PCF8591
Re: PCF8591
So you can confirm connection on I2C? Is it using the default address?
Then to read the first port (A IN 0), should only need this setting:
Re: PCF8591
If I take it right, ports should be numbered 1..4, as per https://github.com/ESP8266nu/ESPEasy/bl ... 91.ino#L68Martinus wrote:So you can confirm connection on I2C? Is it using the default address?
Please consider updating Wiki
