Lctech relay board
Lctech relay board
Hi all. I'm very new to espeasy so pls be gentle with me. I have a lctech relay board the same as this http://www.chinalctech.com/uploads/alli ... 1423-0.jpg I've managed to flash espeasy on the esp-01 micro controller and can access it via http. My question is how do I set it up so I can automatically turn on the relay using a temp sensor when the temp is below a temp and off when above. Thank you for any input.
Re: Lctech relay board
this is actually quite simple. Add the temperature sensor in the devices page an then also add the level control plugin.
Thank you I'll give it a go.chromo23 wrote: ↑13 Nov 2024, 08:40Hi,
