"command unknown" on publish rule?
Posted: 03 May 2024, 18:37
I'm new to ESP Easy and have a 1M install (for now) on an ESP-01s relay module that I'm using to turn a small pump on and off.
For some reason, now that I'm adding more MQTT publish info into the rule set, the publish line for when the pump is turned on an offi is returning Command Unknown on the status
It appears to be throwing the error on both the on and off publish commands:
On System#Boot Do
GPIO,0,1
Publish,"%sysname%/status/flash/freq","%flash_freq%MHz"
Publish,"%sysname%/status/flash/freq","%flash_size%Bytes"
Publish,"%sysname%/status/CPU/freq","%cpu_freq%MHz"
Publish,"%sysname%/status/FS/size","%fs_size%Bytes"
Publish,"%sysname%/status/FS/free","%fs_free%Bytes"
TimerSet,2,15
// report time on system waking
On System#Wake Do
GPIO,0,1
// NTP time is likely not yet set on first start
if %unixtime%>0
Publish,"%sysname%/status/Sleep","%lcltime%:Awake"
TimerSet,2,15
On Time#Initialized Do
Publish,"%sysname%/Time/Init","%lcltime%"
Publish,"%sysname%/Time/Sunrise","%sunrise%AM"
Publish,"%sysname%/Time/Sunset","%sunset%PM"
On Rules#Timer=1 Do
GPIO,0,1
[i]Publish,"%sysname%/Relay/Pump","%lcltime%:Off"[/i]
Publish,"%sysname%/Power/VCC","%vcc%VDC"
TimerSet,2,270
On Rules#Timer=2 Do
// only turn on the pump during daylight hours
if (%syssec_d%>%s_sunrise%) and (%syssec_d%<%s_sunset%)
GPIO,0,0
[i]Publish,"%sysname%/Relay/Pump","%lcltime%:On"[/i]
TimerSet,1,30
TimerSet,2,1800
On System#Sleep Do
Publish,"%sysname%/status/Sleep","%lcltime%:Sleeping"
GPIO,0,1
Command unknown: Relay,0,2024-05-03 12:24:58:Pump On
Command unknown: Relay,0,2024-05-03 12:20:28:Pump Off
Command unknown: Relay,0,2024-05-03 12:19:58:Pump On
