I have been trying to use the option in espeasy to log to a remote syslog server. This works OK except that I find the esp entry logged on the syslog server with a facility of 'kernel' rather than something more appropriate.
I have taken a look at the espeasy routine 'syslog' in module 'networking' and the reason is clear - the message is logged to syslog using a hardcoded priority of 7.
The priority is calculated as 8 * Facility + Severity and so if the priority is to remain hardcoded, a priority of 133 (Facility=local0=16 and Severity=Warn=5) might be more appropriate.
Even better if this could be made configurable in the webserver.
N
Syslog
Re: Syslog
In addition to this I also wonder why the ESP generated syslog messages do not follow "usual" structure.
So instead of
why not send
So reuse the hostname to identify for ESP - or the real hostname if applicable, the programname could be the ESP Name and the PID the node id.
This would make filtering of syslog much more intuitive and easier. With rsyslog one could write analog to my CRON here
instead of a clumsy definition I currently use
Any comments on this one anyone?
Regards, Alex.
So instead of
2017-10-10 12:01:09 ESP Unit: 2 : WIFI : Connected! IP: 192.168.xxx.xxx (ESPEasy_BME280_2)
2017-10-10 12:01:09 ESPEasy ESPEasy_BME280[2]: WIFI : Connected! IP: 192.168.xxx.xxx (ESPEasy_BME280_2)
# CRON rsyslog
# Catch all CRON generated syslog messages and redirect to a dedicated file
if $programname == "CRON" then {
# collect all matching messages in one dedicated file
action(type="omfile" file="/var/log/cron.log" name="CRON_omfile")
# we do not want to have this kind of logs in other log files
stop
# rsyslog config for espeasy devices
# define ruleset and bind it to the udp input module
# Debugging template as the syslog string of espeasy is strange 2016-12
template(name="esplog_debug" type="string"
string="%TIMESTAMP:::date-rfc3339%°%syslogfacility-text%°%HOSTNAME%°%syslogtag%°%msg:::sp-if-no-1st-sp%°%msg:::drop-last-lf%°%rawmsg:::drop-last-lf%°\n"
#:rawmsg,contains, "ESP Unit:" /var/log/espeasy/espeasy_all_debug.log;esplog_debug
# define ruleset for remote logging of messages
ruleset(name="espeasy_remote"){
# check if comming from espeasy nodes
if $hostname == "ESP" then {
# collect all espeasy related messages in one big file
action(type="omfile" file="/var/log/espeasy/espeasy_all.log" name="espeasy_remote_omfile")
# save messages from different units to different files
if $rawmsg contains "Unit: 1" then /var/log/espeasy/espeasy-sonoff_nixie.log
if $rawmsg contains "Unit: 2" then /var/log/espeasy/espeasy-bme280.log
if $rawmsg contains "Unit: 99" then /var/log/espeasy/espeasy-nodemcu.log
# we do not want to have espeasy logs in other log files
stop
# bind ruleset to tcp listener and activate it
input(type="imudp" port="514" ruleset="espeasy_remote" name="input_espeasy_remote")
Regards, Alex.
Users browsing this forum: Bing [Bot] and 16 guests
