asm7100
#1
Post
by asm7100 » 04 Oct 2015, 17:49
When i try to flash to off my esp-12 modules i cot a error.
Flashing i ok, I reboot and on the seriel console this comes
ªU1073873385
1074852416
Reset!
FLASH: Erase ok
FLASH: Erase ok
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
I dont know and ant findt this anyware?
Can anyone help me. Its R29
5xESP-01 - 3xESP-12 - 2xESP-12E 3xRPIb+ - 1xBPIm1 - 3xACTi DOME - 7xACTi Indoor cam. Lot off cisco equ.
BertB
#2
Post
by BertB » 04 Oct 2015, 20:39
Did you try additional reset?
asm7100
#3
Post
by asm7100 » 04 Oct 2015, 21:19
What do you meen?
asm7100
#4
Post
by asm7100 » 04 Oct 2015, 21:34
I flash Nodemcu to it by the firmware uploader program, thats works.
But not with the Arduino IDE
asm7100
#5
Post
by asm7100 » 06 Oct 2015, 12:47
No help to get?
Martinus
#6
Post
by Martinus » 06 Oct 2015, 15:45
Could you try stable R20 on that module and see it that works?
asm7100
#7
Post
by asm7100 » 06 Oct 2015, 18:09
Yes with R20 its work.
But anoter ESP12 Modul and this moduel is from the same store
![Lach :-)](./images/smilies/icon_e_smile.gif)
The first one, was fine, but not the other.
I will try to flash it with R29 when i have set it up, i R20
asm7100
#8
Post
by asm7100 » 06 Oct 2015, 18:19
It work with R20, now i have flash it with R29, and get this when i boot it up.
1074852416
Reset!
FLASH: Erase ok
FLASH: Erase ok
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
ets_main.c
Martinus
#9
Post
by Martinus » 07 Oct 2015, 08:59
There's something going wrong during flash writing. I have not seen this before in my test lab.
R20 and R30 use a different flash memory area to store it's configuration, so that could explain different behavior.
Are more people experiencing the same issue?
Side note: If your unit get's stuck in a flash erasing loop, better remove the sketch (by using an older release or just program a blink sketch) or power off the ESP module until you have a solution. The ESP flash memory may wear out on that particular sector and may become defective after a number of writes. Don't now the exact maximum of write cycles but with AVR is was >100.000
asm7100
#10
Post
by asm7100 » 07 Oct 2015, 10:28
Its running with R20 for now.
But its strange is that the first (Called esp120) is running R29
But this one i call 121 can' t run R29, but is now running R20
asm7100
#11
Post
by asm7100 » 12 Oct 2015, 13:45
Now i have tried R37 or??? 36.
And it still the same.
