Wrong serial data?
Posted: 13 May 2024, 15:40
I am using rflink via iobroker's rflink adapter.
Since firmware 1.50 I get strange/random debug messages in the log.
They are of type Wrong serial data: BLDEBUG=xxxx
I have logged some, and time fitting what rflink received.
The strange thing, AFAIK only known devices to rflink a logged in the "command line" and I don't own a Broadlink device, nore is one in the learned device/channels configuration (maybe slipped in from neighbours).
2024-04-29 00:02:47.473 - warn: rflink.0 (44671) Wrong serial data: BLDEBUG=82489a040801982489
2024-04-29 00:02:47.527 - warn: javascript.0 (44714) script.js.common.rflink_log: 20;B7;Broadlink;ID=82489a04;SWITCH=01;CMD=ON;
2024-04-29 01:31:45.333 - warn: rflink.0 (44671) Wrong serial data: BLDEBUG=000000000000000000
2024-04-29 01:31:45.365 - warn: javascript.0 (44714) script.js.common.rflink_log: 20;11;Broadlink;ID=00000000;SWITCH=01;CMD=OFF;
2024-04-29 01:44:40.991 - warn: rflink.0 (44671) Wrong serial data: BLDEBUG=e22109522006788842
2024-04-29 01:44:41.007 - warn: javascript.0 (44714) script.js.common.rflink_log: 20;37;Broadlink;ID=e2210952;SWITCH=01;CMD=ON;
2024-04-29 02:40:13.308 - warn: rflink.0 (44671) Wrong serial data: BLDEBUG=000000000000000000
2024-04-29 02:40:13.341 - warn: javascript.0 (44714) script.js.common.rflink_log: 20;F3;Broadlink;ID=00000000;SWITCH=01;CMD=OFF;
2024-04-29 03:10:22.033 - warn: rflink.0 (44671) Wrong serial data: BLDEBUG=e22132a8400cf11099
2024-04-29 03:10:22.052 - warn: javascript.0 (44714) script.js.common.rflink_log: 20;5E;Broadlink;ID=e22132a8;SWITCH=01;CMD=ON;
2024-04-29 04:49:15.663 - warn: rflink.0 (44671) Wrong serial data: BLDEBUG=0000000000f0000000
2024-04-29 04:49:15.687 - warn: javascript.0 (44714) script.js.common.rflink_log: 20;B4;Broadlink;ID=00000000;SWITCH=01;CMD=OFF;
2024-04-29 05:06:21.228 - warn: rflink.0 (44671) Wrong serial data: BLDEBUG=000000aa3ea2000000
2024-04-29 05:06:21.248 - warn: javascript.0 (44714) script.js.common.rflink_log: 20;ED;Broadlink;ID=000000aa;SWITCH=01;CMD=OFF;
2024-04-29 05:49:49.163 - warn: rflink.0 (44671) Wrong serial data: BLDEBUG=000000000000000000
2024-04-29 05:49:49.193 - warn: javascript.0 (44714) script.js.common.rflink_log: 20;87;Broadlink;ID=00000000;SWITCH=01;CMD=OFF;
2024-04-29 07:10:08.976 - warn: rflink.0 (44671) Wrong serial data: BLDEBUG=000000000000000000
