Build fails with VSCOD, only version mega-20240822- Latest Version.
Posted: 03 Nov 2024, 00:46
Something strange happened when using the latest version of Espeasy 20240822.
After opening in Open paste, I use a directory cloned through Git Clone, this information appears in VSCOD:
Resolving max_ESP32_16M8M_LittleFS_ETH dependencies...
Tool Manager: Installing https://github.com/Jason2866/esp32-ardu ... 74f314.zip
Unpacking 0% 10%Unpacking...
FileNotFoundError: Traceback (most recent call last):
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py", line 37, in unpack
return fu.unpack(dst, with_progress=with_progress)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\unpack.py", line 185, in unpack
self._archiver.extract_item(item, dest_dir)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\unpack.py", line 49, in extract_item
self._afo.extract(item, dest_dir)
File "C:\Users\william\AppData\Local\Programs\Python\Python312\Lib\zipfile\__init__.py", line 1726, in extract
return self._extract_member(member, path, pwd)
File "C:\Users\william\AppData\Local\Programs\Python\Python312\Lib\zipfile\__init__.py", line 1801, in _extract_member
open(targetpath, "wb") as target:
FileNotFoundError: [Errno 2] No such file or directory: 'c:\\Users\\william\\Documents\\ESPEasy\\ESPEasy\\.platformio\\.cache\\tmp\\pkg-installing-jxmxqy8u\\framework-arduinoespressif32\\tools\\esp32-arduino-libs\\esp32\\include\\mbedtls\\mbedtls\\3rdparty\\everest\\include\\everest\\kremlib\\FStar_UInt64_FStar_UInt32_FStar_UInt16_FStar_UInt8.h'
During handling of the above exception, another exception occurred:
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\__main__.py", line 103, in main
cli() # pylint: disable=no-value-for-parameter
File "C:\Users\william\.platformio\penv\Lib\site-packages\click\core.py", line 1157, in __call__
return self.main(*args, **kwargs)
File "C:\Users\william\.platformio\penv\Lib\site-packages\click\core.py", line 1078, in main
rv = self.invoke(ctx)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\cli.py", line 85, in invoke
return super().invoke(ctx)
File "C:\Users\william\.platformio\penv\Lib\site-packages\click\core.py", line 1688, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "C:\Users\william\.platformio\penv\Lib\site-packages\click\core.py", line 1434, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "C:\Users\william\.platformio\penv\Lib\site-packages\click\core.py", line 783, in invoke
return __callback(*args, **kwargs)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\project\commands\init.py", line 106, in project_init_cmd
install_project_dependencies(
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py", line 107, in install_project_dependencies
already_up_to_date = not install_project_env_dependencies(env, options)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py", line 132, in install_project_env_dependencies
_install_project_env_platform(project_env, options),
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py", line 149, in _install_project_env_platform
PlatformPackageManager().install(
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\manager\platform.py", line 62, in install
p.install_required_packages(force=force)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\platform\_packages.py", line 76, in install_required_packages
self.install_package(name, force=force)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\platform\_packages.py", line 70, in install_package
return self.pm.install(spec or self.get_package_spec(name), force=force)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py", line 47, in install
pkg = self._install(spec, skip_dependencies=skip_dependencies, force=force)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py", line 97, in _install
pkg = self.install_from_uri(spec.uri, spec)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py", line 191, in install_from_uri
self.unpack(dl_path, tmp_dir)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py", line 42, in unpack
return fu.unpack(dst, with_progress=False)
File "C:\Users\william\.platformio\penv\Lib\site-packages\platformio\package\unpack.py", line 178, in unpack
An unexpected error occurred. Further steps:
* Verify that you have the latest version of PlatformIO using
`python -m pip install -U platformio` command
* Try to find answer in FAQ Troubleshooting section
https://docs.platformio.org/page/faq/index.html
* Report this problem to the developers
https://github.com/platformio/platformio-core/issues
I ran the command python -m pip install -U platformio` command with the following results:
Requirement already satisfied: platformio in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (6.1.16)
Requirement already satisfied: click<9,>=8.0.4 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (8.1.7)
Requirement already satisfied: colorama in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (0.4.6)
Requirement already satisfied: marshmallow==3.* in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (3.23.1)
Requirement already satisfied: pyelftools<1,>=0.27 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (0.31)
Requirement already satisfied: pyserial==3.5.* in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (3.5)
Requirement already satisfied: requests==2.* in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (2.32.3)
Requirement already satisfied: semantic-version==2.10.* in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (2.10.0)
Requirement already satisfied: tabulate==0.* in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (0.9.0)
Requirement already satisfied: ajsonrpc==1.2.* in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (1.2.0)
Requirement already satisfied: starlette<0.40,>=0.19 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (0.39.2)
Requirement already satisfied: wsproto==1.* in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (1.2.0)
Requirement already satisfied: bottle==0.13.* in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (0.13.2)
Requirement already satisfied: uvicorn<0.31,>=0.16 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from platformio) (0.30.6)
Requirement already satisfied: packaging>=17.0 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from marshmallow==3.*->platformio) (24.1)
Requirement already satisfied: charset-normalizer<4,>=2 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from requests==2.*->platformio) (3.4.0)
Requirement already satisfied: idna<4,>=2.5 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from requests==2.*->platformio) (3.10)
Requirement already satisfied: urllib3<3,>=1.21.1 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from requests==2.*->platformio) (2.2.3)
Requirement already satisfied: certifi>=2017.4.17 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from requests==2.*->platformio) (2024.8.30)
Requirement already satisfied: h11<1,>=0.9.0 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from wsproto==1.*->platformio) (0.14.0)
Requirement already satisfied: anyio<5,>=3.4.0 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from starlette<0.40,>=0.19->platformio) (4.6.2.post1)
Requirement already satisfied: sniffio>=1.1 in c:\users\william\appdata\local\programs\python\python312\lib\site-packages (from anyio<5,>=3.4.0->starlette<0.40,>=0.19->platformio) (1.3.1)
Previous versions I can compile normally.
What has changed for Vscod in this new version?
