Page 1 of 5
Re: Connecting a TM1637 4-Digit Display
Posted: 10 Oct 2017, 23:08
by freijn
ronald wrote: ↑10 Oct 2017, 11:34
O, that's great! I really want to try it.
I must admit that I don't know how to test it though. I know how to flash my unit and how to upgrade to new versions/ test versions of the software, but I have never added a new plugin.
I can't find how to do it... Can you tell where to find that?
Same problem here
I have found the plugin
https://github.com/letscontrolit/ESPEasy/pull/534/files
No idea about the next step , is there a how to plugin wiki ? link?
Posted: 11 Oct 2017, 09:49
by papperone
I will post BIN later today with dev12 plus this plugin; I will compile only for 4096 module if ok for you....
Posted: 11 Oct 2017, 09:52
by ronald
Great, Papperone!
4096 is ok for me.
Posted: 11 Oct 2017, 13:22
by papperone
here it is! please let me know your feeback...
Posted: 11 Oct 2017, 14:22
by ronald
Hi Papperone
I already tried the device (a TM1637) and for me it is working great!
I tried these modes:
clock blinking
clock not blinking
date
manual command 7dn
7dn,-1000 = ----
7dn,-999 = -999
7dn,9999 = 9999
7dn,99999 = ----
manual command 7dt
- positive number gives me "22:2o" (with the degree symbol in the upper half of course!)
- negative number gives me "-10o"
Display output is working ok.
I would welcome commands to switch the device on or off, like the LCD has.
I tried it on a Witty Cloud version of the esp8266, which is a bit of a pain in the b*t, because so many of the I/O pins are already taken, but my other device were not available.
I hooked it up to D0 (DIO) and D4 (CLK) and that worked.
Thanks for your effort!
Posted: 11 Oct 2017, 17:09
by papperone
Thanks Ronald, probably you should read this previous comment -->
http://www.letscontrolit.com/forum/view ... =30#p19744
You have already "7don" "7doff" and "7db,<brightness>" commands implemented...
Posted: 11 Oct 2017, 20:03
by ronald
Ah, missed that one! I'm really happy with the result
Posted: 12 Oct 2017, 12:19
by freijn
Downloaded ...
I try to open it with WinRar, but it throws an error... How do I uncompress is??
MANY THANKS !!!!
Frank
Posted: 12 Oct 2017, 17:37
by papperone
freijn wrote: ↑12 Oct 2017, 12:19
Downloaded ...
MANY THANKS !!!!
Frank
no idea, I tryed myself to donwload and open it and I got no errors; as well ronald download and installed it without issue it seems...
Posted: 12 Oct 2017, 19:10
by grovkillen
Posted: 12 Oct 2017, 19:38
by ronald
I used the free utility UnRAR. Worked like a charm.
Posted: 12 Oct 2017, 20:38
by papperone
I have WinRAR full license and it works as I wrote...
Posted: 12 Oct 2017, 21:33
by freijn
Ok will try zip7.
Cheers
Posted: 13 Oct 2017, 23:52
by grovkillen
Will
dot matrix displays powered by MAX7216 be supported? Just curious.
Posted: 14 Oct 2017, 00:31
by papperone
it's in my "to-do" list but probably as a separate plugin as this matrix led can be more flexible and customizable
Posted: 14 Oct 2017, 06:29
by grovkillen
Drool! You're awesome!
Posted: 14 Oct 2017, 10:19
by Shardan
+1
Posted: 16 Oct 2017, 11:24
by freijn
Guys,
Sorry for the stupid questions....
How do you know how to connect the display ?
Is there a how-to page where I can find how to compile a plugin into easyesp ?
I have the tm1638 ,would that work as well? At least the display?
p.s.
with the zip7 I managed to unpack. THanks !
Frank
Posted: 16 Oct 2017, 11:27
by papperone
freijn wrote: ↑16 Oct 2017, 11:24
Guys,
p.s.
Frank
I guess not as plugin has been written using the TM1637 datasheet for the implementation.
I don't have a TM1638 handy but looking at google it seems a fair different module with 8 digits, 8 buttons and 8 LEDs...
Posted: 17 Oct 2017, 12:19
by freijn
Hey Papperone
First, many thanks for your great work here!!
Do you know, is there a wiki or good place to start to get a plugin compiled in EspEasy ?
I have seen the developers wiki , but nothing on Plugin's
Somehow I can't get started.
Again, many thanks for your work here
Frank
Posted: 17 Oct 2017, 13:52
by grovkillen
I will make a wiki that is a simplified version of the development wiki.
Posted: 17 Oct 2017, 16:34
by freijn
You are all GREAT people !
Thanks !
Posted: 17 Oct 2017, 16:53
by papperone
freijn wrote: ↑17 Oct 2017, 12:19
Hey Papperone
Frank
If you need this plugin only you can find the BIN of 2.0.0dev12 with P073 attached in one of my previous posts.
About how to complie plugins, if you are familiar with Arduino IDE or PlatformIO it's just a matter to copy the file into the main folder of ESPEasy source files and open it from there in order to complie (assumign you have all the libraries with the right version installed of course
Posted: 17 Oct 2017, 21:26
by grovkillen
I just added a section to the official Platformio wiki.
https://www.letscontrolit.com/wiki/inde ... ed_plugins
Not alot but essentially its not that much different from compiling the official FW.
Posted: 17 Oct 2017, 23:07
by freijn
cheers!!!!
Will try this tomorrow.
Frank
Posted: 17 Nov 2017, 19:59
by ronald
I'm trying to get the temperature from a sensor that's on the same ESP.
I have never used rules before, just don't know how to get them working.
Anyway, I tried and did this:
- Switch the TM1637 to manual mode
- The Temparature sensor is called 'TempPres'
- I switched on rules and created this rule: on TempPres#Temperature do 7dt,[TempPres#Temperature]
- Does nothing....
When I send a http command it works fine, so obviously there is something wrong. But what? Who can tell me how to do it. And can it be done anyway?
I could send the value I get from Domoticz back to the esp, but I hope to get it done with rules this time.
Posted: 17 Nov 2017, 20:13
by grovkillen
Send screenshots.
Posted: 17 Nov 2017, 23:41
by ronald
Posted: 18 Nov 2017, 08:09
by grovkillen
Seems correct. What does the log look like? Does it trigger at all?
Posted: 18 Nov 2017, 08:31
by ronald
No, nothing happens. The display stays dark. When I send a command by http it works.
Posted: 18 Nov 2017, 08:34
by grovkillen
Try this rule:
On TempPres#Temperature do
EndOn
Your code should work but just as a test.
And please send a log file screenshot for us to see.
Posted: 18 Nov 2017, 12:14
by ronald
It works!!!
The EndOn must have been the problem.
Or maybe the style of coding.
Anyway, it works now and I'm very glad it does.
Thank you for your help!
Posted: 18 Nov 2017, 14:39
by grovkillen
I updated the wiki accordingly. Thanks for feedback!
Posted: 02 Dec 2017, 23:33
by grovkillen
Posted: 03 Dec 2017, 00:01
by papperone
Great Job grovkillen!
As far as I've one running since more than a month without issue I woudl consider to move this to
NORMAL instead of
TESTING but I'd like to have at least some confirmation of stability from other users who maybe using it permanently on their devices...
Posted: 03 Dec 2017, 00:03
by grovkillen
Papperone, thanks!!
I've been using it for a day now
I do miss some log output though. And as I asked on GitHub, is the 4 digit display with dots also supported or is it only the "clock" version?
Posted: 03 Dec 2017, 09:27
by papperone
grovkillen wrote: ↑03 Dec 2017, 00:03
Papperone, thanks!!
Let me know which LOG and I'll add them and will evaluate to move to NORMAL plugins...
As per GitHub discussion I will add more displays support to the next release of the plugin (once they will arrive from China
Posted: 03 Dec 2017, 10:58
by grovkillen
papperone wrote: ↑03 Dec 2017, 09:27
Papperone, thanks!!
When I add numbers manually the log is not populated with this. Commands 7don, 7doff and 7db,<value> are not reported. Just that stuff
Posted: 03 Dec 2017, 12:43
by papperone
grovkillen wrote: ↑03 Dec 2017, 10:58
Papperone, thanks!!
Ah ok, that's simple... I normally use logs only during developping/testing then I remove them to optimize but you are right, you can always change logs level/reporting from the advanced settings
I will add it soon and submit a PR
Posted: 03 Dec 2017, 12:52
by grovkillen
Great!
Posted: 03 Dec 2017, 15:35
by grovkillen
Is it possible to have the plugin handle multipel devices (four maybe) add the rotary encoder plugin for example?
Posted: 03 Dec 2017, 17:30
by papperone
grovkillen wrote: ↑03 Dec 2017, 15:35
not sure I understood... you want the plugin to control like 4 displays and change the contents using a rotary encoder?
can you clarify?
Posted: 03 Dec 2017, 17:43
by grovkillen
No, I want to be able to use more than one display together with one esp. The rotary we just used as an example, sorry for not being clear.
Posted: 03 Dec 2017, 17:48
by papperone
grovkillen wrote: ↑03 Dec 2017, 17:43
ok you are right, I still need to figure it out why multiple istances of same plugin make the ESP unstable; while adding the LOG will try to understand it...
Posted: 03 Dec 2017, 17:54
by grovkillen
papperone wrote: ↑03 Dec 2017, 17:48
Thanks, and yes, it's an overall problem with ESP Easy. We need to try to find the root cause of the instability.
Posted: 26 Dec 2017, 14:50
by sentinel
Hi guys,
I am fairly new to EspEasy. I was also looking for a way to use a TM1637 display, so I wanted to thank Papperone for the work!
Happy New Year to all!
Posted: 28 Dec 2017, 13:43
by papperone
sentinel wrote: ↑26 Dec 2017, 14:50
Hi guys,
Thanks and Happy New Year!!!
PS: my new displays to expand this plugin are still "in transit" from China; hope to getit soon and be able to release new version of plugin!
Posted: 28 Dec 2017, 14:58
by sentinel
I have added a timer on the rules. When the module boots, I get the following:
5236 : WIFI : Connected! IP: <IP> (<name>)
5331 : EVENT: System#Boot
5336 : ACT : timerSet,1,5
5402 : FS : Error while reading/writing config.dat in 926
5502 : WD : Uptime 0 ConnectFailures 0 FreeMem 22808
5518 : EVENT: Clock#Time=Thu,15:39
7339 : DS : Temperature: 41.50 (28-ff-37-e2-0-17-3-b3)
7339 : EVENT: DSTemp#Temperature=41.50
7404 : ACT : 7dt,41.5
17976 : EVENT: Clock#Time=Thu,15:40
And the timer never expires. Can this error be related to your code?
My Rules are:
On System#Boot do
timerSet,1,5
On DSTemp#Temperature do
7dt,[DSTemp#Temperature]
On Rules#Timer=1 do
SendToHTTP <IP_2>,80,/control?cmd=lcd,1,1,test123
timerSet,1,5
IP_2 is the address of another module.
Posted: 28 Dec 2017, 15:46
by grovkillen
This is a bug:
https://github.com/letscontrolit/ESPEasy/issues/588
It is fixed in current code but no "dev release" yet. You can compile current code if you know how to or wait for it to be released.
Posted: 28 Dec 2017, 16:36
by sentinel
thanks for the quick response! (I'll check the list of issues next time)
