwing stuff here...
I'have found out that if I cover the IR led during the start up of sonoff it doesn't boot up (green led of TCRT is on) DO on tcrt is 3.3v .
If I don't cover it (green led on tcrt is off) DO on tcrt is 3.3v than Sonoff boot up...
But it's always green and it's off when it pulse.. so the problem persist..
I have connected DigitalOutput to the Sonoff but I have also an AnalogicOutput..
That's all. Thank you for support
Ah, yes I always cover the IR led if I'm not using it as a signal. Great, I had my thoughts that something like that was going on
EDIT: or am I misunderstanding you (feels like it)?
yes, you misunderstood me, sorry for my little English
as an experiment I cover the two Led and if they are covered the esp doesn't boot, if they are not covered the esp boot up.
so I misured DO signal.. it's 3.3v if the led is covered and 0v if it's free..
I use the tcrt to read the number of spins of an old water meter
Just to be sure... it is just about the LEDs on the Sonoff 4ch, without any other components added?
A LED may act as a "solar panel".
You can verify this with a multimeter and a LED. Any led will work.
The voltage generated by the LED can be > 2V, depending on the color of the LED.
With the slightest load the voltage will drop to 0, since power generated is low, but on a high impedance input it may set some input off.
Activating a pull-up resistor may help then.
Hi all,
i am using the sonoff 4ch now for half a year with the default software, but i don't like that my switch is controlled via internet.
can i use ESPEasy to switch the 4 channels on/off? or does ESPEasy need to be controlled via a server/broker/MQTT?
I am looking for a solution to just have an app or webpage on my android phone to switch the 4 channels on or off. for now that would be all, who knows maybe later i will also use a broker or what ever.
I successfully loaded ESPEasy on it, but whats next, i dont see a page to control the switches, anybody a sugestion for this NOOB?
Thanks in advanced,
btw, i installed the ESPEasy_R148a_1024.zip posted by Shardan on page 4
Thanks in advanced,
Users browsing this forum: Ahrefs [Bot] and 0 guests
