DS1820
Posted: 02 May 2016, 00:34
Dear all,
I changed the Plugin_004_DS_readTemp function such that it gives also correct values for DS1820 or DS18s20 (both with family id 0x10). The code is based on the DallasTemperature-lib 3.7.3
Stefan
Stefan
boolean Plugin_004_DS_readTemp(uint8_t ROM[8], float *value)
int16_t DSTemp;
byte ScratchPad[12];
Plugin_004_DS_reset();
Plugin_004_DS_write(0x55); // Choose ROM
for (byte i = 0; i < 8; i++)
Plugin_004_DS_write(ROM[i]);
Plugin_004_DS_write(0x44);
delay(800);
Plugin_004_DS_write(0xBE); // Read scratchpad
for (byte i = 0; i < 9; i++) // copy 8 bytes
ScratchPad[i] = Plugin_004_DS_read();
if (Plugin_004_DS_crc8(ScratchPad, 8) != ScratchPad[8])
*value=0;
return false;
if(ROM[0] == 0x28 ) //DS18B20
DSTemp = (ScratchPad[1] << 8) + ScratchPad[0];
*value = (float(DSTemp) * 0.0625);
else if(ROM[0] == 0x10 ) //DS1820 DS18S20
DSTemp = (ScratchPad[1] << 11) + ScratchPad[0] << 3;
DSTemp = ((DSTemp & 0xfff0) << 3) - 16 +
((ScratchPad[7] - ScratchPad[6]) << 7) /
ScratchPad[7]
*value = float(DSTemp) * 0.0078125;
return true;
