Factory reset
Posted: 04 Oct 2015, 10:02
by asm7100
Hi how about explaning how to do this in the wiki
Added option to do a factory reset by connecting RX and TX pins during boot.
Is et rust to connect it to a computer.
To gnd.
Together?
Or???
Re: Factory reset
Posted: 04 Oct 2015, 15:57
by BertB
Together
Re: Factory reset
Posted: 04 Oct 2015, 17:50
by asm7100
Re: Factory reset
Posted: 04 Apr 2016, 11:39
by Tim-
Does this work with an esp8266 07 to?
for how long should i boot the esp to reset it?
Re: Factory reset
Posted: 04 Apr 2016, 12:15
by kirelam
So place the steps: (Correct me if i'm wrong)
-While not powered connect RX and TX together.
-Now BOOT the ESP8266
This trick should do the job?
Re: Factory reset
Posted: 04 Apr 2016, 12:41
by Tim-
i thought the same but it didn't do anything..
if i connect the esp rx and tx with ground: boot it and then boot it normally it didn't reset
if i connect the esp rx and tx with each other: boot it and then boot it normally it didn't reset
Re: Factory reset
Posted: 09 May 2016, 19:25
by kirelam
A friend of mine fixen this problem!
Het flashed a different, for example onder version on the esp. After that he flashed it back to r78.
Now it works again!
