Sonoff Dual R3 Esp32 damaged trace
Posted: 02 Sep 2024, 12:40
I've managed to damage the 3v and rx trace on this board, I've cleaned up the areas and ordered some conductive foil to repair, I have a couple of questions hopefully someone can help me with.
Is the foil suitable for this repair?
I have circled in red the 2 points I believe need to be joined, does that look correct? I couldn't find any schematic for this board, I'm not entirely sure it would have helped me with this repair if I had..
I've also pulled the trace on the RX(blue circle), I've already successfully flashed the device with Esphome, so I don't care if I can't connect to the Rx point in the future, but is there any repir needed at that point, currently the board is dead when connected to AC, I'm hoping that fixing the 3.3v trace will fix that.
Any support appreciated
