I have two INEL shutters that don’t seem to be recognized by RFLINK. Here are some resources about the product:
https://www.inel.gda.pl/en/
https://www.inel.gda.pl/images/pliki/ma ... 1PM_EN.pdf
The remotes transmit a 433 MHz signal. The code from DEBUG mode is attached below. It appears that the code is not consistent, I recorded it twice for each button.
I hope you can implement support for these in RFLINK!
Remote 1 – UP – Try1
20;04;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,330,300,300,300,3930,720,300,720,300,720,300,300,690,300,690,300,690,720,300,720,300,300,720,720,300,300,690,300,690,300,690,300,720,300,690,300,720,720,300,720,300,300,720,300,690,300,690,720,300,300,720,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,330,300,690,720,300,300,690,720,300,720,300,720,300,300,720,300,690,300,690,300,720,720,300,720,300,720,300,330,690,300,720,720,300,300,690,720,300,300,690,720,300,330,720,300,690,720,300,720,300,720,300,720,300,720,330,720,300,720,300,720,300,300,690,300,720,300,690,300,720,300,690,300,690,300,6990;
20;05;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,300,270,300,300,300,300,270,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,690,300,690,300,720,720,300,720,300,300,690,720,300,300,690,300,690,300,720,300,720,300,690,300,690,720,300,720,300,300,720,300,720,300,690,720,300,300,690,720,300,300,720,300,690,330,690,300,690,720,300,720,300,720,300,720,300,300,720,300,690,300,690,300,720,720,300,720,300,300,690,720,300,690,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,690,690,300,300,720,720,300,300,690,720,300,300,720,300,690,720,300,720,330,720,300,720,300,720,300,720,300,720,300,720,300,300,720,300,720,300,720,300,690,300,690,300,690,300,6990;
20;06;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,270,300,300,270,300,270,300,300,300,300,300,300,300,300,330,300,300,3930,690,300,720,300,720,330,300,690,300,690,300,690,720,300,720,300,300,720,720,300,300,690,300,690,300,690,300,720,300,720,300,690,720,300,720,300,300,690,300,720,300,690,720,300,300,690,720,300,300,690,300,720,300,690,300,690,720,300,720,330,720,300,720,300,300,690,300,690,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,330,690,720,300,300,690,720,300,720,300,720,300,300,690,330,690,300,690,300,720,720,300,720,300,720,300,300,720,300,690,720,300,300,690,720,300,300,690,720,300,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,330,690,300,690,300,6990;
20;07;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,270,300,300,270,300,300,300,300,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,720,300,690,300,690,720,300,720,300,300,720,720,300,300,690,300,690,300,690,330,690,300,720,300,690,720,300,720,300,300,690,300,720,300,720,720,300,300,690,720,300,300,690,300,720,300,720,300,690,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,330,720,300,720,300,300,690,300,690,300,690,300,690,720,330,720,300,720,300,300,690,300,690,720,300,300,720,720,300,300,690,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,330,690,300,720,300,720,300,690,300,690,300,6990;
20;08;DEBUG;Pulses=182;Pulses(uSec)=390,300,270,300,270,270,300,270,300,300,270,300,300,300,300,300,300,300,300,300,330,3930,720,300,720,300,720,300,330,720,300,690,300,690,720,300,690,300,300,690,720,300,330,690,300,690,300,690,300,690,300,720,300,720,720,330,720,300,300,690,300,690,300,720,720,300,300,690,720,300,300,690,300,690,300,720,300,690,720,300,720,300,720,300,720,300,300,690,300,690,300,690,300,690,690,300,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,720,720,300,300,690,720,300,300,690,330,690,720,300,720,300,720,300,720,300,720,300,720,330,720,300,720,300,300,690,300,690,300,690,300,720,300,720,300,690,300,6990;
20;09;DEBUG;Pulses=182;Pulses(uSec)=390,300,330,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,720,300,690,720,300,720,330,300,690,300,720,720,300,300,690,300,690,720,300,720,300,300,720,300,690,720,300,300,690,720,300,300,690,330,720,720,300,300,690,720,300,720,300,300,720,720,330,300,690,300,690,300,690,300,690,300,720,720,300,720,330,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,330,720,300,720,720,300,720,300,720,300,300,690,300,720,720,300,300,690,720,300,300,690,720,300,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,300,690,300,720,300,6990;
20;0A;DEBUG;Pulses=182;Pulses(uSec)=510,270,300,300,270,300,300,270,300,270,300,300,300,330,300,300,300,300,300,300,300,3930,720,330,300,720,720,300,720,300,720,300,720,300,720,300,300,720,300,690,720,300,720,300,300,690,300,690,720,300,300,720,300,690,720,300,720,300,300,720,300,690,720,300,330,690,720,300,300,690,300,720,720,300,300,690,720,330,720,300,300,720,720,300,300,690,300,690,300,690,300,720,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,330,720,300,300,690,300,720,720,300,300,690,720,300,300,720,720,300,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,330,690,300,690,300,690,300,690,300,6990;
20;0B;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,270,300,300,270,300,270,270,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,720,300,690,720,300,720,300,330,690,300,690,720,300,300,690,300,690,720,300,720,300,330,720,300,720,720,300,300,690,720,300,300,690,300,720,720,300,300,690,720,300,720,300,300,690,720,300,300,720,300,690,300,690,300,690,300,720,720,300,720,300,330,690,720,300,720,300,720,300,720,300,300,690,720,300,330,690,720,300,720,300,720,300,300,690,300,690,300,720,300,720,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,300,690,720,300,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,300,690,300,720,300,6990;
20;0C;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,270,300,270,300,270,300,300,330,300,300,300,300,300,300,3930,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,690,330,720,720,300,720,300,300,690,300,690,720,300,300,720,300,690,720,300,720,300,300,690,300,720,720,300,300,720,720,300,300,690,300,690,720,300,300,690,720,300,720,300,300,690,720,300,300,720,300,690,300,690,300,690,330,690,720,300,720,300,300,690,720,300,720,300,720,330,720,300,300,690,720,300,300,690,720,300,720,300,720,330,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,720,300,300,690,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,720,300,690,300,690,300,6990;
20;0D;DEBUG;Pulses=182;Pulses(uSec)=330,300,300,270,300,300,300,270,270,300,300,270,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,690,300,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,300,720,300,690,720,300,300,690,300,720,720,300,720,300,300,720,300,690,720,300,300,720,720,300,300,690,300,690,720,300,300,720,720,300,720,300,300,690,720,300,300,690,330,690,300,690,300,690,300,690,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,720,720,300,300,720,720,300,720,300,720,300,300,720,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,690,720,300,330,690,720,300,300,690,720,300,300,690,300,690,720,330,720,300,720,300,720,300,720,300,720,300,720,300,720,330,300,690,300,690,300,690,300,690,300,720,300,690,300,6990;
20;13;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,330,300,3930,300,690,720,300,300,690,330,690,720,300,300,690,720,300,720,300,300,690,720,330,720,300,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,300,690,720,300,720,300,720,300,300,690,720,300,300,690,720,300,330,690,300,690,300,690,300,690,300,690,300,720,720,330,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,720,300,720,720,300,720,300,720,300,300,690,330,690,720,300,300,690,720,300,720,300,300,690,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,300,720,300,690,300,6990;
20;14;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,300,270,300,300,270,300,270,300,270,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,690,300,690,720,300,300,690,720,330,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,300,690,720,300,720,300,720,300,300,720,720,300,300,690,720,300,300,690,300,690,300,690,300,720,300,690,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,720,720,300,300,690,720,330,720,300,300,690,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,300,690,300,690,300,6990;
20;15;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,270,300,270,270,300,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,720,300,720,720,300,300,690,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,720,720,300,300,690,300,690,720,330,720,300,720,300,300,690,720,300,300,690,720,300,300,720,300,690,300,690,300,690,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,690,720,300,720,300,300,690,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,300,690,330,690,300,6990;
20;16;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,270,300,270,300,270,270,300,300,270,300,300,300,300,300,300,300,300,300,3930,300,720,720,300,300,690,300,720,720,300,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,330,300,690,300,690,720,300,720,300,720,300,300,720,720,300,300,690,720,300,300,690,300,720,300,690,300,690,300,720,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,330,720,300,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,720,300,720,300,300,690,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,720,300,690,300,690,300,6990;
20;17;DEBUG;Pulses=182;Pulses(uSec)=330,270,300,270,300,270,300,300,270,270,300,270,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,690,300,690,720,300,300,690,720,300,720,300,300,690,690,300,720,330,720,300,720,300,300,690,720,300,720,300,720,300,720,330,720,300,300,690,690,300,300,720,300,690,720,300,720,300,720,300,300,690,720,300,300,690,720,300,300,690,330,690,300,720,300,720,300,690,300,690,720,300,720,300,330,720,720,300,720,300,720,300,720,300,300,690,720,330,300,690,720,300,720,300,720,300,300,720,300,720,300,720,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,300,690,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,330,720,300,300,690,300,690,300,690,300,690,300,720,300,720,300,6990;
20;1D;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,300,300,300,300,300,330,300,300,300,300,300,300,300,3930,720,330,720,300,720,300,300,690,720,300,300,690,720,300,300,720,720,300,300,690,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,330,300,690,720,300,300,720,720,300,300,690,300,690,300,720,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,720,720,300,300,690,720,300,720,330,300,690,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,330,690,300,690,300,690,300,690,300,6990;
20;1E;DEBUG;Pulses=182;Pulses(uSec)=330,300,270,300,270,300,300,270,300,270,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,690,720,300,300,690,720,300,300,720,720,300,300,690,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,330,720,300,720,300,690,720,300,720,300,720,300,720,330,720,300,720,300,720,300,300,690,720,300,300,720,720,300,300,690,300,690,300,690,300,720,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,690,720,300,330,690,720,300,720,300,720,300,300,690,300,690,300,720,300,720,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,300,690,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,300,690,300,720,300,6990;
20;1F;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,270,300,300,270,300,270,300,300,300,300,330,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,690,720,300,300,690,720,300,300,690,720,300,300,690,300,690,720,300,720,300,720,300,720,330,300,690,720,300,300,690,300,690,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,720,720,300,300,720,720,300,300,690,300,690,300,690,330,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,330,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,690,720,300,720,300,330,690,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,300,690,300,690,300,6990;
20;20;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,300,300,270,300,300,270,300,300,300,300,300,300,300,300,300,300,3930,720,300,720,300,720,300,300,720,720,300,330,690,720,300,300,690,720,300,300,720,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,300,720,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,330,690,300,690,300,690,300,690,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,690,720,300,300,720,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,300,690,300,690,720,300,330,720,720,300,720,300,300,690,300,690,300,690,720,330,720,300,720,300,720,300,720,300,720,300,720,300,720,330,300,690,300,690,300,690,300,720,300,690,300,690,300,6990;
20;21;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,270,300,300,270,300,300,300,300,300,330,300,300,300,300,3930,720,300,720,330,720,300,300,720,720,300,300,690,720,300,300,690,720,330,300,720,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,300,720,300,690,300,690,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,330,690,300,690,720,300,300,720,720,300,720,300,300,720,300,690,300,690,720,300,720,300,720,300,720,300,720,330,720,300,720,300,720,300,300,690,300,690,300,690,300,720,300,690,300,690,300,6990;
20;22;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,330,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,300,720,720,300,720,300,330,690,720,300,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,300,690,720,300,300,690,300,720,300,690,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,300,690,300,720,300,720,300,690,330,690,300,690,300,690,720,300,720,300,300,690,720,330,720,300,720,300,720,300,300,690,720,300,300,690,720,330,720,300,720,300,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,330,690,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,720,300,690,300,720,300,690,300,690,300,690,300,6990;
20;23;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,270,300,300,270,270,300,270,300,300,300,300,300,300,300,300,300,330,300,3930,720,300,300,690,720,300,330,720,720,300,720,300,300,690,720,300,720,300,720,330,720,300,720,300,300,690,720,300,720,300,720,300,300,720,720,300,300,690,300,720,300,690,720,300,720,300,720,300,720,300,300,720,720,300,720,300,720,300,300,690,330,720,300,720,300,690,300,690,300,690,300,690,720,330,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,330,690,720,300,300,720,300,690,720,300,720,300,300,720,300,720,720,300,720,300,720,300,720,300,720,300,720,330,720,300,720,300,300,690,300,690,300,720,300,690,300,720,300,690,300,6990;
20;24;DEBUG;Pulses=182;Pulses(uSec)=390,300,270,300,270,270,300,270,300,300,300,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,300,720,720,300,720,300,300,720,720,300,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,300,690,720,300,300,690,300,720,330,720,720,300,720,300,720,300,720,300,300,720,720,330,720,300,720,300,300,690,300,690,300,720,300,690,300,720,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,300,720,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,720,300,720,300,690,300,690,300,6990;
20;25;DEBUG;Pulses=182;Pulses(uSec)=360,300,300,300,270,270,300,270,300,300,270,300,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,300,690,720,300,300,690,300,690,300,720,720,300,720,300,720,330,720,300,300,720,720,300,720,300,720,300,300,690,300,720,300,720,300,690,300,690,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,720,300,690,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,690,300,720,300,690,330,690,300,6990;
20;26;DEBUG;Pulses=182;Pulses(uSec)=360,300,270,300,300,270,300,300,270,300,270,270,300,300,300,300,300,300,300,300,300,3930,720,300,300,690,720,300,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,300,690,720,300,300,690,300,690,300,720,720,300,720,300,720,300,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,300,690,300,720,300,690,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,330,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,690,300,720,720,300,720,300,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,300,720,300,690,300,6990;
20;27;DEBUG;Pulses=182;Pulses(uSec)=390,300,300,300,300,300,300,300,330,300,300,300,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,690,300,690,300,690,300,720,720,300,720,300,720,300,720,300,300,690,720,300,720,330,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,720,300,330,690,720,300,300,690,720,300,300,690,720,300,300,690,330,690,300,720,300,690,720,300,720,300,300,690,720,330,720,300,720,300,720,300,300,690,720,300,300,720,720,300,720,300,720,300,300,690,300,690,300,720,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,690,330,690,720,300,720,300,300,690,300,690,720,300,720,330,720,300,720,300,720,300,720,300,720,300,720,300,300,720,300,720,300,690,300,690,300,690,300,690,300,6990;
20;28;DEBUG;Pulses=182;Pulses(uSec)=360,270,300,300,270,300,270,270,300,270,300,270,300,300,300,300,300,300,300,330,300,3930,300,690,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,720,300,300,690,720,300,720,300,300,690,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,720,300,300,690,720,300,300,690,720,330,300,690,720,300,300,690,300,690,300,720,300,720,720,330,720,300,300,690,720,300,720,300,720,300,720,300,300,720,720,300,300,690,720,300,720,300,720,300,300,690,330,690,300,720,300,690,720,300,720,300,720,300,300,690,330,720,720,300,300,690,300,690,720,300,720,300,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,690,330,690,300,690,300,6990;
20;29;DEBUG;Pulses=182;Pulses(uSec)=360,300,300,300,300,270,300,300,300,270,300,300,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,720,300,690,300,690,300,690,720,300,720,300,720,300,720,300,300,690,720,300,720,300,330,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,720,300,300,720,720,300,300,690,720,300,300,720,720,300,300,690,300,720,300,690,300,720,720,300,720,300,300,690,690,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,690,300,690,300,720,720,330,720,300,720,300,300,690,300,720,720,300,300,690,300,720,720,300,720,300,300,720,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,330,720,300,720,300,690,300,690,300,690,300,6990;
20;2A;DEBUG;Pulses=182;Pulses(uSec)=330,300,270,300,300,270,300,270,270,270,300,300,300,300,300,300,300,300,300,300,300,3930,300,690,720,300,300,720,300,720,300,690,300,690,720,300,720,300,720,300,720,300,330,690,720,300,720,300,300,720,720,300,720,300,300,720,720,300,720,300,720,300,720,300,300,690,300,690,720,330,720,300,720,300,300,690,720,300,300,690,720,300,300,720,720,300,300,690,300,690,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,720,300,300,690,720,300,720,300,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,300,690,300,720,720,300,300,690,300,690,720,300,720,300,300,690,300,720,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,720,300,690,300,720,300,690,300,6990;
20;2B;DEBUG;Pulses=182;Pulses(uSec)=330,300,270,300,300,270,300,270,300,300,270,300,300,300,300,300,300,300,300,300,300,3930,300,720,720,300,300,690,300,720,300,690,300,690,720,300,720,300,720,300,720,300,300,690,720,300,720,300,300,720,720,300,720,300,300,690,720,300,720,300,720,300,720,300,300,690,300,690,720,300,720,300,720,300,300,720,720,300,300,690,720,300,300,690,720,300,300,690,300,690,330,690,300,690,720,300,720,300,300,690,720,300,720,330,720,300,720,300,300,690,720,300,300,690,720,300,720,330,720,300,300,690,300,690,300,690,300,690,720,300,720,300,720,300,300,690,300,690,720,300,300,720,300,690,720,300,720,300,300,690,300,690,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,720,300,690,300,720,300,690,300,690,300,6990;
