Rules again follow-up
Re: Rules again follow-up
That can't be all rules, as then there is nothing calling this one rule.
To get the full picture I need to see all rules code...
This was not the latest solution from IT aadmin but it was alost a full working solution. After my change it worked completely
but still it is not logic for me and have my doubt if the variable is loaded.
Add 2 logentry rows of the variables are set but this is all.
on UpdateLightIntensity do
if [Plugin#GPIO#Pinstate#2]=0 and [int#1]=1
// Manual mode is not active, and no recent motion detected.
// So we must turn off the lights.
gpio,10,1
gpio,13,1
on System#Boot do
Monitor GPIO,0 // PIR sensor
Monitor GPIO,2 // Manual mode
on GPIO#0=1 do
// PIR motion detected
// Manual mode is not active, so we must act on the motion sensor
timerSet,1,1800 // 30 minutes timer
let,1,1 // Set variable #1 to indicate we had some motion detected
LogEntry,"var#1: [var#1] A1"
asyncevent,UpdateLightIntensity=[serre_lichtmeting#Analog]
on GPIO#2 do
// Change of "manual mode"
On serre_lichtmeting#Analog do
asyncevent,UpdateLightIntensity=%eventvalue1%
on Rules#Timer=1 do
// 30 minutes has past with no motion detected
let,1,0 // Clear variable #1 to indicate no motion was detected.
LogEntry,"var#1: [var#1] A2"
gpio,10,1
gpio,13,1
LogEntry,"Intensity: %eventvalue1% pwm: n/a gpio: 0 A"
// Either manual mode is active, or recently detected motion
If %eventvalue1%<60
PWM,16,00
Elseif %eventvalue1%<450
gpio,10,1
gpio,13,1
LogEntry,"Intensity: %eventvalue1% pwm: n/a gpio: 0 B"
let,1,2.5*%eventvalue1%-125 // Approximation of the curve
PWM,16,[int#1]
Else
PWM,16,1000
GPIO,10,1
GPIO,13,1
LogEntry,"Intensity: %eventvalue1% pwm: n/a gpio: 0 C"
Endif
Not sure why, but your current copy of "on UpdateLightIntensity do" doesn't match with the last edition I gave in post #47.
Can you update that part with a complete copy of that code?
This is what is expected to be in your rules: (Use the "Select all" link at the top and then ctrl-C to copy it completely)
on System#Boot do
on GPIO#0=1 do
on GPIO#2 do
on Rules#Timer=1 do
if [Plugin#GPIO#Pinstate#2]=0 and [int#1]=0
gpio,10,0
gpio,13,0
If %eventvalue1%<60
// Option #1 Will turn off 10 and 13 because LightIntensity <60
GPIO,10,0
GPIO,13,0
PWM,16,00
LogEntry,"Intensity: %eventvalue1% pwm: 0 gpio: 0 B"
let,1,2.5*%eventvalue1% - 125 // Approximation of the curve
PWM,16,[int#1]
GPIO,10,1 // Option 2 Will turn on 10 and 13 because LightIntensity >= 60
GPIO,13,1
LogEntry,"Intensity: %eventvalue1% pwm: [int#1] gpio: 1 C"
Else
PWM,16,1000
GPIO,10,1 // Option 3 Will turn on 10 and 13 because LightIntensity >= 450
GPIO,13,1
LogEntry,"Intensity: %eventvalue1% pwm: 1000 gpio: 1 D"
Endif
It seems to work now. I see entries in the Log that gpio 10 and 13 are turned on and that is what I missed in the solution I implemented during the day. I test it and hope, tomrrow morning, i get up and movement is is there, the lights turn on. I let you know.
this morning the light went on entering the room. The switch Beweging went to 1. After 30 min the lights went out, still Beweging switch had the status 1. In my opinion it has to do somenthing with the vaiables and the 30min timer.
This is the log:
173664848: EVENT: serre_lichtmeting#Analog=194
173664856: ACT : asyncevent,UpdateLightIntensity=194
173664863: EVENT: UpdateLightIntensity=194
173664880: ACT : gpio,10,0
173664883: GPIO : port#10: set to 0
173664885: ACT : gpio,13,0
173664887: GPIO : port#13: set to 0
173664890: ACT : LogEntry,'Intensity: 194 pwm: n/a gpio: 0 A'
173664892: Intensity: 194 pwm: n/a gpio: 0 A
173664941: SW : GPIO=13 State=0 Output value=0
173665036: HTTP : C001 192.168.2.244 GET... HTTP code: 200
173665043: EVENT: Stekkers3_kastverlichting#State=0
173665053: EVENT: http#192.168.2.244=200
173665382: HTTP: GPIO,13,0
173665385: GPIO : port#13: set to 0
This is the log:
It is acting on the change of the state.
So, I guess you need to set the timer to turn it off when the PIR state becomes 0 again instead of 1.
on GPIO#0 do
if %eventvalue1%=1
// no more motion detected
// Start timer to turn off lights.
Now it seems to work. i'm glad to finish this project. Great work!
There is one more corner-case where it might behave unexpectedly...
But this depends on how often the PIR might toggle.
For example, what if your PIR sensor toggles a few times, since you're sitting still and then start moving a lot for a long time.
Then the timer isn't reset if the motion is detected again.
So we simply need to clear the timer when the PIR state becomes '1' and start the timer again when the PIR changes into '0'.
on GPIO#0 do
if %eventvalue1%=1
timerSet,1,0 // Clear the timer
I just saw your last remark and that sound very logic. Befor I add this part I want to say that everything is working now. As soon as the light intensity came above 60 and movement was detected, the lidstrip went on. I add the new part so it is approaching the point of perfection,
Users browsing this forum: Bing [Bot] and 3 guests
