Page 3 of 3
Re: Pulse Counter P003 enhancement. How to give back?
Posted: 06 May 2021, 21:23
As you may have seen, there was quite a delay between the last nightly build and the one before (> 2 months, which is exceptionally long)
This was mainly because of issues with build size.
I also did not want to change too much things at once (failed on that one a bit....) so I can merge your PR so it can be tested a bit more before the next build is made.
If Ton does not have any objections, I will merge it.
Posted: 06 May 2021, 22:21
by Ath
TD-er wrote: 06 May 2021, 21:23 If Ton does not have any objections, I will merge it.
I don't mind, but I haven't used / tested it, so actually can't object if the code seems stable ;)
Posted: 08 May 2021, 16:29
by GravityRZ
i am using the new P003 enhancement for quiet some time now (build 0411) and can tell that it has been very stable
I use it in a production environment (watermeter)
@TD-er
if you merge it please point me to the location so i can download it.(assuming you do not create a new release)
Posted: 15 May 2021, 11:01
by rron
@gravityRZ,
Where can I find this 0411 build? Or is this already in the stable release?
Posted: 15 May 2021, 22:04
by GravityRZ
i downloaded the 0411 version as a beta.
the current 0503 release does habe the new P003 enhancement but somehow this is a very old version.
you are better of downloading the 0223 release
i attached the 0411 release in case you want it.
let me know if you need a different one
ESPEasy_normal_ESP8266_4M1M.zip
(2.23 MiB) Downloaded 206 times
Posted: 16 May 2021, 11:54
by rron
Thanks, I will try this version and let you know.
Posted: 16 May 2021, 12:58
by rron
GravityRZ wrote: 15 May 2021, 22:04 i downloaded the 0411 version as a beta.
Hi GravityRZ,
What settings are you using and is giving the best results?
Posted: 16 May 2021, 15:54
by GravityRZ
at the moment i am using 88ms when using pulse low
it al depends on how long the signal is low
if this time is very short then you also need a short debounce time, roughly 1/10 of the time the signal is low.
in my situation i use it for a watermeter.
this can have a flow of 0-25 liters a second so this affects the pulselow time also
you want to have a debounce time which will work when the flow is low but also still works when the flow is high
Posted: 16 May 2021, 22:30
by rron
GravityRZ wrote: 16 May 2021, 15:54 at the moment i am using 88ms when using pulse low
Ok thanks I will start with your setting and let you know.
Posted: 22 Jun 2021, 09:37
by mdax82
Also using the "0411" build with a bk-g4 gas meter. Works quite nicely - the false counts I had previously are gone and the debug output gives a lot of insight. Great job thanks!
