JEEDOM good news !!!!
Posted: 28 Mar 2016, 16:27
i write my first _C00x.ino script for sending value of a ds18b20 to jeedom.
this code is very sad ... but works if the specialist in ino code are here perhaps they could use it and clean it
thanks
this code is based on thinkspeak .....
//########################### Controller Plugin 009: Jeedom #########################################
#define CPLUGIN_009
#define CPLUGIN_ID_009 9
#define CPLUGIN_NAME_009 "Jeedom HTTP"
boolean CPlugin_009(byte function, struct EventStruct *event, String& string)
boolean success = false;
switch (function)
case CPLUGIN_PROTOCOL_ADD:
Protocol[++protocolCount].Number = CPLUGIN_ID_009;
Protocol[protocolCount].usesMQTT = false;
Protocol[protocolCount].usesAccount = false;
Protocol[protocolCount].usesPassword = true;
Protocol[protocolCount].defaultPort = 80;
case CPLUGIN_GET_DEVICENAME:
string = F(CPLUGIN_NAME_009);
case CPLUGIN_PROTOCOL_SEND:
char log[80];
char host[20];
sprintf_P(host, PSTR("%u.%u.%u.%u"), Settings.Controller_IP[0], Settings.Controller_IP[1], Settings.Controller_IP[2], Settings.Controller_IP[3]);
sprintf_P(log, PSTR("%s%s using port %u"), "HTTP : connecting to ", host,Settings.ControllerPort);
addLog(LOG_LEVEL_DEBUG, log);
// Use WiFiClient class to create TCP connections
WiFiClient client;
if (!client.connect(host, Settings.ControllerPort))
connectionFailures++;
strcpy_P(log, PSTR("HTTP : connection failed"));
addLog(LOG_LEVEL_ERROR, log);
return false;
statusLED(true);
if (connectionFailures)
connectionFailures--;
String postDataStr = SecuritySettings.ControllerPassword; // "0UDNN17RW6XAS2E5" // api key for jeedom
switch (event->sensorType)
case SENSOR_TYPE_SINGLE: // single value sensor, used for Dallas, BH1750, etc
case SENSOR_TYPE_SWITCH:
postDataStr += F("&field");
postDataStr += event->idx;
postDataStr += "=";
postDataStr += toString(UserVar[event->BaseVarIndex],ExtraTaskSettings.TaskDeviceValueDecimals[0]);
case SENSOR_TYPE_TEMP_HUM: // dual value
case SENSOR_TYPE_TEMP_BARO:
postDataStr += "=";
postDataStr += event->idx + 1;
postDataStr += "=";
postDataStr += toString(UserVar[event->BaseVarIndex + 1],ExtraTaskSettings.TaskDeviceValueDecimals[1]);
case SENSOR_TYPE_TEMP_HUM_BARO:
postDataStr += "=";
postDataStr += "=";
postDataStr += event->idx + 2;
postDataStr += "=";
postDataStr += toString(UserVar[event->BaseVarIndex + 2],ExtraTaskSettings.TaskDeviceValueDecimals[2]);
postDataStr += F("\r\n\r\n");
String postStr = F("POST ");
postStr += F("/jeedom/core/api/jeeApi.php?apikey=");
postStr += SecuritySettings.ControllerPassword;
postStr += F("&type=virtual&id=");
postStr += event->idx;
postStr += F("& HTTP/1.1\n");
postStr += F("Host: ");
postStr += host;
postStr += ("\n");
postStr += F("Connection: close\n");
postStr += F("Content-Type: application/x-www-form-urlencoded\n");
postStr += F("Content-Length: ");
postDataStr = F("value=");
postStr += postDataStr.length();
postStr += F("\n\n");
postStr += postDataStr;
// This will send the request to the server
client.print(postStr);
unsigned long timer = millis() + 200;
while (!client.available() && millis() < timer)
delay(1);
// Read all the lines of the reply from server and print them to Serial
while (client.available()) {
String line = client.readStringUntil('\n');
line.toCharArray(log, 80);
addLog(LOG_LEVEL_DEBUG_MORE, log);
if (line.substring(0, 15) == "HTTP/1.1 200 OK")
strcpy_P(log, PSTR("HTTP : Succes!"));
success = true;
delay(1);
strcpy_P(log, PSTR("HTTP : closing connection"));
client.flush();
client.stop();
return success;
thanks
#define CPLUGIN_009
switch (function)
char log[80];
char host[20];
WiFiClient client;
return false;
statusLED(true);
postDataStr += "=";
postDataStr += "=";
postDataStr += "=";
postDataStr += "=";
postDataStr += "=";
postDataStr += "=";
postStr += host;
postStr += ("\n");
delay(1);
success = true;
delay(1);
client.flush();
client.stop();
return success;
